    Trim the fat in a JSON file?
    6 Posts 3 Posters 2.9k Views 4 Watching
      DeathChicken
      So, I got my MM working. Set up a few modules and learning along the way.
      Than comes the JSON file that I get to display, but I only care about a part of it.
      Its a ComEd Hourly Pricing and the output it gives is
      0:[{"millisUTC":"1517732400000","price":"2.1"}]
      I just want the 2.1 output
      there is a “values” option that seems to be what I need to use,
      ie:
      Example: [“key1”, “key2”, “keyA.keyB.keyC”]
      but when I add the last line
          module: 'MMM-json-feed',
          position: 'bottom_left',
            url: 'https://hourlypricing.comed.com/api?type=currenthouraverage&format=json',
            title: "ComEd Hourly Pricing",
            values: ["key4"],
      it doesnt work.
      Am I doing something wrong?
        doubleT Module Developer
        @DeathChicken said in Trim the fat in a JSON file?:
        So the value of the key “price”. I haven’t looked at the module’s code, but I think you have to say “price” instead of “key4”.
            values: ["price"]
          DeathChicken
          Tried that. It doesn’t work.
          The field just doesn’t display any data at all
          alt text
          if i set
          values: [""]
          it shows alt text
            Ok, I checked the code of that module, values: ["price"] IS the correct setting for the config but getValue: function(data, value) {... has an error.
                if (data && value) {
                  var split = value.split(".");
                  var current = data;
                  while (split.length > 0) {
            //        current = current[split.shift()]; // WRONG!
                      current = current[0][split.shift()];
                  return current;
                return null;
            I’d have written that totally different, but yeah, at the moment, the problem is, that the object it should be looking for is nested within a wrapping object. Add the [0]and you should be getting your results.
            Edit: Could also be a problem with the received json format.
            E 1 Reply Last reply Reply Quote 2
              DeathChicken
              Thank you so much.
              I wasn’t sure where to add the [0] exactly. But at least I had somethign to play with.
              After a couple tries values: [“0.price”] yields output of Price: “2.1” which is clear enough for my needs.
              • E Offline
                E3V3A @doubleT
                @doubleT If you think there is an improvement that can be done to that module, perhaps file an issue or PR at the module repo? I’ve been looking at that module and wondering if it’s worthwhile using it, or rather just use something more complete as a template. What do you think?
                "Everything I do (here) is for free – altruism is the way!"
