    Energy saving
    energy savingmonitor offhdmi off
    7 Posts 2 Posters 3.5k Views 2 Watching
      svenr
      Hi. I would like that the monitor turns of at 21:00 and turns on again at 08:00.
      But i have no idea how to do this im a noob so maybe someone could help me with this.
      Also i tried to put google assistant to the mirror but i couldnt make it i think thats a bit to hard for me n my knowledge :/
      • P Online
        Peter
        For turning on the mirror (or the screen) and wakening it up, maybe this will help you:
        https://forum.magicmirror.builders/topic/6291/howto-turn-on-off-your-monitor-time-based-pir-button-app
        I use this too and I am happy with it.
        Later I added a pir.
        Succes!
        Peter
          svenr @Peter
          @Peter thank you i guess that helps me just one question: if i type that the monitor should turn off (just a example) from 09:00 till 12:00 and after that works how im able to turn on the monitor in case i changed opinion and at 10:00 i want to turn on the monitor. The monitor is off at 10:00 so how to change it
          • P Online
            Peter
            My monitor turns off at 23.30 and on at 7.00.
            So at night I cannot turn it on.
            During the day the monitor is turned off and on with a pir.
            Clear?
            Peter
              svenr @Peter
              @Peter so it means at 01:00 at night you have no chance to turn on the screen right?
              • P Online
                Peter
                Not if you use a time based method.
                I think I will use the pir only in the future: any movement will turn on the screen for several minutes.
                Even in the middle of the night …
                Peter
                  svenr @Peter
                  @Peter thank you for help :-) good to know
