    Calendar and Newsfeed stop Updating after 1-2 hours
    3 Posts 3 Posters 2.0k Views 3 Watching
    • O
      osoWP95
      My Magic Mirror works and runs the default calendar, weather, and newsfeed modules as well as MMM-Cryptocurrency. I did the config check and it came back with proper syntax. Overall, everything works well, but I’ve noticed that my claendar stops updating after 1-2 hours and that my newsfeed also stops updating. I linked to an iCal URL. If I make a change to the calendar using another device, the changes will update on the Magic Mirror, but after MagicMirror has run for an hour or so it stops reflecting the changes. I left my MagicMirror running for a week and events that were 5-6 days ago were listed as occurring tomorrow.
      It also was running the previous weeks’ headlines. I’m not sure if they’re doing the same thing as the calendar and updating for 1-2 hours, then stopping, or if they just do an initial load and never update.
      The MMM-Cryptocurrency and weather modules do update appropriately. If I close and restart MagicMirror everything starts off up to date and then after an hour or two it appears the calendar and newsfeed stop updating.
      I’m sure there’s a smart way to look in a logfile and see what’s going on, but I didn’t see anything obvious. I checked the messages when I quit the Magic Mirror application, and I also browsed through the logfiles under ~/Pi/.rpi/logs/. Nothing jumped out at me, but I’m more or less self taught on Linux and have no real idea what I’m doing. Any help is appreciated.
      • N
        ninjabreadman @osoWP95
        @osoWP95
        If you’re using pm2, you can use pm2 logs to view the server logs (or view them directly in ~/.pm2/logs).
        You can also use npm start dev to start in dev mode and see the browser (client) console (be sure to stop the PM2 process first, e.g. pm2 stop mm).
        • kwyjibo089K
          kwyjibo089
          Not sure if this applies to you, but I had problems with updating the calendar. Turns out I had to change the wifi channel -> https://forum.magicmirror.builders/topic/4193/calendar-not-updating-after-changing-to-wifi-ssid/3
