    Npm start issues
    12 Posts 2 Posters 10.9k Views 1 Watching
      Coltjb45
      Errors after i try to run npm start in the terminal. I can’t figure out what to do from here?
      • cruunnerrC Offline
        cruunnerr
        have a screenshot of the errors? or just copy/paste the error messages.
        Where did u type npm start? u need to be in the MagicMirror Folder.
          Coltjb45
          magicmirror@2.1.3 start /home/pi/MagicMirror
          sh run-start.sh
          run-start.sh: 4: run-start.sh: electron: not found
          npm ERR! magicmirror@2.1.3 start: sh run-start.sh
          npm ERR! Exit status 127
          npm ERR!
          npm ERR! Failed at the magicmirror@2.1.3 start script.
          npm ERR! This is most likely a problem with the magicmirror package,
          npm ERR! not with npm itself.
          npm ERR! sh run-start.sh
          npm ERR! You can get their info via:
          npm ERR! npm owner ls magicmirror
          npm ERR! System Linux 4.9.59-v7+
          npm ERR! command “/usr/bin/nodejs” “/usr/bin/npm” “start”
          npm ERR! cwd /home/pi/MagicMirror
          npm ERR! node -v v4.8.2
          npm ERR! npm -v 1.4.21
          npm ERR! code ELIFECYCLE
          npm WARN This failure might be due to the use of legacy binary “node”
          npm WARN For further explanations, please read
          /usr/share/doc/nodejs/README.Debian
          npm ERR!
          npm ERR! Additional logging details can be found in:
          npm ERR! /home/pi/MagicMirror/npm-debug.log
          npm ERR! not ok code 0
            cruunnerr
            did you run npm install first? or did u use the automatic installer? Looks like there is no electron installed.
            maybe try to execute “DISPLAY=:0 nohup npm start &”
            But i need to say that i am no developer or programer or something like that. Just started to try understanding the whole stuff ^^
            So keep that i mind and before u crash something maybe u should wait for someone who got more ideas.
            for so long keep reading: https://www.google.de/search?client=safari&rls=en&q=run-start.sh:+4:+run-start.sh:+electron:+not+found&ie=UTF-8&oe=UTF-8&gfe_rd=cr&dcr=0&ei=Q9JDWuagJ6zBXqmvrKAI
              Coltjb45
              I’m just starting out too, that’s why I’m having problems. Lol
                cruunnerr
                hmm. which os did u use? is it a fresh install?
                I’m using stretch lite, but that needs more steps to install the MM.
                So i recommend to use a desktop version (with pixel) for the first.
                If u did, i would use this guide: https://forum.magicmirror.builders/topic/236/complete-setup-tutorial
                Or, if u would like to use a lite OS Version i would use this: https://github.com/MichMich/MagicMirror/wiki/Jessie-Lite-Installation-Guide
                Last one worked fine for me. It takes about 30-60 Minutes all in all to set up the Magic Mirror when i did it first time. Important is to read carefully and take the time u need for it ;)
                  Coltjb45
                  I used automatic installer. And the OS was the lite system that came with my raspberry
                    Coltjb45
                    I tried your first suggestion and this is what happened.
                    pi@raspberrypi:~/MagicMirror $ DISPLAY=:0 nohup npm start &
                    [1] 1854
                    pi@raspberrypi:~/MagicMirror $ #nohup: ignoring input and appending output to 'nohup.out
                      cruunnerr
                      that should be the reason, why u are running in trouble. With the lite version there are missing some packages, which u have to install manually.
                      i would delete the MagicMirror folder with “rmdir MagicMirror” and try to set it up again with using the second link i posted above.
                      Even better if u install a whole new OS on your SD-Card, 'cause i don’t know what stuff is installed there.
                        Coltjb45
                        It said failed to remove magic mirror
                          cruunnerr
                          try
                          rmdir /home/pi/MagicMirror
                          or maybe
                          sudo rmdir /home/pi/MagicMirror
                            Coltjb45
                            both didn’t work
