    MMM-Jarvis-Voice-Control
    27 Posts 10 Posters 31.9k Views 13 Watching
      merceaemil @r3z3
      @r3z3 Hy, I am happy that it works for you :)
      • aro28A
        aro28 @merceaemil
          merceaemil
          Hello
          Please reconfigure jarvis and change the hotword to something shorter. “Hello my friend!” is to long for your setup. Use something like “Ok Mirror”.
          The circle will show up after jarvis recognises the hot word. After Jarvis recognised that you said that hotword.
          Just like in the screen you shared it said that the hotword has to be between 0.5 and 1.5 speaking seconds.
          After you reconfigure the hotword tell me if it works.
          aro28A 1 Reply Last reply Reply Quote 0
          • aro28A
            aro28 @merceaemil
            @merceaemil
            I’ve changed hotword. But I cannot setup my microphone. I can configure either speakers or a microphone. it either asks to increase the signal or reduce during setup process.
            When I say something during Setup Wizard for speaker it passed successfully but when it asks me to be silent it can’t finish and says decrease microphone gain. Please advise
            Best,
            • aro28A
              aro28 @aro28
              @aro28
              I have builted microphone in my touch screen Monitor. Should I try another external USB microphone.
                merceaemil
                i think you should try another mic. one that works on usb… or maybe use a webcam which has a builtin mic.
                • aro28A
                  aro28 @merceaemil
                  @merceaemil
                  Ok. Thank you! Will do tomorrow.
                  • aro28A
                    aro28 @aro28
                    @aro28
                    Today i installed another mic thru the 3D sound card adapter and Setup Wizard has been completed successfully.
                    But MM is running without animated circle. Also, when i run Jarvis in troubleshooting mode, in the beginning it introduces itself and when i say something it’s just repeating my words
                    Should i configure something else? How do voice commands work here? I’m generally new to this.
                    Thank you in advance.
                    aro28A 1 Reply Last reply Reply Quote 1
                    • aro28A
                      aro28 @aro28
                      @aro28
                      Hi any updates on above?
                      What should to be installed first? MM or Jarvis?
                      Thanks!
                      • cowboysdudeC
                        Clean it all out and reinstalled it…was good until Microsoft wanted a CC to register… that’s a big fat noooooooooooooooo…so this voice software will not do… ;)
                        • N
                          nobita @merceaemil
                          @merceaemil
                          and to Anyone
                          How to Connect (Usage) Jarvis in Magic Mirror
                          such as How to open/close currentweather (Default module) ,
                          How to open/close clock (default module)
                          can you explain in detail becuase I,m Beginner
                          Thanks for your kind
                          • W
                            Waldehead
                            although this thread is quite old, I have a question.
                            Is it possible to display the inner circle (e.g. in blue) when Jarvis is in standby mode?
                            • A
                              aljosie @merceaemil
                              @merceaemil give me the example/tutorial how to create of code how to jarvis can control homedevice, because i was try and get some failed
                              • A
                                aljosie
                                Hallo @merceaemil i was installed the openjarvis plugin and mmm-jarvis-voice-control in my MM, but when i try to say anything the jarvis nothing to response, but when i say my hotword, jarvis can answer me, please help me.
