    MMM-Bergfex doesent load respectively should be a valid spdx license expression
    30 Posts 6 Posters 21.7k Views 6 Watching
      marphi1602 @hermlam
      @hermlam pls publish the bergfex part of your config. Are you looking for the snow results of Austria or Switzerland? I had to change the const to the Austrian snow result url, pls see the posts above. For the first step I would suggest to take only one ski resort in your Cfg.
        astrakid @marphi1602
        @marphi1602 highlightingwould need changes to the sourcecode.
          binderth
          I do have the same problem:
          To avoid some enconding Problems, I picked some oneword-places for start:
          			module: 'MMM-bergfex',
          			position: 'top_right',
          			classes: 'small dimmed',
          			    updateInterval: 30*60*1000,
          			    animationSpeed: 0,
          			    header: 'Schneebericht',
          				skiareas: [
          						// 'Zell am Ziller - Zilleral Arena',
          						// 'Gerlos - Zillertal Arena',
          						'Ischgl',
          						'Jungholz',
          				shortenArea: 20,
          				cssclassrow: 'normal',
          				cssclassheader: 'bright'
          like described in this thread (https://forum.magicmirror.builders/post/30795), I changed to var util = require(‘util’); in node_helper.js
          In my logs I get this:
          TypeError: Cannot read property 'parent' of undefined
              at Function.exports.update (/home/pi/MagicMirror/modules/MMM-bergfex/node_modules/cheerio/lib/parse.js:69:25)
              at module.exports (/home/pi/MagicMirror/modules/MMM-bergfex/node_modules/cheerio/lib/parse.js:19:11)
              at Function.exports.load (/home/pi/MagicMirror/modules/MMM-bergfex/node_modules/cheerio/lib/static.js:27:14)
              at Request._callback (/home/pi/MagicMirror/modules/MMM-bergfex/node_helper.js:43:19)
              at self.callback (/home/pi/MagicMirror/modules/MMM-bergfex/node_modules/request/request.js:186:22)
              at emitOne (events.js:96:13)
              at Request.emit (events.js:191:7)
              at Request.onRequestError (/home/pi/MagicMirror/modules/MMM-bergfex/node_modules/request/request.js:878:8)
              at ClientRequest.emit (events.js:191:7)
            marphi1602 @binderth
            @binderth are you sure that your pi is connected with the internet? I have seen the same error a couple of weeks ago and I noticed that my pi wasn’t connected with the www anymore. What’s happening in case you ping www.google.com from your pi? Are you using pm2? What’s in your pm2 log mm
              ReinerZ
                ReinerZ
                  ReinerZ @astrakid
                    binderth
                    strange. I thought i had replied to this already…
                    1. my Pi is connected (I’m getting info for every other module quite right!)
                    2. I’m using pm2
                    3. I just upgraded to 2.2 (in case that matters now - same Output though)
                    4. my pm2 log mm reads:
                    pi@MagicMirror2:~/MagicMirror $ pm2 log mm
                    [TAILING] Tailing last 15 lines for [mm] process (change the value with --lines option)
                    /home/pi/.pm2/logs/mm-error-0.log last 15 lines:
                    0|mm       | there was a Wunderlist problem { error:
                    0|mm       |    { type: 'server_error',
                    0|mm       |      translation_key: 'api_error_unknown',
                    0|mm       |      message: 'An unknown server error occurred' } } 500
                    0|mm       | (node:931) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 message listeners added. Use emitter.setMaxListeners() to increase limit
                    0|mm       | SyntaxError: Unexpected end of JSON input
                    0|mm       |     at JSON.parse ()
                    0|mm       |     at Class.loadLogs (/home/pi/MagicMirror/modules/MMM-syslog/node_helper.js:60:21)
                    0|mm       |     at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-syslog/node_helper.js:45:9)
                    0|mm       |     at Socket. (/home/pi/MagicMirror/modules/node_modules/node_helper/index.js:113:11)
                    0|mm       |     at emitTwo (events.js:106:13)
                    0|mm       |     at Socket.emit (events.js:194:7)
                    0|mm       |     at /home/pi/MagicMirror/node_modules/socket.io/lib/socket.js:514:12
                    0|mm       |     at _combinedTickCallback (internal/process/next_tick.js:73:7)
                    0|mm       |     at process._tickCallback (internal/process/next_tick.js:104:9)
                    /home/pi/.pm2/logs/mm-out-0.log last 15 lines:
                    0|mm       | 1 snow reports from bergfex.at retrieved.
                    0|mm       | searching for Zell am Ziller - Zillertal Arena
                    0|mm       | searching for Gerlos - Zillertal Arena
                    0|mm       | searching for Hintertuxer Gletscher / Hintertux
                    0|mm       | Whoops! There was an uncaught exception...
                    0|mm       | MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                    0|mm       | If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                    0|mm       | Starting access to FRITZ!Box...
                    0|mm       | retrieveAndUpdate()
                    0|mm       | Use existing news fetcher for url: http://rss.sueddeutsche.de/rss/Topthemen
                    0|mm       | Access to FRITZ!Box finished.
                    (wunderlist and syslog working just fine - despite those Errors?)
                    but still:
                      @binderth what’s happening in case you would disable the whole wunderlist module and restart mm again?
                        binderth @marphi1602
                        @marphi1602
                        tried this one! :) - just reinstalled the whole 2.2.2 Version and now I don’t get any Errors:
                        pi@MagicMirror2:~ $ pm2 logs
                        /home/pi/.pm2/pm2.log last 15 lines:
                        PM2        | 2018-01-12 18:39:38: Current arch         : arm
                        PM2        | 2018-01-12 18:39:38: PM2 home             : /home/pi/.pm2
                        PM2        | 2018-01-12 18:39:38: PM2 PID file         : /home/pi/.pm2/pm2.pid
                        PM2        | 2018-01-12 18:39:38: RPC socket file      : /home/pi/.pm2/rpc.sock
                        PM2        | 2018-01-12 18:39:38: BUS socket file      : /home/pi/.pm2/pub.sock
                        PM2        | 2018-01-12 18:39:38: Application log path : /home/pi/.pm2/logs
                        PM2        | 2018-01-12 18:39:38: Process dump file    : /home/pi/.pm2/dump.pm2
                        PM2        | 2018-01-12 18:39:38: Concurrent actions   : 2
                        PM2        | 2018-01-12 18:39:38: SIGTERM timeout      : 1600
                        PM2        | 2018-01-12 18:39:38: ===============================================================================
                        PM2        | 2018-01-12 18:39:38: Starting execution sequence in -fork mode- for app name:mm id:0
                        PM2        | 2018-01-12 18:39:38: [Watch] Start watching MagicMirror
                        PM2        | 2018-01-12 18:39:38: Starting execution sequence in -fork mode- for app name:MagicMirror id:1
                        PM2        | 2018-01-12 18:39:39: App name:mm id:0 online
                        PM2        | 2018-01-12 18:39:39: App name:MagicMirror id:1 online
                        /home/pi/.pm2/logs/MagicMirror-error-1.log last 15 lines:
                        1|MagicMir | (node:965) DeprecationWarning: sys is deprecated. Use util instead.
                        0|mm       |     at Object.exports._errnoException (util.js:1026:11)
                        0|mm       |     at exports._exceptionWithHostPort (util.js:1049:20)
                        0|mm       |     at Server._listen2 (net.js:1253:14)
                        0|mm       |     at listen (net.js:1289:10)
                        0|mm       |     at net.js:1399:9
                        0|mm       |     at _combinedTickCallback (internal/process/next_tick.js:77:11)
                        0|mm       |     at process._tickCallback (internal/process/next_tick.js:98:9)
                        0|mm       |     at Module.runMain (module.js:592:11)
                        0|mm       |     at run (bootstrap_node.js:402:7)
                        0|mm       |     at startup (bootstrap_node.js:157:9)
                        0|mm       |   code: 'EADDRINUSE',
                        0|mm       |   errno: 'EADDRINUSE',
                        0|mm       |   syscall: 'listen',
                        0|mm       |   address: '0.0.0.0',
                        0|mm       |   port: 8080 }
                        0|mm       | Connecting socket for: MMM-FRITZ-Box-Callmonitor
                        0|mm       | Starting module: MMM-FRITZ-Box-Callmonitor
                        0|mm       | Connecting socket for: MMM-DWD-WarnWeather
                        0|mm       | MMM-DWD-WarnWeather helper started...
                        0|mm       | Connecting socket for: MMM-mqtt
                        0|mm       | MMM-mqtt started ...
                        0|mm       | Connecting socket for: MMM-bergfex
                        0|mm       | Starting node helper: MMM-bergfex
                        0|mm       | Connecting socket for: newsfeed
                        0|mm       | Starting module: newsfeed
                        0|mm       | Sockets connected & modules started ...
                        0|mm       | Launching application.
                        /home/pi/.pm2/logs/MagicMirror-out-1.log last 15 lines:
                        1|MagicMir | Create new news fetcher for url: http://rss.sueddeutsche.de/rss/Topthemen - Interval: 300000
                        1|MagicMir | 1 snow reports from bergfex.at retrieved.
                        1|MagicMir | searching for Zell am Ziller - Zillertal Arena
                        1|MagicMir | searching for Gerlos - Zillertal Arena
                        1|MagicMir | searching for Hintertuxer Gletscher / Hintertux
                        1|MagicMir | Access to FRITZ!Box finished.
                        1|MagicMir | No log file found.
                        1|MagicMir | Starting access to FRITZ!Box...
                        1|MagicMir | retrieveAndUpdate()
                        1|MagicMir | Use existing news fetcher for url: http://rss.sueddeutsche.de/rss/Topthemen
                        still - I get “1 snow reports from bergfex.at retrieved.” - but none show up…
                        PS: I always get the EADDRINUSE error, if I do pm2 restart mm.
                          @binderth mhhh are you sure that no other mm instance is parallel running or an additional app is also listening on the same port?
                          Kill all other pm instances before - pm2 delete all
                          Try the following and put only the bergfex module to your config and post your config.
                            @marphi1602
                            yes, I’m sure no other is running.
                            Got it figured out - after some debugging in node_helper.js I figured, it was strange, that I only found “1 sno report” - and after some annoying reloads (I’m not a developer, not to speak of JS), I found the only one issue for mmm-bergfex on github:
                            https://github.com/nebulx29/MMM-bergfex/issues/1#issuecomment-355083367
                            9days ago, Rainer added not only the deprecated “sys -> util” has to be changed, but also the “tbody var” - that did the trick for me! it worked!!
                            tl:dr>
                            1. add “private”: true, after “license”: “Apache 2.0”, inside package.json to avoid the license problem
                            2. change inside node_helper.js
                            var sys = require('sys'); to
                            //var sys = require('sys');
                            var util = require('util');
                            1. change inside node_helper.js
                            var tbody = $('.content').children().last(); to
                            var tbody = $('.content>table').children().last();
                              binderth @binderth
                              @binderth said in MMM-Bergfex doesent load respectively should be a valid spdx license expression:
                              I’m not so sure anymore! ;)
                              When I reinstalled MagicMirror2 from scratch, it seems, pm2 added another instance called “MagicMirror” - so I got two running - but that is another issue I’m currently working on - perhaps coming back to the Forum in a new thread.
