    MMM-PIR-Sensor: Everything works fine, just one thing not...
    7 Posts 3 Posters 3.2k Views 2 Watching
    • MedoM Offline
      Medo
      My sensor is working fine for months now. It works as designed (shuts my mirror down after 5 minutes and is reactivated if someone enters the room or goes by).
      But i noticed this:
      After a reboot of the whole PI mirror system, the screen isn’ t turned off by the MMM-PIR-Sensor-module (even after waiting for more than an hour or more - i think it would be on forever). Only if someone goes by, the sensor shuts down the screen (monitor) for a millisecond and immediately after that, turns the screen on again. After that, the PIR sensor works fine like every day before…
      Does any one of you ever had a similar behavior of a PIR sensor configuration?
      Thanks!
      Medo
        AxLed Module Developer
        Hi Medo,
        i think i read something that after a reboot you have to wave your hand (for example) in front of sensor once, so the sensor is active.
        AxLED
        MedoM 1 Reply Last reply Reply Quote 0
        • MedoM Offline
          Medo @AxLed
          @AxLed
          Thanks, did not know that this has to be done to “activate” a PIR sensor…Interesting…hmm…
          Does anyone know, if there is a method that this can be “simulated” in any way?
          • cruunnerrC Offline
            cruunnerr
            one idea is to just put the tvservice -o command in your rc.local.
            before that u should do a little sleep.
            like this:
            sudo nano /etc/rc.local
            #!/bin/sh -e
            # rc.local
            # This script is executed at the end of each multiuser runlevel.
            # Make sure that the script will "exit 0" on success or any other
            # value on error.
            # In order to enable or disable this script just change the execution
            # bits.
            # By default this script does nothing.
            # Print the IP address
            _IP=$(hostname -I) || true
            if [ "$_IP" ]; then
              printf "My IP address is %s\n" "$_IP"
            fi
            sleep 60 &
            tvservice -o
            exit 0
            So on every reboot it will wait 60 seconds (just to let everything start like MM) and then turn the monitor off.
            MedoM 1 Reply Last reply Reply Quote 3
            • MedoM Offline
              Medo
              Sounds like a great idea! I will try that soon and will geht you a reply if it works! Thanks for that possible solution…
              • MedoM Offline
                Medo @cruunnerr
                @cruunnerr
                Your solution worked like a charm.
                Thanks!
                cruunnerrC 1 Reply Last reply Reply Quote 1
                  cruunnerr @Medo
                  @Medo
                  Glad to hear that :)
