    Question to MMM-Swipe (Simon089) and MMM-Pages and MMM-page-indicator
    4 Posts 2 Posters 2.1k Views 2 Watching
      AxLed Module Developer
      i installed following modules
      • MMM-Swipe (Simon089)
      • MMM-Pages
      • MMM-page-indicator
      and wired my 2x HC-SR04 Sensors a suggested and have following questions.
      Movement will be recognized, but not reliable, i already change some settings (leftDistance, rightDistance, maxDistance) and used the calibrate mode but i am not satisfied.
      Is there a suggested distance between (not distance from sensor to hand) right and left HC-SR04 i should use, to make them work better?
      I tried this modul on my “Lab” RPI1, is it possible this pi has to less power/ressource to calculate accurate?
      I also have a RPI3 for my final mirror, but testing will either been done in a ubuntu VM or on the RPI1 if i have to use the GPIOs.
      I am looking forward hearing from you.
      Regards
      Axled
        jonathancole85
        AxLed, I’m curious, did you ever get swipe to work for you?
          @jonathancole85
          No, it never worked satisfieing for me. Thats the reason i wrote the MMM-Navigate Module for using a rotary encoder for interaction with mm.
          AxLED
            jonathancole85
            I will try that now. Looking forward to seeing it in action.
            • E Egnos referenced this topic on
            • M MMRIZE referenced this topic on
