    MMM-Bergfex doesent load respectively should be a valid spdx license expression
    30 Posts 6 Posters 21.4k Views 6 Watching
    • G Offline
      gianienderlin
      to be honest, I don’t know what I’ve changed, too long ago. but it works for me
      • G Offline
        gianienderlin @gianienderlin
        oh sorry, i cant upload my files…
        Error
        You do not have enough privileges for this action
          marphi1602
          Has anybody solved the issue? I am facing also the “loading” issue. I was thinking of that a certain ski area doesn´t exist anymore, but I took only one (Hintertux) which is definitely open and listed on the web page… In case somebody solved the issue, please upload your files.
            astrakid
            not yet, i am waiting for the files of gianienderlin, then i can find out what is the fix.
            • G Offline
              gianienderlin
              here are my custom files. please let me know if they work.
              http://www.filehosting.org/file/details/705911/MMM-bergfex.zip
              M H 2 Replies Last reply Reply Quote 0
                astrakid
                @gianienderlin said in MMM-Bergfex doesent load respectively should be a valid spdx license expression:
                as far as i could see there is one main change in node_helper.js:
                instead of
                var sys = require(‘sys’);
                he uses
                var util = require(‘util’);
                regards,
                andre
                  marphi1602 @gianienderlin
                  @gianienderlin worked for me! The only thing what I´ve changed was the const in node_helper.js.
                  Due to the fact that I am more interested in seeing the results of the Austrian ski resorts I put // Constants
                  const URL = “http://www.bergfex.at/oesterreich/schneewerte/”;
                  Thank you!
                  • G Offline
                    gianienderlin
                    yes this is possible: -) but thought there was more…
                      marphi1602
                      anybody knows how I have to set ‘Kitzbühel - Kirchberg’ to the config? I think I am struggling with the “ü” same also for special characters like “-”… In case I am putting Kitzbühel into the config it says loading…
                        astrakid
                        @marphi1602 said in MMM-Bergfex doesent load respectively should be a valid spdx license expression:
                        it works for me without an issue. my config part:
                                                module: 'MMM-bergfex',
                                                position: 'top_right',
                                                classes: 'small dimmed',
                                                    updateInterval: 30*60*1000,
                                                    animationSpeed: 0,
                                                    header: 'Schneebericht',
                                                        skiareas: [
        'Fieberbrunn - Saalbach Hinterglemm Leogang',
        'Kitzbühel - Kirchberg',
                                                        shortenArea: 20,
                                                        cssclassrow: 'normal',
                                                        cssclassheader: 'bright'
                        edit: which ‘locale’ are you using? i have “C” configured except “LANGUAGE=” and “LC_ALL=”.
                        edit2: maybe you can try this (this is what is visible in the logfile): ‘Kitzbhel - Kirchberg’
                          marphi1602 @astrakid
                          @astrakid thanks! I checked the config once again and I’ve seen some odd ascii characters hence it hasn’t worked properly. Now it’s working!
                            marphi1602
                            Is there any chance to highlight this ski resort with the highest amount of fresh snow?
                            • H Offline
                              hermlam @gianienderlin
                              @gianienderlin @astrakid Even after copying these files, the problem stays: the only thing I see is the header and ‘_loading…’
                                marphi1602 @hermlam
                                @hermlam pls publish the bergfex part of your config. Are you looking for the snow results of Austria or Switzerland? I had to change the const to the Austrian snow result url, pls see the posts above. For the first step I would suggest to take only one ski resort in your Cfg.
                                  astrakid @marphi1602
                                  @marphi1602 highlightingwould need changes to the sourcecode.
                                    binderth
                                    I do have the same problem:
                                    To avoid some enconding Problems, I picked some oneword-places for start:
                                    			    animationSpeed: 0,
                                    				skiareas: [
                                    						// 'Zell am Ziller - Zilleral Arena',
                                    						// 'Gerlos - Zillertal Arena',
                                    						'Ischgl',
                                    						'Jungholz',
                                    				shortenArea: 20,
                                    like described in this thread (https://forum.magicmirror.builders/post/30795), I changed to var util = require(‘util’); in node_helper.js
                                    In my logs I get this:
                                    TypeError: Cannot read property 'parent' of undefined
                                        at Function.exports.update (/home/pi/MagicMirror/modules/MMM-bergfex/node_modules/cheerio/lib/parse.js:69:25)
                                        at module.exports (/home/pi/MagicMirror/modules/MMM-bergfex/node_modules/cheerio/lib/parse.js:19:11)
                                        at Function.exports.load (/home/pi/MagicMirror/modules/MMM-bergfex/node_modules/cheerio/lib/static.js:27:14)
                                        at Request._callback (/home/pi/MagicMirror/modules/MMM-bergfex/node_helper.js:43:19)
                                        at self.callback (/home/pi/MagicMirror/modules/MMM-bergfex/node_modules/request/request.js:186:22)
                                        at emitOne (events.js:96:13)
                                        at Request.emit (events.js:191:7)
                                        at Request.onRequestError (/home/pi/MagicMirror/modules/MMM-bergfex/node_modules/request/request.js:878:8)
                                        at ClientRequest.emit (events.js:191:7)
                                      marphi1602 @binderth
                                      @binderth are you sure that your pi is connected with the internet? I have seen the same error a couple of weeks ago and I noticed that my pi wasn’t connected with the www anymore. What’s happening in case you ping www.google.com from your pi? Are you using pm2? What’s in your pm2 log mm
                                        ReinerZ
                                          ReinerZ
                                            ReinerZ @astrakid
