    How I got my Magic Mirror working on a Raspberry Pi 0 (zero)
    raspberry pipi0zeropizeropi1
    204 Posts 47 Posters 666.6k Views 47 Watching
    • Andrius okA
      Andrius ok @lasharor
      @lasharor did you using Raspberry Pi Zero W ?
      L 1 Reply Last reply
      • L
        lasharor @Andrius ok
        @Andrius-ok Yes.
        Tried the Image also. works fine after upgrading. Was not succesfull upgrading magicmirror however. Trying PipoloyJo solution now.
        Andrius okA 1 Reply Last reply
        • Andrius okA
          @lasharor ok tomorrow I will share the image
          • L
            lasharor @PipoloyJo
            @PipoloyJo So I also tried this. Can you please specify which distro you are using? As this is not working on Jessie.
            Also the script should contain apt-get upgrade in the beginning. Otherwise you’ll not be able to download most packages due to incorrect links.
            Trying now on stretch.
            Edit: having problems with rpi-update (or upgrade), will not download the full image can’t run chrome in sandboxed mode. So tried to run MM by disabling sandboxed mode. End up with working Chrome but blank black screen.
            P 1 Reply Last reply
              PipoloyJo @lasharor
              @lasharor I am using Raspbian Stretch. I also got issue with rpi-update, but I got MM to work without it.
              • L
                lasharor @PipoloyJo
                @PipoloyJo If you don’t update you can’t launch Chromium in sandboxed mode, what are your flags for chrome?
                @Andrius-ok Would be great if you could share.
                • L
                  @Andrius-ok said in How I got my Magic Mirror working on a Raspberry Pi 0 (zero):
                  Have you forgotten :(?
                  • Andrius okA
                    Hi @lasharor , my apologies. Yes I have forgotten, very sorry was on long vacation.
                    So there is my MM image with Chromium for Raspberry Pi Zero W
                    https://www.dropbox.com/sh/kdo5q1pxjluca49/AACvP81YjZik6R90BHZNiSZ5a?dl=0
                    note: you have to configure WiFi by yoursefl and also all modules to work properly in Yours language.
                    B P 2 Replies Last reply
                      bmarofsky @Andrius ok
                      @Andrius-ok Thank You! Worked Perfectly. Setup Wifi (your SSID and PW were still in there) and your config loaded. I am in the process of converting to my config.
                      B 1 Reply Last reply
                        bmarofsky @bmarofsky
                        @bmarofsky said in How I got my Magic Mirror working on a Raspberry Pi 0 (zero):
                        so i have all my modules in place and the system crashes: unable to handle kernel null pointer dereference at virtual address
                        I’ll roll back to your setup and see if it is stable. i am using calendar, weather, clock and newsfeed- very similar to yours.
                        Andrius okA H 3 Replies Last reply
                        • Andrius okA
                          Andrius ok @bmarofsky
                          @bmarofsky nice that you trying to work your MM more “under preasure” what can Raspberry Pi Zero W :) I believe that I take the maximum from this SBC which from the forum cannot do that I did :) by the way share and show photo ;) thats nice to see.
                          P.s. Now checking much more with ASUS TinkerBord - follow me! ;)
                          • Andrius okA
                            @bmarofsky if need advice please you can ask me
                            • H
                              Hawking @bmarofsky
                              Please report if you could stabilize your system. I also had crashes (approx twice a day) when using Chromium. I didn’t had time to investigate the exact cause (to heavy load?).
                              • L
                                lasharor
                                @Andrius-ok Thanks for the image. This works fine. Have you had any succes trying to upgrade Magic mirror? Noticed this image was running a older version.
                                • Andrius okA
                                  Andrius ok @Hawking
                                  @Hawking my MM with this image on Raspberry Pi Zero W working a half a year without crashing, restarting etc., what modules do you using? Did you try only with my modules? You have to know that SBC is very slow and poor on performance so my modules which is in img is taking 99% CPU always, if tou trying to add one more module I think it’s too much
                                  • Andrius okA
                                    @lasharor yes of course, no problems? Did you? Having issues?
                                      patoberli @Andrius ok
                                      Thanks! Worked nice, until I updated and Chromium 56 (or so) got installed.
                                      That version can’t connect (for whatever reason) connect to http://localhost:8080/.
                                      Because of this, I had to change the file /home/pi/startMirror.sh and replace the word localhost with the word 127.0.0.1 and reboot.
                                      Now it’s working again :)
                                      Next thing I’m going to try is to update the MagicMirror installation.
                                      Thanks for your image!
                                      • T
                                        tbanzato
                                        @Andrius-ok
                                        I used your image and works quite well, only one issue.
                                        The server doesn’t star till I SSH it.
                                        What I’m saying the Pi Zero W boots and keeps on the prompt but doesn’t start the magic mirror till I ssh the Pi.
                                        Any hints?
                                        • G
                                          greenwaydev
                                          Great tutorial but when I booted up my pi I got this:
                                          -bash: xset: command not found
                                          -bash: midori: command not found
                                          pi@raspberrypi:~ $ matchbox: can’t open display! check your DISPLAY variable.
                                          I do not know what to do to fix this.
                                          MikgaboM 1 Reply Last reply
                                          • MikgaboM
                                            Mikgabo @greenwaydev
                                            @greenwaydev
                                            Hey!
                                            Try this link to a disc image from Andrius:
                                            Works amazing for me, and I’m sure for you too!
                                            Cheers
                                            G 1 Reply Last reply
                                            • 10
                                            • 11
                                            • 8 / 11
