    How to MANUALLY install MM on your Pi. For absolute beginners.
    27 Posts 5 Posters 24.2k Views 5 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @noorm91
      @noorm91 said in How to MANUALLY install MM on your Pi. For absolute beginners.:
      How do you apply after each module you try out? Is there a way or do you have to reboot every time?
      You don’t have to reboot the Pi to launch MM after adding a module. Assuming you quit MM before you added the module, you simply launch MM as you normally would
      N 1 Reply Last reply
      • N
        noorm91 @Mykle1
        @Mykle1
        The MM autostarts when booting up the Pi, what’s the command you use to apply/run the config.js right after you save it?
        Mykle1M 1 Reply Last reply
        • Mykle1M
          When the mirror is running, press your Alt key to drop down a menu bar. Choose Minimize from the Window menu. Assuming pm2 is autostarting for you, open a terminal and type pm2 stop mm to quit MM.
          You can start MM after saving your config in the terminal by typing pm2 start mm, or if MM is still running, from the drop down menu, View, Reload
          • foxF
            fox
            The problem was the module watchdog !
            Also with fresh install it throws errors with the newest update.
            Fixed for me. Thank you @Mykle1 !!!
            Issues With MMM-WatchDog known?
            https://forum.magicmirror.builders/post/29827
            Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
            Reply Quote 2
            • axellejamousA
              axellejamous
              I don’t know if this is the right place for me to reply but I’m desperate.
              I’m supposed to do a project for school with the MM but I can’t even seem to get it up and running.
              I made an issue on the forum but so far I’ve gotten no replies :(
              I followed these steps to reinstall the MM but instead of making my own config file I used the one provided. When I run it, the screen is black and I can see in dev tools that the “moment” npm package is having some issues but I can’t find any info anywhere on how to solve it or anyone that has a similar issue.
              • Mykle1M
                Mykle1 Project Sponsor Module Developer @fox
                @fox said in How to MANUALLY install MM on your Pi. For absolute beginners.:
                You’re welcome, mate.
                • Mykle1M
                  Mykle1 Project Sponsor Module Developer @axellejamous
                  @axellejamous said in How to MANUALLY install MM on your Pi. For absolute beginners.:
                  I see that you have fixed your issue in another topic. Very good! Can I ask, are you saying you had this issue after a manual installation? The symptoms and fix you used are commonly associated with the automatic installer or version update. I’m just curious because I have not heard of this happening after a manual installation.
                  axellejamousA 1 Reply Last reply
                  • axellejamousA
                    axellejamous @Mykle1
                    @Mykle1
                    I did luckily!
                    I indeed had the issue after manual installation. Fact is, the automatic installation script would actually get stuck on two of my Pi’s at the node modules installation.
                    So I had to manually install.
                    In the issue that helped me find the answer, he did do a manual install as well and had the same problem.
                    But someone did mention “in the latest version there is a npm install task in the vendor folder as well which gets executed automatically after a successful install, yours wasn’t successful so this was never executed” which means I probably made a mistake in my manual installation, although I have no clue what it could’ve is as I followed the steps thoroughly on 2 different pi’s, getting the same result.
                    Mykle1M slametpsS 2 Replies Last reply
                    • Mykle1M
                      No sir, you made no mistake. You download the software and run npm install in the MagicMirror directory. If, and when that fails, it is no fault of yours.
                      I’m glad you solved your problem and thanks for the information. It’s good to know that in case anyone else encounters that problem with a manual installation.
                      Reply Quote 2
                      • slametpsS
                        slametps @axellejamous
                        @axellejamous I still got no luck making 2.1.3 works. the log said MM run without error. Unfortunately, got a black screen using default config.js (copy from config.js.sample). If I remove config.js, the MM display to create a config. Still no clue how to solve this.
                        regards,
                        Slamet PS
                        • Mykle1M
                          Mykle1 Project Sponsor Module Developer @slametps
                          @slametps said in How to MANUALLY install MM on your Pi. For absolute beginners.:
                          You did a manual install and ran npm install in the MagicMirror directory? He solved his problem by running npm install in the vendor directory. I don’t know if you have the same issue.
                          But it seems to me if MM is reporting “Create a config” that MM is launching correctly. You could try getting a fresh copy of the config.js.sample (in case something is wrong with the one you have) and trying again.
                          Good luck
                          slametpsS 1 Reply Last reply
                          • slametpsS
                            slametps @Mykle1
                            @Mykle1 said in How to MANUALLY install MM on your Pi. For absolute beginners.:
                            Good luck
                            Yap, I just copy config.js from config.js.sample, and got a black screen.
                            I will give a try, running npm install in vendor folder.
                            regards,
                            Slamet PS
                            • Mykle1M
                              @slametps
                              You didn’t answer my question.
                              You didn’t try my suggestion.
                              You did the one thing that I said I didn’t know was your issue.
                              Shrug
                              • slametpsS
                                slametps @Mykle1
                                @slametps
                                Shrug
                                Yap, I install MM manually refers to documentation you wrote (and backed up current running MM 2.1.0).
                                config. js I mentioned earlier, is a fresh copy from config.js.sample in config folder.
                                I did npm-install in MM folder, but not in vendor yet. I’ll try later when I have access to my MM.
                                regards,
                                Slamet PS
                                • slametpsS
                                  slametps @slametps
                                  @slametps
                                  Shrug
                                  Finally, MM 2.1.3 was installed successfully by executing:
                                  cd /root/MagicMirror/vendor
                                  npm install /root/MagicMirror
                                  cd /root/MagicMirror/fonts
                                  npm install
                                  regards,
                                  Slamet PS
                                  • axellejamousA
                                    axellejamous @slametps
                                    @slametps glad you found it! you basically had the same issue as me except I didn’t have the fonts one. It’s really odd.
                                    • slametpsS
                                      @axellejamous You should try:
                                      $ cd {your_magicmirror_folder}/fonts
                                      $ npm install
                                      it will install required fonts.
                                      regards,
                                      Slamet PS
                                      • axellejamousA
                                        @slametps If you run it with npm start, does it work for you?
                                        For me that only solved my issue if I run it with node serveronly.
                                        Now there’s 0 errors so I have no clue why my screen still shows up black with npm start.
                                        • slametpsS
                                          Yap, it works like a charm now (also after I downgraded electron to 1.6.10 (1.7.9 consumes excessive CPU).
                                          Firstly, I got the same issue. After I did what I mentioned earlier, it is OK now.
                                          regards,
                                          Slamet PS
                                          • axellejamousA
                                            @slametps Yeah had to do the same! But I downgraded to 1.7.9, so I’ll change it to 1.6.10 now thank you! :)
