    Sync private iCloud calendar with MagicMirror
    162 Posts 58 Posters 445.5k Views 65 Watching
      paddyhughes @maestro82
      Ya kept thinking I did something wrong set up 3 different Rpi thinking I did something some were in the code to mess up. Finally got it working ;)
      @maestro82 said in Sync private iCloud calendar with MagicMirror:
      paddyhughes,
      Had the exact same issue.
      Had one calendar called “worK”, all the rest had the long UUID names.
      I keep looking for the “work” calendar, of course it’s UUID was “work”.
      Put that in and now it works.
      Some lessons are learned the hard way.
      Maestro-82
        Devert
        Have any1 made a video how to set it up, I have some problems? :-D
        P 1 Reply Last reply
          paddyhughes @Devert
          Hi what’s the issue
          @Devert
          • F
            Fenis
            I saw someone back on page 1 getting this error but not a solution:
            File “/usr/bin/vdirsyncer”, line 7, in
            from vdirsyncer.cli import main
            ImportError: No module named ‘vdirsyncer’
            In answer to the reply of if I added python3 to the executable, I already have.
            • F
              Fenis @Doubleve
              @Doubleve How did you fix this issue? I’m getting the same error.
                dylanje
                Thanks for the tutorial, this is incredibly helpful.
                I’m to the point where my MagicMirror displays events from my Home calendar, but it seems that vdirsyncer.timer is not actually working. When I run systemctl --user enable vdirsyncer.timer the console doesn’t output any errors and just returns to a new line. I never see any updates to events on the calendar if I remove/add.
                I’ve modified the timer settings, and changed a few settings on the MagicMirror side as well but the only way I can get the .ics files to update is if I manually run vdirsyncer sync. I’ve ready through the docs over here: https://vdirsyncer.pimutils.org/en/stable/index.html but there really isn’t any useful information about the timer.
                Any thoughts or leads to finding an answer?
                • MarosM
                  Maros
                  Hi all,
                  i’m trying to prepare everything on SW site before i start building MM and i have almost everything except birthdays … :(
                  i’m using iCloud to store my contacts birthdays but i’m not able to find way how to import them to calendar module on MM2
                  i’ve found and installed this module :
                  MMM-iCloud-Client
                  i’ve installed it and also dependecies :
                  npm install ical-generator
                  npm install icloud
                  npm install nedb --save
                  in config/config.js i’ve updated entry with
                  module: ‘MMM-iCloud-Client’,
                  username: “appleID”,
                  password: “password”,
                  countrycode: “49”,
                  also i’ve edited modules/default/calendar/calendar.js and added this code to it (below US-Holidays.ics …entry) :
                  symbol: ‘birthday-cake’,
                  url: ‘http://localhost:8080/MMM-iCloud-Client/birthdays’,
                  but it’s still not showing any birthday even if upcomming are in 2 days.
                  Can someone help me what i’m doing wrong ?
                  Thank you
                  • MarosM
                    Maros
                    noone ? i realy want to see upcomming birthday but i’m not able to get it work
                    • MarosM
                      Maros
                      i’ve tried to remove module MMM-iCloud-Client
                      (rm -rf MMM-iCloud-Client in modules dir)
                      then i’ve installed it from beginning as written in Readme
                      when i’ve executed “npm install” in MMM-iCloud-Client directory i get this information :
                      /MagicMirror/modules/MMM-iCloud-Client $ npm install
                      npm WARN deprecated node-uuid@1.4.8: Use uuid module instead
                      npm notice created a lockfile as package-lock.json. You should commit this file.
                      added 59 packages from 71 contributors and audited 74 packages in 14.839s
                      found 1 low severity vulnerability
                      run npm audit fix to fix them, or npm audit for details
                      i’ve executed “npm audit” and error is according lodash
                      i’ve tried also “npm audit fix” but i get
                      i’ve searched and tried to install lodash manually by “npm install lodash”
                      /MagicMirror/modules/MMM-iCloud-Client $ npm install lodash
                      • lodash@4.17.10
                        updated 1 package and audited 74 packages in 7.673s
                      can someone help ? I’m not sure if this is root cause why Birthday is not working as it should but this is the only error i can see.
                      • MarosM
                        Maros
                        Or is there any posibility how to add birthday ? Google calendar maybe?
                        justjim1220J 1 Reply Last reply
                        • justjim1220J
                          justjim1220 Module Developer @Maros
                          @maros
                          there is a default calendar module that automatically came with MM2
                          And there are others, I personally like MMM-CalendarExt.
                          Jim Hallock - 1995
                          • MarosM
                            Maros
                            Yes but is there possibility to add birthday calendar ?
                            Icloud or google ?
                            justjim1220J AlbinolanA 3 Replies Last reply
                            • justjim1220J
                              @maros
                              I work mainly with Google, I haven’t personally used iCloud. Have also worked with Yahoo and Hotmail. Google is my favorite…
                              This is my list of calendars:
                              And, this is how I put into my calendar module…
                              "calendars": [
                                  "name": "Family Stuff",
                                  "symbol": "heart@fa",
                                  "url": "Calendar link here",
                                  "interval": 24*60*60*1000
                                  "name": "US Holiday",
                                  "symbol": "gift@fa",
                                  "interval": 24*60*60*1000,
                                  "maxEntries": 50, "maxDays":365
                                   "name": "Birthdays",
                                   "symbol": "birthday-cake",
                                // "name": "KC Chiefs",
                                   "symbol": "football-ball@fa",
                                   "name": "NFL Games",
                                   "name": "NFL Playoff Games",
                              Jim Hallock - 1995
                              AlbinolanA 1 Reply Last reply
                              • AlbinolanA
                                Albinolan @justjim1220
                                @justjim1220 We are all able to do that, to clarify the issue. The objective is to find a way to use an iCloud calendar without having a public url, which is what your google calendar is currently using. By using a public URL, web crawlers are able to find and read your calendar events.
                                • AlbinolanA
                                  Albinolan @Maros
                                  @maros you can add the bday calendar in the default calendar module by making your iCloud calendar public (tick the box circled in this screenshot), and you should be given a link that you can copy into the config file.
                                  If you want to use google calendars, it should be similar. Just look up how to publicly share a google calendar, and get the link from there to put into your config.
                                  • AlbinolanA
                                    Albinolan @Maros
                                    @maros One problem (which this thread was originally trying to solve) was the inability to prevent others from accessing the calendar. If a web crawler can find your link, they too will be able to read your calendar.
                                    • MarosM
                                      Maros
                                      @Albinolan but in icloud calendar Birthday calendar have not option to public.
                                      it’s marked as others
                                      @justjim1220 i’ve tried also this in gmail i’ve copied url for birthday calendar (public url to this calendar) and add it to my calendar module
                                      symbol: “calendar”,
                                      url: “https://calendar.google.com/calendar/xxxxxxxxxxxx”
                                      but it’s not showing any upcomming birthday
                                      ok i’ve made temporary solution but it’s not ideal …
                                      what i’ve done - open Google Calendar - Export and Import
                                      exported all calendars to .ics
                                      i’ve copied birthday calendar to rpi (using scp birthday.ics pi@:MagicMirror/modules/calendars)
                                      in config.js i’ve creaded new entry for newly created calendar.
                                      problem is it’s static so if you want to add new birthday you have to edit file birthday.ics
                                        jhp392819
                                        @Beh
                                        First, thank you! This is great. I got three different iCal calendars to all work perfectly.
                                        I can’t, however, seem to get a holiday calendar to show. The vdirsyncer discover doesn’t show the iCal US Holiday calendar, so I can’t use the one that is provided by iCloud. So I decided to use the calendarlabs that comes as a default with MagicMirror. But it’s showing up on electron when I npm start
                                        I’ve included my code below. Can anyone tell me why the calendarlabs US holiday calendar isn’t showing up?
                                        Do I need to create a 4th .ics file form calendarlabs to store locally to use with vdirsyncer? Is that why the default code in MagicMirror for calendarlabs no longer works?
                                        Thanks.
                                            module: 'calendar',
                                            position: 'top_left',   // This can be any of the regions. Best results in left or right regions.
                                                colored: true,   // Activate coloring
                                                maximumNumberOfDays: 10,
                                                maximumEntries: 7,
                                        	timeFormat: 12,
                                                        // "ME Calendar"
        url: 'http://localhost:8080/modules/calendars/home.ics',
        symbol: 'calendar',
        color: '#5bc0de'   // Assign color
                                                        // "YOU Calendar"
        url: 'http://localhost:8080/modules/calendars/work.ics',
        symbol: 'calendar',
        color: '#FFF000'  // Assign color
                                        		// "ME & YOU Calendar"
                                                            	url: 'http://localhost:8080/modules/calendars/65839DD3-D523-48E6-931B-D2DB201A1C36.ics',
        symbol: 'calendar',
        color: '#5bbf21'  // Assign color
                                        		// "Holiday Calendar"
                                                            	url: 'http://www.calendarlabs.com/templates/ical/US-Holidays.ics',
        symbol: 'calendar',
        color: '#ab00ff'  // Assign color
                                        • Y
                                          yk
                                          Fantastic effort! Thanks!
                                          I’ve got everything working except the timer functionality (just doesn’t seem to take). Any ideas?
                                          BehB 1 Reply Last reply
                                            showbizkid
                                            Thanks gentlemen for allowing me to join your group. I am presently stuck on the " touch ~/.vdirsyncer/config". My pi claims I am unable to use touch. error is touch: cannot touch '/home pi/.vdirsyncer/config. No such file or directory. Do I need to be in the MagicMirror directory to execute this command?
                                            • 4 / 9
