Magic Mirror 2 on Raspberry Pi 3 - Wifi shutting down!
3 Posts 2 Posters 5.5k Views 2 Watching
  • N Offline
    noro
    Hi guys,
    I installed magi mirror on my rpi3 (jessie) and every thig works well until the wifi randomly goes down.
    The rpi3 is still alive but I cannot reach it over SSH.
    I set the wifi power management to off and I followed all indication/tutorials. But I cannot solve this problem.
    Can you help me some expert with a workaround or a tip?
    Thank you very much.
    Best regards,
    Noro
    • Y Offline
      yawns Moderator
      Did you follow the guidelines for disabling wifi power saving mode?
      If it still fails, you could follow this approach: http://alexba.in/blog/2015/01/14/automatically-reconnecting-wifi-on-a-raspberrypi/
      Maybe replace the ip with the ip of your router to ping a local device in case internet connection dropped at that point.
      • N Offline
        noro
        I disabled the wifi power saving. I will setup the script in crontab to check the connection as you suggested. Thank you.
        Best regards,
        Noro
