    Sync private iCloud calendar with MagicMirror
    162 Posts 58 Posters 415.0k Views 65 Watching
    • G Offline
      ganther
      @Gailby no, same behavior here.
      @beh Thank you and good luck for your exams.
        maestro82 @maestro82
        Solved this issue by using “http:” not “https:” in calendar url but now my calendar shows no events. I looked into the actual “modules/calendars/****.ics” file and it contains multiple events. Any suggestions?
        • G Offline
          ganther @maestro82
          @maestro82
          Did you check your calendar-url in conf/config.js?
          My calendar is running now correctly. Don‘t know why but now my ics-file isn‘t empty anymore.
            maestro82
            So . . . . . . restarted the mirror and now it works. Moving on to adding other calendars, wish us luck.
              maestro82
              So I have three separate calendars linked to ical, running on my magic mirror. I see events from all three calendars, but many events are missing. Any ideas?
              • E Offline
                E3V3A @maestro82
                @maestro82 said in Sync private iCloud calendar with MagicMirror:
                You are probably limiting the number of calendar items shown in your calendar config. (IDK what is the default, but perhaps only 10-15 which for 3 cals can be easily overloaded.)
                "Everything I do (here) is for free – altruism is the way!"
                  maestro82 @E3V3A
                  I have several reoccurring events on the same day, only one of each event is showing up. The number of events is set at 10 but it is going out at least 4 months with that set. It should only go out about 3 weeks with 10 events listed. I’ll try raising the number of events and limiting the time.
                    paddyhughes
                      paddyhughes @paddyhughes
                        paddyhughes
                        Hi
                        So i am getting stuck with this and don’t know how to fix the issue.
                        The UUID is beside my Calendar and in my iCloud this is my default one.
                        but the one i want to use is home (Home Calendar) but No UUID shows up
                        same goes for the work one.
                        The only one i am interested in is the Home Calendar
                        pi@raspberrypi:~/MagicMirror $ vdirsyncer discover
                        Discovering collections for pair iCloud_to_MagicMirror
                        Mirror:
                        iCloud:
                          - "tasks" ("Reminders")
                          - "AE********-E**4-4D**-A**4-*****************" ("Calendar")
                          - "home" ("Home Calendar")
                          - "work" ("Work")
                        warning: No collection "HERE-GOES-THE-UUID-OF-THE-CALENDAR-YOU-WANT-TO-SYNC" found for storage Mirror.
                        Should vdirsyncer attempt to create it? [y/N]:
                        Thanks for any help given :)
                          Last issue resolved
                          So my issue not really an issue just me expecting something different than what i got when i ran vdirsyncer discovery
                          So the example on page 1 looks like this
                          Mirror:
                          iCloud:
                            - "25CB285C-E163-4E0E-B420-C3FB469B7C00" ("Calendar 1")
                            - "9221FEE8-E8B4-4D07-9402-8638529919EC" ("Calendar 2")
                            - "953A5477-E405-4ED6-A5C3-473444EACC95" ("Calendar 3")
                          warning: No collection "9221FEE8-E8B4-4D07-9402-8638529919EC" found for storage Mirror.
                          With all the Calendars having a string for UUID E.G. 9221FEE8-E8B4-4D07-9402-8638529919EC
                          And this is what i got
                          Mirror:
                          iCloud:
                            - "9221FEE8-E8B4-4D07-9402-8638529919EC" ("Calendar")
                            - "work" ("Work")
                          Now what i didn’t know was that i did get a return of UUID for each Calendar
                          (Reminders) UUID is "tasks"
                          (Calendar) UUID is "9221FEE8-E8B4-4D07-9402-8638529919EC"
                          (Home Calendar) UUID is "home"
                          Hope this helps other people in the future.
                          took me a bit of digging around.
                            maestro82
                            paddyhughes,
                            Had the exact same issue.
                            Had one calendar called “worK”, all the rest had the long UUID names.
                            I keep looking for the “work” calendar, of course it’s UUID was “work”.
                            Put that in and now it works.
                            Some lessons are learned the hard way.
                            Maestro-82
                              paddyhughes @maestro82
                              Ya kept thinking I did something wrong set up 3 different Rpi thinking I did something some were in the code to mess up. Finally got it working ;)
                              paddyhughes,
                              Maestro-82
                                Devert
                                Have any1 made a video how to set it up, I have some problems? :-D
                                  paddyhughes @Devert
                                  Hi what’s the issue
                                  @Devert
                                  • F Offline
                                    Fenis
                                    I saw someone back on page 1 getting this error but not a solution:
                                    File “/usr/bin/vdirsyncer”, line 7, in
                                    from vdirsyncer.cli import main
                                    ImportError: No module named ‘vdirsyncer’
                                    In answer to the reply of if I added python3 to the executable, I already have.
                                    • F Offline
                                      Fenis @Doubleve
                                      @Doubleve How did you fix this issue? I’m getting the same error.
                                        dylanje
                                        Thanks for the tutorial, this is incredibly helpful.
                                        I’m to the point where my MagicMirror displays events from my Home calendar, but it seems that vdirsyncer.timer is not actually working. When I run systemctl --user enable vdirsyncer.timer the console doesn’t output any errors and just returns to a new line. I never see any updates to events on the calendar if I remove/add.
                                        I’ve modified the timer settings, and changed a few settings on the MagicMirror side as well but the only way I can get the .ics files to update is if I manually run vdirsyncer sync. I’ve ready through the docs over here: https://vdirsyncer.pimutils.org/en/stable/index.html but there really isn’t any useful information about the timer.
                                        Any thoughts or leads to finding an answer?
                                        • MarosM Offline
                                          Maros
                                          Hi all,
                                          i’m trying to prepare everything on SW site before i start building MM and i have almost everything except birthdays … :(
                                          i’m using iCloud to store my contacts birthdays but i’m not able to find way how to import them to calendar module on MM2
                                          i’ve found and installed this module :
                                          MMM-iCloud-Client
                                          i’ve installed it and also dependecies :
                                          npm install ical-generator
                                          npm install icloud
                                          npm install nedb --save
                                          in config/config.js i’ve updated entry with
                                          module: ‘MMM-iCloud-Client’,
                                          username: “appleID”,
                                          password: “password”,
                                          countrycode: “49”,
                                          also i’ve edited modules/default/calendar/calendar.js and added this code to it (below US-Holidays.ics …entry) :
                                          symbol: ‘birthday-cake’,
                                          url: ‘http://localhost:8080/MMM-iCloud-Client/birthdays’,
                                          but it’s still not showing any birthday even if upcomming are in 2 days.
                                          Can someone help me what i’m doing wrong ?
                                          Thank you
                                          • MarosM Offline
                                            Maros
                                            noone ? i realy want to see upcomming birthday but i’m not able to get it work
                                            • 3 / 9
