    Modules doesn't show
    4 Posts 2 Posters 2.5k Views 1 Watching
    • G Offline
      gshimself
      Hi! I have problems that Currentweather and Weatherforecast has gone away.
      Via MM-Remote I can see that they are offline due to “This module was hidden by module_5_currentweather, it can not be shown.” and “This module was hidden by module_6_weatherforecast, it can not be shown.” and I can’t get it to show again.
      Any ideas what I could do? It has worked before.
      • bheplerB Offline
        bhepler Module Developer @gshimself
        @gshimself Can you post your config.js for us? Remember to use the markdown text and hide any API keys in your file.
        • G Offline
          gshimself @bhepler
          @bhepler Ofc, here you go!
           * MIT Licensed.
          var config = {
                  port: 8080,
                  address: "0.0.0.0",
                  ipWhitelist: [  "192.168.1.1/24",
                                  "::fff:192.168.1.1/112",
                                  "127.0.0.1",
                                  "::ffff:127.0.0.1",
                                  "::1",
                                  "0.0.0.0",
                                  "192.168.1.22"
                               ], // Set [] to allow all IP addresses.
                  language: "sv",
                  timeFormat: 24,
                  units: "metric",
                                  module: "alert",
                                  module: "updatenotification",
                                  position: "top_bar"
                                  module: "clock",
                                  position: "top_left"
                                  header: "Min Kalender",
                                          colored: "true",
                                                          symbol: "calendar-check-o ",
                                                          url: "A-SUPER-SECRET-URL"
                                  module: "compliments",
                                  position: "lower_third"
                                  module: "currentweather",
                                          locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
                                          appid: "A-SUPER-SECRET-API"
                                  module: "weatherforecast",
                                  header: "Weather Forecast",
                                          colored: "true",
                                  module: "newsfeed",
                                  position: "bottom_bar",
                                          feeds: [
                                                          title: "VK",
                                                          url: "http://www.vk.se/feed"
                                                          title: "Expressen",
                                                          url: "http://expressen.se/rss/nyheter"
                                                          //encoding: "ISO-8859-1",
                                                          title: "Krisinformation.se",
                                                          url: "https://www.krisinformation.se/nyheter/nyheter-som-rss",
                                          showSourceTitle: true,
                                          showPublishDate: true
          // EGNA MODULER NEDAN
          // Remote-Control
              module: 'MMM-Remote-Control'
              // , position: 'bottom_left'
          // mmm-weatherchart
                  module: 'mmm-weatherchart',
                  position: 'bottom_center', // this can be any of the regions
                          country: 'Sverige', // as determined above
                          area: 'Västerbotten', // as determined above
                          city: '****', // as determined above
                          updateInterval: 60 * 60 * 1000, // update every hour
                          hideBorder: true, // whether or not a border with city name should be shown
          // SKRIV INGET NEDANFÖR
          • G Offline
            gshimself @gshimself
            Just fyi, the “location” under module currentweather is within quote marks (") but I done goofed when I did “****” instead of my real location
