    Sync private iCloud calendar with MagicMirror
    162 Posts 58 Posters 446.0k Views 65 Watching
      maestro82
      So . . . . . . restarted the mirror and now it works. Moving on to adding other calendars, wish us luck.
        maestro82
        So I have three separate calendars linked to ical, running on my magic mirror. I see events from all three calendars, but many events are missing. Any ideas?
        E 1 Reply Last reply
        • E
          E3V3A @maestro82
          @maestro82 said in Sync private iCloud calendar with MagicMirror:
          You are probably limiting the number of calendar items shown in your calendar config. (IDK what is the default, but perhaps only 10-15 which for 3 cals can be easily overloaded.)
          “Everything I do (here) is for free – altruism is the way!”
          M 1 Reply Last reply
            maestro82 @E3V3A
            I have several reoccurring events on the same day, only one of each event is showing up. The number of events is set at 10 but it is going out at least 4 months with that set. It should only go out about 3 weeks with 10 events listed. I’ll try raising the number of events and limiting the time.
              paddyhughes
              P 1 Reply Last reply
                paddyhughes @paddyhughes
                  paddyhughes
                  Hi
                  So i am getting stuck with this and don’t know how to fix the issue.
                  The UUID is beside my Calendar and in my iCloud this is my default one.
                  but the one i want to use is home (Home Calendar) but No UUID shows up
                  same goes for the work one.
                  The only one i am interested in is the Home Calendar
                  pi@raspberrypi:~/MagicMirror $ vdirsyncer discover
                  Discovering collections for pair iCloud_to_MagicMirror
                  Mirror:
                  iCloud:
                    - "tasks" ("Reminders")
                    - "AE********-E**4-4D**-A**4-*****************" ("Calendar")
                    - "home" ("Home Calendar")
                    - "work" ("Work")
                  warning: No collection "HERE-GOES-THE-UUID-OF-THE-CALENDAR-YOU-WANT-TO-SYNC" found for storage Mirror.
                  Should vdirsyncer attempt to create it? [y/N]:
                  Thanks for any help given :)
                    Last issue resolved
                    So my issue not really an issue just me expecting something different than what i got when i ran vdirsyncer discovery
                    So the example on page 1 looks like this
                    Mirror:
                    iCloud:
                      - "25CB285C-E163-4E0E-B420-C3FB469B7C00" ("Calendar 1")
                      - "9221FEE8-E8B4-4D07-9402-8638529919EC" ("Calendar 2")
                      - "953A5477-E405-4ED6-A5C3-473444EACC95" ("Calendar 3")
                    warning: No collection "9221FEE8-E8B4-4D07-9402-8638529919EC" found for storage Mirror.
                    With all the Calendars having a string for UUID E.G. 9221FEE8-E8B4-4D07-9402-8638529919EC
                    And this is what i got
                    Mirror:
                    iCloud:
                      - "9221FEE8-E8B4-4D07-9402-8638529919EC" ("Calendar")
                      - "work" ("Work")
                    Now what i didn’t know was that i did get a return of UUID for each Calendar
                    (Reminders) UUID is "tasks"
                    (Calendar) UUID is "9221FEE8-E8B4-4D07-9402-8638529919EC"
                    (Home Calendar) UUID is "home"
                    Hope this helps other people in the future.
                    took me a bit of digging around.
                      maestro82
                      paddyhughes,
                      Had the exact same issue.
                      Had one calendar called “worK”, all the rest had the long UUID names.
                      I keep looking for the “work” calendar, of course it’s UUID was “work”.
                      Put that in and now it works.
                      Some lessons are learned the hard way.
                      Maestro-82
                        paddyhughes @maestro82
                        Ya kept thinking I did something wrong set up 3 different Rpi thinking I did something some were in the code to mess up. Finally got it working ;)
                        paddyhughes,
                        Maestro-82
                          Devert
                          Have any1 made a video how to set it up, I have some problems? :-D
                            paddyhughes @Devert
                            Hi what’s the issue
                            @Devert
                            • F
                              Fenis
                              I saw someone back on page 1 getting this error but not a solution:
                              File “/usr/bin/vdirsyncer”, line 7, in
                              from vdirsyncer.cli import main
                              ImportError: No module named ‘vdirsyncer’
                              In answer to the reply of if I added python3 to the executable, I already have.
                              • F
                                Fenis @Doubleve
                                @Doubleve How did you fix this issue? I’m getting the same error.
                                  dylanje
                                  Thanks for the tutorial, this is incredibly helpful.
                                  I’m to the point where my MagicMirror displays events from my Home calendar, but it seems that vdirsyncer.timer is not actually working. When I run systemctl --user enable vdirsyncer.timer the console doesn’t output any errors and just returns to a new line. I never see any updates to events on the calendar if I remove/add.
                                  I’ve modified the timer settings, and changed a few settings on the MagicMirror side as well but the only way I can get the .ics files to update is if I manually run vdirsyncer sync. I’ve ready through the docs over here: https://vdirsyncer.pimutils.org/en/stable/index.html but there really isn’t any useful information about the timer.
                                  Any thoughts or leads to finding an answer?
                                  • MarosM
                                    Maros
                                    Hi all,
                                    i’m trying to prepare everything on SW site before i start building MM and i have almost everything except birthdays … :(
                                    i’m using iCloud to store my contacts birthdays but i’m not able to find way how to import them to calendar module on MM2
                                    i’ve found and installed this module :
                                    MMM-iCloud-Client
                                    i’ve installed it and also dependecies :
                                    npm install ical-generator
                                    npm install icloud
                                    npm install nedb --save
                                    in config/config.js i’ve updated entry with
                                    module: ‘MMM-iCloud-Client’,
                                    username: “appleID”,
                                    password: “password”,
                                    countrycode: “49”,
                                    also i’ve edited modules/default/calendar/calendar.js and added this code to it (below US-Holidays.ics …entry) :
                                    symbol: ‘birthday-cake’,
                                    url: ‘http://localhost:8080/MMM-iCloud-Client/birthdays’,
                                    but it’s still not showing any birthday even if upcomming are in 2 days.
                                    Can someone help me what i’m doing wrong ?
                                    Thank you
                                    • MarosM
                                      Maros
                                      noone ? i realy want to see upcomming birthday but i’m not able to get it work
                                      • MarosM
                                        Maros
                                        i’ve tried to remove module MMM-iCloud-Client
                                        (rm -rf MMM-iCloud-Client in modules dir)
                                        then i’ve installed it from beginning as written in Readme
                                        when i’ve executed “npm install” in MMM-iCloud-Client directory i get this information :
                                        /MagicMirror/modules/MMM-iCloud-Client $ npm install
                                        npm WARN deprecated node-uuid@1.4.8: Use uuid module instead
                                        npm notice created a lockfile as package-lock.json. You should commit this file.
                                        added 59 packages from 71 contributors and audited 74 packages in 14.839s
                                        found 1 low severity vulnerability
                                        run npm audit fix to fix them, or npm audit for details
                                        i’ve executed “npm audit” and error is according lodash
                                        i’ve tried also “npm audit fix” but i get
                                        i’ve searched and tried to install lodash manually by “npm install lodash”
                                        /MagicMirror/modules/MMM-iCloud-Client $ npm install lodash
                                        • lodash@4.17.10
                                          updated 1 package and audited 74 packages in 7.673s
                                        can someone help ? I’m not sure if this is root cause why Birthday is not working as it should but this is the only error i can see.
                                        • MarosM
                                          Maros
                                          Or is there any posibility how to add birthday ? Google calendar maybe?
                                          justjim1220J 1 Reply Last reply
                                          • justjim1220J
                                            justjim1220 Module Developer @Maros
                                            @maros
                                            there is a default calendar module that automatically came with MM2
                                            And there are others, I personally like MMM-CalendarExt.
                                            Jim Hallock - 1995
                                            • 3 / 9
