    Timetable with (almost) static data
    16 Posts 5 Posters 9.6k Views 5 Watching
      AxLed Module Developer
      Hi, i am looking for a possibility to enter a timetable for my kids, which is based on static datas and change only on a yearly base.
      My idea would be to have a file (.txt/.csv) somewhere in the filefolders of magic mirror. I can probably realize it by .php but i dont have a clou how to show this in MM2 (as i would like to run the .php directly on the raspberry pi.
      Best regards
      Axled
      • OdomLinxO Offline
        OdomLinx
        Use the Module iframe to Display the php Site
          Hi OdomLinx,
          i tried this, but i dont know where to run my php site on the raspberry pi:
          • does Raspian/MM2 support .php
          • where do i have to save the files and what will the (web)path be?
            Axled
            So, now i installed apache2 and php on my test system (ubuntu vm). I got a first solution with a .php site (running on same machine) and MMM-iFrame pointing to local php site.
            Here is a first screenshot:
            My Webfolder looks like this:
            • index.html (comes from apache2)
            • phpinfo.php (was a testfile to check if php works)
            • timetable.php (is my php site, which reads the datas of timetable.csv, so it is easier to change datas once a year)
            Right now i am fighting with css and formatting, but the first steps are made.
            I am not sure what the performance on RPI will be with apache2 and php running next to MM2.
            Axled
            N 1 Reply Last reply Reply Quote 1
            • N Offline
              ninjabreadman @AxLed
              @AxLed To answer your question, apache2 or xginx serving a single static page without (image) assets will have a negligible footprint and cause minimal load, certainly not noticeable with everything else the Pi is doing for MM and Node.js.
              As for your layout and styling question, I quickly Googled this layout here, which might help, and comes with example markup and styling (and explanatory article): https://codyhouse.co/demo/schedule-template/index.html
                doubleT Module Developer
                Node can execute a php – if a php.ini is in the PATH – with this in the node_helper.js :
                const runner = require("child_process");
                runner.exec("php " + proxy + " " + params, function(err, data, stderr) {
                //         ("php timetable.php parameter", function(err, data, stderr) {
                    var content = data; // "Clean your room - now!"
                    this.workWithTheData(content);
                timetable.php :
                < ? php // remove spaces
                $params = explode(",", $argv[1]); // example, you can leave parameters out (see above)
                $content = "Clean your room – now!";
                echo $content;
                Now that we know we can, let’s talk about if we should: I like it, I use it for a proxy to call APIs while ignoring CORS. BUT I don’t think it makes sense in this case! It’s like using a hammer to fix a loose screw.
                To show a static website in the iframe, HTML is enough. Do you really need server side scripts?
                If you want a csv, use this in the node_helper.js :
                const fs = require("fs"); // before module.exports = ...
                getTimeTable: function() {
                    var rawdata = fs.readFileSync('modules/my-module/file.json'); // or txt or csv
                    var timetable = JSON.parse(rawdata); // in this case
                    this.sendSocketNotification("Response", timetable);
                EDIT: I know that for users with basic HTML or even PHP knowledge, the iFrame solution is an easy win. Use runner or fs if you want to import data directly into your own module.
                N 1 Reply Last reply Reply Quote 2
                • N Offline
                  ninjabreadman @doubleT
                  @doubleT Not exactly. More like making and keeping around a hammer for the occasional tiny nail. Locally loading an HTML file absent a server is more akin to hammering with the handle is a screwdriver. ;)
                  Will the existing instance of Server in server.js not serve files in the /modules directory? Like an iframe of /modules/MMM-iframe/sched.html? If not, could you add a /static or similar folder to directories? As you say, seems overkill to (1) run an apache2 instance, but even to (2) create a separate webserver in Node, given that MM already runs one that can be used or modified.
                  Apologies all, I’m posting from my phone on vacation, so am speaking before properly testing.
                    Actually, I wasn’t really thinking about loading a page and displaying it (in an iFrame) but I rather looked at the questions of loading file contents and suggested the runner.exec child process because php was specifically mentioned (I don’t think PHP is necessary at all).
                    If we’re talking about HTML, I’d agree with you (also without testing, though). But for PHP within Node.js: That won’t work, you’d have to have a PHP server running parallel to node and address it, etc. My suggestion (runner.exec child_process) doesn’t run a server but executes that one file with PHP and returns what it parsed.
                    • N Offline
                      @doubleT D’oh! I totally overlooked the PHP requirement in contemplating a revised approach. Given it’s already written, probably not worth porting the code to native js. ¯\_(ツ)_/¯
                      @AxLed could however view the PHP file, save the generated HTML, and then serve the static file (until next semester, anyway!).
                        @doubleT and ninjabreadman
                        My request was to show a timetable, where i can change the datas in an .csv file.
                        The only way i knew to realize this was via php. So thats the reason why i tried this via apache2 an php which worked (somehow).
                        If i understood you right, there are to ways to solve my request:
                        A. Show the .php page via node
                        B. use the node_helper.js to open a .csv file and loop through the datas.
                        If i am right, i dont know what do i need for Way A and Way B, as i dont know (right now) how to write a own module.
                        I am looking forward hearing from you.
                        Best regards
                        Axled
                        • N Offline
                          @AxLed Honestly, I derailed the conversation with other ways it could be accomplished.
                          If you have apache2 and php serving up your .csv file, you’ve accomplished what you need to in a way that can easily be updated in future. You already solved the requirement with option A. You could change how you generate the table from the CSV, but that’s a lot of work with no real benefit.
                          If you want to post your CSV/HTML, we can maybe recommend ways to help style it, but you’ve already accomplished what you set out to do.
                            Or maybe I derailed it when I looked at the question of “how to get the csv” after the thread already went to the iframe solution? :D
                            @AxLed Did you get the php page shown via iframe module?
                            A. will not be able to show the php page via node – if you mean my suggestion. It will just get all echo’d content from the php file into the js module. So in this case it’s an over-complicated way of receiving the csv file into a module.
                            The node_helper.js should send the whole package back to the module.js and there it should loop through the datas.
                            If you have the php knowledge to build a page that reads a csv and shows the content, it shouldn’t be too hard to get into the necessary js. To build a module for the MM, the Readme in the module folder is the first step to go to.
                              AxLed Module Developer @doubleT
                              @doubleT said in Timetable with (almost) static data:
                              Yes i did, see my screenshot:
                              Timetable and datas below is a .php Website, which runs local on RPI and is integrated in MM via MMM-iFrame
                              Axled
                                Ah, true. If that works for you, I’d leave it at that. But then again, it’s always good to learn something new.
                                Do you want to try it yourself and maybe ask for help when you get stuck? Or maybe this would be an excellent case for a tutorial, I could try to do something like that.
                                  pinsdorf Module Developer
                                  @AxLed, I also wanted to show today’s class schedules on my magic mirror. Those weekly schedules, e.g. at school or sports clubs, are very reliable and update only with a low frequency. So it is no big deal to change the config every now and then.
                                  I’ve created a module MMM-WeeklySchedule to solve this for me. Feel free to give it a try. Feedback is most welcome.
                                  Cheers.
                                  alt text
                                    @pinsdorf
                                    Thanks for the link an the name of your module, thats that what i was looking for. I will test it. I like your implementation with “starting time only” and “actual weekday only”, so this saves a lot of space in width to fit better to the other modules.
                                    And you are right, if i change datas in an .csv or in a list in the config-file is pretty most the same.
                                    Regards
                                    Axled
