MM on Pi Zero creates some wierd issues. Wrong font, and modules not showing.
3 Posts 2 Posters 1.6k Views 2 Watching
  • 1 Offline
    17saiiqb
    So I managed to get MagicMirror on a Pi zero, following these instructions. However, I have some problems. I’ll start with the simplest.
    The font isn’t Roboto, I think maybe the font doesn’t work on Pi Zero? I’m not used to not having a GUI, so I don’t know how to fix it.
    Second problem is modules not showing. Only the default modules work. I found this. But I have no idea if it is related. If it is, how can I fix it? The module I want is https://github.com/YR/MMM-YrNow
    • 1 Offline
      17saiiqb
      Update: I managed to fix the font problem. It wasn’t installed by npm install for some reason. So I updated npm, and ran npm install, and it worked!
      I still can’t figure out the module thing though, can someone please help?
      S 1 Reply Last reply Jan 1, 2018, 1:11 PM Reply Quote 0
        strawberry 3.141 Project Sponsor Module Developer @17saiiqb
        @17saiiqb https://github.com/YR/MMM-YrNow/blob/master/MMM-YrNow.js#L57
        and https://github.com/YR/MMM-YrNow/blob/master/MMM-YrNow.js#L62 use arrow functions, which could be replaced with normal functions as the scope isn’t used in the function anyways.
        return this.list.points.filter(function(item) {
          item.precipitation.intensity > 0 && Date.parse(item.time) >= new Date().valueOf()})[0];
          item.precipitation.intensity === 0 && Date.parse(item.time) >= new Date().valueOf()})[0];
        https://github.com/YR/MMM-YrNow/blob/master/printf.js#L14
        return String(str).replace(RE_PRINTF, function(token) {
        not sure if … was also introduced in es6 or before https://github.com/YR/MMM-YrNow/blob/master/printf.js#L10
