    Sync private iCloud calendar with MagicMirror
    162 Posts 58 Posters 423.5k Views 65 Watching
    • G Offline
      Gailby @Beh
      @Beh Everything works fine until I’ll try to save the config file:
      1. ~/.vdirsyncer/config directory cannot be found
      2. Once I manuals create directories I also save config file as config.cfg and also tried config.config and save
      3. I haven’t filled in collections = [“HERE-GOES-THE-UUID-OF-THE-CALENDAR-YOU-WANT-TO-SYNC”] in conf. Could this make it crash?
      4. Running curl for timer ok.
        5.Then when vdirsyncer discover nothing happens I get Errno 21 and that’s where I get stuck…
      Really wonder what might be the issues here?
      • G Offline
        ganther @Gailby
        @Gailby
        The file is named config. It‘s not a directory, it‘s the name of the file. (No ending).
        • G Offline
          Gailby @ganther
          @ganther so if I put config in ~/.vdirsyncer/config it should work?
          I think I did try it but somehow wansn’t able to read it as a file nor save and getting empty file and no result forward…
          • G Offline
            ganther @Gailby
            @Gailby
            Yes. Just type these commands as given:
            touch ~/.vdirsyncer/config
            nano ~/.vdirsyncer/config
            • schwoediauerS Offline
              schwoediauer @l0cal
              @l0cal Hi !
              I’m also interrested on this solution to display reminders on this way, but It dosen’t work actually for me.
              Do you have a running configuration
                maestro82
                Two run two calendars, would I need to adjust config.js file as well?
                • G Offline
                  Gailby @Beh
                  @Beh I had no problem adding several modules of same kind and several .ics files in Calendars…however it doesn’t seem to sync or retrieve anything…only says no upcomming events :/
                  • G Offline
                    ganther @Gailby
                    @Gailby
                    Is your ics-file in modules/calendars also 0kb?
                    • G Offline
                      Gailby @ganther
                      @ganther I don’t know…I need to check
                      • G Offline
                        Gailby
                        Doesn’t seem like they are empty in KB. However the first file has rw–r–r-- and the others only rw------ don’t know if these permissions affects the none fetching of data
                          maestro82 @maestro82
                          @maestro82 So I was able to get through the tutorial with no errors, all files discovered and synced. But when I run MagicMirror calendar says “Loading…” and never loads. I have changed interval to 5min in timer file. Any advise to troubleshoot?
                          Thanks,
                          • G Offline
                            Gailby @Gailby
                            @Gailby @ganther @Beh the ics files doesn’t seem to sync in Calendars… all files are empty. Have anyone resolved this?
                              Beh
                              Hey Guys, I’m sorry I can’t help you right now.
                              I currently have my examination period at my university. So I’m super busy right now… I’ll be able to help in a week or so…
                              • G Offline
                                ganther
                                @Gailby no, same behavior here.
                                @beh Thank you and good luck for your exams.
                                  Solved this issue by using “http:” not “https:” in calendar url but now my calendar shows no events. I looked into the actual “modules/calendars/****.ics” file and it contains multiple events. Any suggestions?
                                  • G Offline
                                    ganther @maestro82
                                    @maestro82
                                    Did you check your calendar-url in conf/config.js?
                                    My calendar is running now correctly. Don‘t know why but now my ics-file isn‘t empty anymore.
                                      maestro82
                                      So . . . . . . restarted the mirror and now it works. Moving on to adding other calendars, wish us luck.
                                        maestro82
                                        So I have three separate calendars linked to ical, running on my magic mirror. I see events from all three calendars, but many events are missing. Any ideas?
                                        • E Offline
                                          E3V3A @maestro82
                                          @maestro82 said in Sync private iCloud calendar with MagicMirror:
                                          You are probably limiting the number of calendar items shown in your calendar config. (IDK what is the default, but perhaps only 10-15 which for 3 cals can be easily overloaded.)
                                          “Everything I do (here) is for free – altruism is the way!”
                                            maestro82 @E3V3A
                                            I have several reoccurring events on the same day, only one of each event is showing up. The number of events is set at 10 but it is going out at least 4 months with that set. It should only go out about 3 weeks with 10 events listed. I’ll try raising the number of events and limiting the time.
                                            • 3 / 9
