    Arcade button to turn on/off monitor
    6 Posts 5 Posters 2.5k Views 5 Watching
    • H
      HandyDandy
      I’ve been using the PIR sensor module to have my monitor turn on/off for a while now. But I’ve always been frustrated weird sensitivity of the sensor; sometimes it works perfectly, other times it continues to detect movement despite there being none. I’m looking for a way to allow inputs from an arcade button (I got one of these https://www.adafruit.com/product/917) to toggle the monitor now for better consistency.
      Any help appreciated, I am totally clueless in terms of coding except fiddling around with settings.
      ? 1 Reply Last reply
        A Former User @HandyDandy
        @HandyDandy You can modify MMM-BUTTON for that purpose.
        • H
          HandyDandy
          Ooo really? Thanks for pointing that out, I took a glimpse over that module and I thought it only included switches done via PC/phone. I’ll take a more careful look thanks!
            robmcc83
            How would I use mmm-button to achieve this?
            Cheers
            N 1 Reply Last reply
            • N
              ninjabreadman @robmcc83
              @robmcc83 Start with the README.md (link) and then follow the “How to connect a button” link for a hardware walkthrough. Once you’ve carefully followed the walkthrough, configuration should be straightforward.
                doubleT Module Developer
                As for the PIR sensitivity, that can usually be adjusted.
