    Problem with MMM-ResRobot, it wont start(?)
    31 Posts 7 Posters 24.0k Views 7 Watching
    • A
      Alvinger @Eburkis
      @Eburkis et al
      I’ve just pushed a long-overdue update to MMM-ResRobot to github.
      This new version has a completely reworked updating logic which should result in less “frozen” updates and also less API calls to Trafiklab/ResRobot over time.
      Note that there is a breaking change to the configuration as I’ve changed the way routes are defined.
      Previous configuration:
      to: "to1,,to3"
      New configuration:
      routes: [
        {from: "from1", to: "to1"},
        {from: "from2", to: ""},
        {from: "from3", to: "to3"},
      Sorry for not pushing the update sooner but my mirror project has been delayed due to other things. Will try to update more frequently in the future. Please drop me a note if you encounter issues!
      A 1 Reply Last reply
      • A
        ajomannen @Alvinger
        @Alvinger
        Hi there,
        I fail to get the new config format to work.
        I use the following block:
        	module: "MMM-ResRobot",
        	header: "Departures",
        		routes: [
        		skipMinutes: 0,
        		maximumEntries: 6,
        		truncateAfter: 5,
        		apiKey: "xxxxx"
        but MagicMirror2 fails to start with following message:
        WARNING! Could not validate config file. Please correct syntax errors. Starting with default configuration.
        (If I use the old config syntax for routes, the system starts up as before, but I get departures from some default location that seems like Stockholm C.)
        What could I have done wrong?
        • A
          ajomannen @ajomannen
          @ajomannen
          I got it to work by adding an extra level of curly brackets and a comma after the closing square bracket:
          		routes: [
          		skipMinutes: 0,
          		maximumEntries: 6,
          		truncateAfter: 5,
          		apiKey: "xxxx"
          Is the example config on https://github.com/Alvinger/MMM-ResRobot incorrect?
          • A
            Alvinger @ajomannen
            @ajomannen sorry, the curly braces got lost in my copying. I have updated my previous post.
            • G
              Gailby
              I can not get it working either, says fetching for quite some time now. I get a “MMM-ResRobot : Error: got 400 response” on starting server… strange. Anyone recognize the same output?
                                          routes: [
                                                  {from: "740021656", to: "740020749"},   // ResRobot Station IDs of starting and destination station(s). At least one route must be defined.
                                                  {from: "740000765", to: "740000284"},   // "from" is required but "to" is optional (set "to" to empty string to indicate all destinations)
                                                  skipMinutes: 0,         // Skip departures that happens within the next  minutes.
                                                  maximumEntries: 6,      // Number of departures to show on screen
                                                  truncateAfter: 5,       // A value > 0 will truncate direction name at first space after  characters. 0 = no truncation
                                                  apiKey: "1c01e8b8-92d0-4e05-86dc-a112d743ba5a"  // Your ResRobot apiKey
              • G
                Gailby
                Ok, seems it didn’t want to handle several departures like previous post but only one:
                                            routes: [
                                                    {from: "740000765", to: "740000284"}    // "from" is required but "to" is optional (set "to" to empty string to indicate all destinations)
                Still get error response:
                node_helper for MMM-ResRobot received a socket notification: CONFIG - Payload: {“updateInterval”:300000,“animationSpeed”:2000,“fade”:true,“fadePoint”:0.25,“apiBase”:“https://api.resrobot.se/v2/departureBoard?format=json&passlist=0",“apiKey”:“1c01e8b8-92d0-4e05-86dc-a112d743ba5a”,“routes”:[{“from”:“740000765”,“to”:“740000284”}],“skipMinutes”:0,“maximumEntries”:6,“truncateAfter”:5,“iconTable”:{“B”:"fa fa-bus”,“S”:“fa fa-subway”,“J”:“fa fa-train”,“U”:“fa fa-subway”,“F”:“fa fa-ship”}}
                Fetching new departure data for module: MMM-ResRobot
                node_helper for MMM-ResRobot received a socket notification: CONFIG - Payload: {“updateInterval”:300000,“animationSpeed”:2000,“fade”:true,“fadePoint”:0.25,“apiBase”:“https://api.resrobot.se/v2/departureBoard?format=json&passlist=0",“apiKey”:“1c01e8b8-92d0-4e05-86dc-a112d743ba5a”,“routes”:[{“from”:“740021656”,“to”:“740020749”}],“skipMinutes”:0,“maximumEntries”:6,“truncateAfter”:5,“iconTable”:{“B”:"fa fa-bus”,“S”:“fa fa-subway”,“J”:“fa fa-train”,“U”:“fa fa-subway”,“F”:“fa fa-ship”}}
                • A
                  Alvinger @Gailby
                  @Gailby I copied your first config but used my API key and it worked with no issues at all.
                  Verify that you are using the correct API key.
                  The 400 status code is usually because you are using the wrong key.
                  G 1 Reply Last reply
                  • G
                    Gailby @Alvinger
                    @Alvinger Thanx a lot, that did it! I got confused about the english translation of “ResRobot - Pole Schedules 2” and used ResRobot - Reseplanerare. My Bad :/
                    • A
                      Alvinger @Gailby
                      @Gailby
                      Great to hear! (Jag dokumenterade på engelska så alla kunde förstå men då blir ju svenskar lite förvirrade! :-)
                      Maybe I should add the swedish name of the API key to the documentation as well.
                      • A
                        ayeball @Alvinger
                        @Alvinger
                        Re: [Problem with MMM-ResRobot]
                        I have also problem with MMM-Resrobot . I use API-Key ResRobot - Stolptidtabeller 2. !
                        I got it to work now but i get stockholm stations … And i have use “ejdergatan"740025622” to redbergsplatsen" 740025673" Göteborg .
                        any idea? Kan svara på svenska också ;) Mvh
                        • A
                          Alvinger @ayeball
                          @ayeball
                          Please post the appropriate part of config.js
                          Klipp in den relevanta delen av config.js så kan vi kolla på den.
                          • A
                            ayeball @Alvinger
                            @Alvinger {
                            Fick det att funka nu ! . Va tydligen 3 ställen jag fick ändra cfg till id för stationerna samt app id . i config.js / mmm-resrobot.js och mmm-resrobot som ligger i mmm-resrobot master mappen .
                            Om jag vill ha en till tillagd som är det bara och upprepa följande kommando nedanför eller ? ;) Mvh
                            from: “station id”, // ResRobot Station ID (or a comma-separated string of IDs)
                            to: “station id”, // ResRobot Station ID of destination (or a comma-separated string of IDs)
                                position: "left",
                                header: "Spårvagn från Ejdergatan",
                                    from: "740025622",   // ResRobot Station ID (or a comma-separated string of IDs)
                                    to: "740025673", // ResRobot Station ID of destination (or a comma-separated string of IDs)
                                    apiKey:"f1109bf4-187c-49e2-95ce-1ba1b6062388"  // Your ResRobot apiKey
                            • A
                              Alvinger @ayeball
                              @ayeball
                              Bra att det funkar.
                              Du ska bara behöva ändra i den config.js som ligger i MagicMirror-mappen, inte i de andra.
                              För att ange flera rutter lägger du bara till en ny rad med:
                              {from:“”, to:“”},
                              På din config ser det ut som att fu använger en gammal version. Gör en git pull för att uppdatera. En av ändringarna är just formatet för att ange flera rutter. Se README.md för dokumentation.
