    Cant run the app
    11 Posts 5 Posters 5.9k Views 4 Watching
    • G Offline
      goncalovsc
      My first time trying to build a magicmirror, and i cant solve this problem. Can you guys help me? alt text
      • cruunnerrC Offline
        cruunnerr
        Could u send the full log file in a code box here?
        cat /home/pi/.npm/_logs/2018-01-02T17_31_20_367Z-debug.log
        • G Offline
          goncalovsc
          1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start' ]
          2 info using npm@3.10.10
          3 info using node@v6.12.2
          5 info lifecycle magicmirror@2.2.1~prestart: magicmirror@2.2.1
          6 silly lifecycle magicmirror@2.2.1~prestart: no script for prestart, continuing
          7 info lifecycle magicmirror@2.2.1~start: magicmirror@2.2.1
          8 verbose lifecycle magicmirror@2.2.1~start: unsafe-perm in lifecycle true
          9 verbose lifecycle magicmirror@2.2.1~start: PATH: /usr/lib/node_modules/npm/bin/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
          10 verbose lifecycle magicmirror@2.2.1~start: CWD: /home/pi/MagicMirror
          11 silly lifecycle magicmirror@2.2.1~start: Args: [ '-c', 'sh run-start.sh' ]
          12 silly lifecycle magicmirror@2.2.1~start: Returned: code: 1  signal: null
          13 info lifecycle magicmirror@2.2.1~start: Failed to exec start script
          14 verbose stack Error: magicmirror@2.2.1 start: `sh run-start.sh`
          14 verbose stack Exit status 1
          14 verbose stack     at EventEmitter. (/usr/lib/node_modules/npm/lib/utils/lifecycle.js:255:16)
          14 verbose stack     at emitTwo (events.js:106:13)
          14 verbose stack     at EventEmitter.emit (events.js:191:7)
          14 verbose stack     at ChildProcess. (/usr/lib/node_modules/npm/lib/utils/spawn.js:40:14)
          14 verbose stack     at ChildProcess.emit (events.js:191:7)
          14 verbose stack     at maybeClose (internal/child_process.js:920:16)
          14 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:230:5)
          15 verbose pkgid magicmirror@2.2.1
          16 verbose cwd /home/pi/MagicMirror
          17 error Linux 4.9.59-v7+
          18 error argv "/usr/bin/node" "/usr/bin/npm" "start"
          19 error node v6.12.2
          20 error npm  v3.10.10
          21 error code ELIFECYCLE
          22 error magicmirror@2.2.1 start: `sh run-start.sh`
          22 error Exit status 1
          23 error Failed at the magicmirror@2.2.1 start script 'sh run-start.sh'.
          23 error Make sure you have the latest version of node.js and npm installed.
          23 error If you do, this is most likely a problem with the magicmirror package,
          23 error not with npm itself.
          23 error Tell the author that this fails on your system:
          23 error     sh run-start.sh
          23 error You can get information on how to open an issue for this project with:
          23 error     npm bugs magicmirror
          23 error Or if that isn't available, you can get their info via:
          23 error     npm owner ls magicmirror
          23 error There is likely additional logging output above.
          24 verbose exit [ 1, true ]
          • N Offline
            ninjabreadman @goncalovsc
            @goncalovsc Is this after having run the auto install script or manually installing? Did you run npm install in the ~/MagicMirror folder? Have you tried running npm start in the same directory?
            @cruunnerr What are the permissions of your run-start.sh? It doesn’t make sense to me that mine is rw-r—r— but works fine. I would expect it needs x permissions.
            • G Offline
              goncalovsc @ninjabreadman
              @ninjabreadman I’ve done all that, and the error persists
              • saljokeS Offline
                saljoke
                Try to rebuild electron or reinstall with last update. npm install -g electron or npm rebuild in magic Mirror directory
                G 2 Replies Last reply Reply Quote 0
                • G Offline
                  goncalovsc @saljoke
                  @saljoke I’ll try later at night, when I’ve done that I’ll give you an update. Thanks
                    cpramhofer
                    Did you run the install directly from the command line (without the start of the graphical user interface)?
                    You should run the setup within the GUI!
                    • G Offline
                      goncalovsc @cpramhofer
                      @cpramhofer i installed by the commands, I followed a video
                      • G Offline
                        goncalovsc @saljoke
                        @saljoke i tryed, and exatly the same error
