    PushBulletNotes - Phone Notifications on your mirror
    8 Posts 5 Posters 6.7k Views 6 Watching
      malicious_banjo
      PushBulletNotes, Phone Notifications on your mirror courtesy of the PushBullet API
      https://github.com/maliciousbanjo/PushBulletNotes
      This module draws design inspiration from user ronny3050’s phone-notification-mirror module, which also used the PushBullet API but stopped being functional about a year ago when the API was updated.
      This is my first module, and I hope to make design tweaks to it per the community’s feedback.
      homescreen
      messages
        StacheEnthusiast @malicious_banjo
        @malicious_banjo
        I am pumped for this module! Thanks for your contribution. After install and configuration, it is showing as no notifications after I sent a couple tests that the chrome extension picked up. I can’t tell if I am being impatient or it is not working right.
        Do I need the pro version of PushBullet for this? What is the update interval?
        There is a link to the PushBullet REST API and this is installed via the npm install right?
        I was a little confused on the ‘read me’ under the API token it says that I would need PushBullet app installed on my device but you’re just referring to having a PushBullet account/app on phone, correct?
          malicious_banjo @StacheEnthusiast
          @StacheEnthusiast Yes, you need to have the official PushBullet app on your phone. No pro version necessary.
          You do need an API key, it definitely will not work without that.
            @malicious_banjo
            Welp…I was hoping to post back before you got to it but after a reboot it’s working flawlessly. I love it. It’s unobtrusive, informative, and simple to set up. Thank you very much!
            Side note, when performing the npm install, I got a message at the end that says npm WARN PushBulletNotes@1.1.1 No repository field. After a bit of googling, I found out that everything is smooth on the install but it is wanting you to add
            "repository": {
              "type": "git",
              "url": "git://github.com/maliciousbanjo/PushBulletNotes.git"
            to your package.json.
            Thanks again!
              @StacheEnthusiast Ah, that’s good to know. Thanks for pointing it out.
              Glad it’s working well for you now!
              • G Offline
                gismo2006
                Good evening,
                I use ronnys notification modul since, I dont know. My smartmirror was offline for a long time. You wrote his modul will not work sice the api have changed. I tested it now again and everything work fine.
                greets gismo
                  Smotx
                  Thx for this module.
                    benderstwin
                    Possible to have everything displayed on one line? I want to put notifications in middle-center and display them as icon-date-time-name-message.
                    Thank you!
