    V2.2.X Updates
    Scheduled Pinned Locked Moved MagicMirror
    3 Posts 1 Posters 8.1k Views 1 Watching
    • MichMichM Offline
      MichMich
      https://github.com/MichMich/MagicMirror/releases/tag/v2.2.0
      [2.2.0] - 2018-01-01
      Note: This update uses new dependencies. Please update using the following command: git pull && npm install
      Changed
      • Calender week is now handled with a variable translation in order to move number language specific.
      • Reverted the Electron dependency back to 1.4.15 since newer version don’t seem to work on the Raspberry Pi very well.
      Added
      • Add option to use Nunjucks templates in modules. (See helloworld module as an example.)
      • Add Bulgarian translations for MagicMirror² and Alert module.
      • Add graceful shutdown of modules by calling stop function of each node_helper on SIGINT before exiting.
      • Link update subtext to Github diff of current version versus tracking branch.
      • Add Catalan translation.
      • Add ability to filter out newsfeed items based on prohibited words found in title (resolves #1071)
      • Add options to truncate description support of a feed in newsfeed module
      • Add reloadInterval option for particular feed in newsfeed module
      • Add no-cache entries of HTTP headers in newsfeed module (fetcher)
      • Add Czech translation.
      • Add option for decimal symbols other than the decimal point for temperature values in both default weather modules: WeatherForecast and CurrentWeather.
      Fixed
      • Fixed issue with calendar module showing more than maximumEntries allows
      • WeatherForecast and CurrentWeather are now using HTTPS instead of HTTP
      • Correcting translation for Indonesian language
      • Fix issue where calendar icons wouldn’t align correctly
      • MichMichM Offline
        MichMich
        https://github.com/MichMich/MagicMirror/releases/tag/V2.2.1
        [2.2.1] - 2018-01-01
        Fixed
        • Fixed linting errors.
        • MichMichM Offline
          MichMich
          https://github.com/MichMich/MagicMirror/tree/v2.2.2
          [2.2.2] - 2018-01-02
          Added
          • Add missing package-lock.json.
