    How to MANUALLY install MM on your Pi. For absolute beginners.
    27 Posts 5 Posters 23.9k Views 5 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @fox
      @fox said in How to MANUALLY install MM on your Pi. For absolute beginners.:
      I’ll give it a try.
      You’re welcome. Let me know how you make out.
      • F
        fox
        Hi @Mykle1 i get this error when i make
        npm start
        Error:
        { Error: listen EADDRINUSE 0.0.0.0:8080
            at Object.exports._errnoException (util.js:1050:11)
            at exports._exceptionWithHostPort (util.js:1073:20)
            at Server.setupListenHandle [as _listen2] (net.js:1263:14)
            at listenInCluster (net.js:1304:12)
            at doListen (net.js:1428:7)
            at _combinedTickCallback (internal/process/next_tick.js:83:11)
            at process._tickCallback (internal/process/next_tick.js:104:9)
            at Module.runMain (module.js:607:11)
            at run (bootstrap_node.js:431:7)
            at startup (bootstrap_node.js:155:9)
          code: 'EADDRINUSE',
          errno: 'EADDRINUSE',
          syscall: 'listen',
          address: '0.0.0.0',
          port: 8080 }
        edit:
        with
        sudo netstat -lnptu
        i saw that electron.js is already using the port. But i have a blank screen and nothing is shown. Also rebooted a couple of times.
        Issues With MMM-WatchDog known?
        https://forum.magicmirror.builders/post/29827
        Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
        Mykle1M 1 Reply Last reply
        • Mykle1M
          Hmm, make sure you only have 1 terminal open when you run npm start from the pi@user/MagicMirror directory. Also, make sure the address: "0.0.0.0", entry in your config is OUTSIDE the whitelist. If you’re running pm2 make sure that is not launching an instance of MM. Otherwise, is there anything else that you changed after the install?
          • N
            noorm91
            How do you apply after each module you try out? Is there a way or do you have to reboot every time?
            • Mykle1M
              Mykle1 Project Sponsor Module Developer @noorm91
              @noorm91 said in How to MANUALLY install MM on your Pi. For absolute beginners.:
              You don’t have to reboot the Pi to launch MM after adding a module. Assuming you quit MM before you added the module, you simply launch MM as you normally would
              N 1 Reply Last reply
              • N
                noorm91 @Mykle1
                @Mykle1
                The MM autostarts when booting up the Pi, what’s the command you use to apply/run the config.js right after you save it?
                • Mykle1M
                  When the mirror is running, press your Alt key to drop down a menu bar. Choose Minimize from the Window menu. Assuming pm2 is autostarting for you, open a terminal and type pm2 stop mm to quit MM.
                  You can start MM after saving your config in the terminal by typing pm2 start mm, or if MM is still running, from the drop down menu, View, Reload
                  • F
                    fox
                    The problem was the module watchdog !
                    Also with fresh install it throws errors with the newest update.
                    Fixed for me. Thank you @Mykle1 !!!
                    Reply Quote 2
                    • axellejamousA
                      axellejamous
                      I don’t know if this is the right place for me to reply but I’m desperate.
                      I’m supposed to do a project for school with the MM but I can’t even seem to get it up and running.
                      I made an issue on the forum but so far I’ve gotten no replies :(
                      I followed these steps to reinstall the MM but instead of making my own config file I used the one provided. When I run it, the screen is black and I can see in dev tools that the “moment” npm package is having some issues but I can’t find any info anywhere on how to solve it or anyone that has a similar issue.
                      • Mykle1M
                        You’re welcome, mate.
                        • Mykle1M
                          Mykle1 Project Sponsor Module Developer @axellejamous
                          @axellejamous said in How to MANUALLY install MM on your Pi. For absolute beginners.:
                          I see that you have fixed your issue in another topic. Very good! Can I ask, are you saying you had this issue after a manual installation? The symptoms and fix you used are commonly associated with the automatic installer or version update. I’m just curious because I have not heard of this happening after a manual installation.
                          axellejamousA 1 Reply Last reply
                          • axellejamousA
                            axellejamous @Mykle1
                            @Mykle1
                            I did luckily!
                            I indeed had the issue after manual installation. Fact is, the automatic installation script would actually get stuck on two of my Pi’s at the node modules installation.
                            So I had to manually install.
                            In the issue that helped me find the answer, he did do a manual install as well and had the same problem.
                            But someone did mention “in the latest version there is a npm install task in the vendor folder as well which gets executed automatically after a successful install, yours wasn’t successful so this was never executed” which means I probably made a mistake in my manual installation, although I have no clue what it could’ve is as I followed the steps thoroughly on 2 different pi’s, getting the same result.
                            Mykle1M slametpsS 2 Replies Last reply
                            • Mykle1M
                              No sir, you made no mistake. You download the software and run npm install in the MagicMirror directory. If, and when that fails, it is no fault of yours.
                              I’m glad you solved your problem and thanks for the information. It’s good to know that in case anyone else encounters that problem with a manual installation.
                              Reply Quote 2
                              • slametpsS
                                slametps @axellejamous
                                @axellejamous I still got no luck making 2.1.3 works. the log said MM run without error. Unfortunately, got a black screen using default config.js (copy from config.js.sample). If I remove config.js, the MM display to create a config. Still no clue how to solve this.
                                regards,
                                Slamet PS
                                • Mykle1M
                                  Mykle1 Project Sponsor Module Developer @slametps
                                  @slametps said in How to MANUALLY install MM on your Pi. For absolute beginners.:
                                  You did a manual install and ran npm install in the MagicMirror directory? He solved his problem by running npm install in the vendor directory. I don’t know if you have the same issue.
                                  But it seems to me if MM is reporting “Create a config” that MM is launching correctly. You could try getting a fresh copy of the config.js.sample (in case something is wrong with the one you have) and trying again.
                                  Good luck
                                  slametpsS 1 Reply Last reply
                                  • slametpsS
                                    slametps @Mykle1
                                    @Mykle1 said in How to MANUALLY install MM on your Pi. For absolute beginners.:
                                    Good luck
                                    Yap, I just copy config.js from config.js.sample, and got a black screen.
                                    I will give a try, running npm install in vendor folder.
                                    regards,
                                    Slamet PS
                                    • Mykle1M
                                      @slametps
                                      You didn’t answer my question.
                                      You didn’t try my suggestion.
                                      You did the one thing that I said I didn’t know was your issue.
                                      Shrug
                                      • slametpsS
                                        slametps @Mykle1
                                        @slametps
                                        Shrug
                                        Yap, I install MM manually refers to documentation you wrote (and backed up current running MM 2.1.0).
                                        config. js I mentioned earlier, is a fresh copy from config.js.sample in config folder.
                                        I did npm-install in MM folder, but not in vendor yet. I’ll try later when I have access to my MM.
                                        regards,
                                        Slamet PS
                                        • slametpsS
                                          slametps @slametps
                                          @slametps
                                          Shrug
                                          Finally, MM 2.1.3 was installed successfully by executing:
                                          cd /root/MagicMirror/vendor
                                          npm install /root/MagicMirror
                                          cd /root/MagicMirror/fonts
                                          npm install
                                          regards,
                                          Slamet PS
                                          • axellejamousA
                                            axellejamous @slametps
                                            @slametps glad you found it! you basically had the same issue as me except I didn’t have the fonts one. It’s really odd.
