    How to MANUALLY install MM on your Pi. For absolute beginners.
    27 Posts 5 Posters 23.7k Views 5 Watching
    • slametpsS
      slametps @slametps
      @slametps said in How to MANUALLY install MM on your Pi. For absolute beginners.:
      @Mykle1 said in How to MANUALLY install MM on your Pi. For absolute beginners.:
      @slametps
      You didn’t answer my question.
      You didn’t try my suggestion.
      You did the one thing that I said I didn’t know was your issue.
      Shrug
      Yap, I install MM manually refers to documentation you wrote (and backed up current running MM 2.1.0).
      config. js I mentioned earlier, is a fresh copy from config.js.sample in config folder.
      I did npm-install in MM folder, but not in vendor yet. I’ll try later when I have access to my MM.
      Finally, MM 2.1.3 was installed successfully by executing:
      cd /root/MagicMirror/vendor
      npm install /root/MagicMirror
      cd /root/MagicMirror/fonts
      npm install
      regards,
      Slamet PS
      axellejamousA 1 Reply Last reply Reply Quote 1
      • axellejamousA
        axellejamous @slametps
        @slametps glad you found it! you basically had the same issue as me except I didn’t have the fonts one. It’s really odd.
        slametpsS 1 Reply Last reply Reply Quote 0
        • slametpsS
          slametps @axellejamous
          @axellejamous said in How to MANUALLY install MM on your Pi. For absolute beginners.:
          @axellejamous You should try:
          $ cd {your_magicmirror_folder}/fonts
          $ npm install
          it will install required fonts.
          regards,
          Slamet PS
          • axellejamousA
            @slametps If you run it with npm start, does it work for you?
            For me that only solved my issue if I run it with node serveronly.
            Now there’s 0 errors so I have no clue why my screen still shows up black with npm start.
            • slametpsS
              Yap, it works like a charm now (also after I downgraded electron to 1.6.10 (1.7.9 consumes excessive CPU).
              Firstly, I got the same issue. After I did what I mentioned earlier, it is OK now.
              regards,
              Slamet PS
              • axellejamousA
                @slametps Yeah had to do the same! But I downgraded to 1.7.9, so I’ll change it to 1.6.10 now thank you! :)
                • slametpsS
                  Glad to hear that. I just realize an issue with language translations is not working in default modules such as current-weather. Is anyone here experience same issue?
                  regards,
                  Slamet PS
