    Problems with rss
    4 Posts 2 Posters 2.3k Views 2 Watching
      retroflex Project Sponsor Module Developer
      This is my first attempt at a module using a node_helper.js. My goal is to get an rss and output all rss items on the mirror. I have got the basics working, which is a function in node_helper.js which sends items over to the module js file:
      loadFeed: function(url) {
          var items = [];
          items.push( { title: 'test title', description: 'test description' } );
          this.sendSocketNotification('ITEMS', {
            items: items
      Output:
      But when I try to read and parse an rss, I get nothing… Code:
      const FeedMe = require('feedme');
      const http = require('http');
          var items = [];
          items.push( { title: 'before', description: 'before' } );
          http.get('http://www.npr.org/rss/rss.php?id=1001', (res) => {
            var parser = new FeedMe();
            parser.on('title', (title) => {
              items.push( { title: 'feedtitle', description: 'feedtitle' } );
            parser.on('item', (item) => {
              items.push( { title: 'feeditem', description: 'feeditem' } );
            res.pipe(parser);
          items.push( { title: 'after', description: 'after' } );
            items: items
      Output:
      “ls node_modules” show that both feedme and http is installed. No relevant errors in .pm2/logs/mm-error-0.log or mm-out-0.log.
      So I tried with another rss parser:
      const parser = require('rss-parser');
          var items = [];
          parser.parseURL('http://www.npr.org/rss/rss.php?id=1001', function(err, parsed) {
            parsed.feed.entries.forEach(function(entry) {
              items.push( { title: 'entrytitle', description: entry.title } );
            items: items
      Same output as above. No log errors. And rss-parser is installed in node_modules. Also this last code works fine in npm RunKit:
      https://runkit.com/embed/q4ucjhbbzpw3
      Any ideas what is failing? Or how to debug?
        A Former User @retroflex
        @retroflex I didn’t look inside deeply, but I think it might be caused by asynchronous problem.
        I suspect sendNotification is performed before parsing rss(item.push)
        Test it with console.log() before sendNotification and item pushing.
        R 1 Reply Last reply Reply Quote 2
          retroflex Project Sponsor Module Developer @Guest
          @Sean Thanks! Logging shows your suspicions were correct:
          MYMODULE Thu Nov 23 2017 09:43:15 GMT+0100 (CET): start of method
          MYMODULE Thu Nov 23 2017 09:43:15 GMT+0100 (CET): end of method
          MYMODULE Thu Nov 23 2017 09:43:16 GMT+0100 (CET): parsed an rss entry
          Now I will try to find out if the rss parsers have a finished callback and put the sendSocketNotifications in there…
            retroflex Project Sponsor Module Developer @retroflex
            To follow up… I got it to work by comparing parsed.feed.entries.length to the number of parsed entries, and when all entries were passed I called a callback that sent the notifications.
            I’m new to javascript so there’s still a lot to learn.
