    MM docker container problem with mac and linux
    14 Posts 3 Posters 8.4k Views 3 Watching
    • T Offline
      tomasz2101
      @raywo i tried
      docker run  -d \
                              --publish 8080:8080 \
                              --restart always \
                              --volume ~/magic_mirror/config:/opt/magic_mirror/config \
                              --volume ~/magic_mirror/modules:/opt/magic_mirror/modules \
                              --name magic_mirror \
                              bastilimbach/docker-magicmirror
      docker ps
      CONTAINER ID        IMAGE                             COMMAND                  CREATED                  STATUS              PORTS                    NAMES
      69efe710da85        bastilimbach/docker-magicmirror   "/opt/magic_mirror/d…"   Less than a second ago   Up 2 seconds        0.0.0.0:8080->8080/tcp   magic_mirror
      docker logs -f magic_mirror
      Starting MagicMirror: v2.1.3
      Loading config ...
      WARNING! Could not find config file. Please create one. Starting with default configuration.
      Loading module helpers ...
      No helper found for module: helloworld.
      All module helpers loaded.
      Server started ...
      Ready to go! Please point your browser to: http://localhost:8080
      cat config.js
      var config = {
      	port: 8080,
      	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "192.168.1.176"],
      	language: "en",
      	timeFormat: 24,
      	units: "metric",
      			module: "clock",
      			position: "top_left"
      When im trying to access url http://localhost:8080/ in incognito i got always “localhost didn’t send any data” and there is no information in container about trying to access pare.
        raywo Module Developer @tomasz2101
        @tomasz2101 This looks okay to me. Although the log states "WARNING! Could not find config file. Please create one. Starting with default configuration.".
        Where did you put your config.js file? Is it in ~/magic_mirror/config on your mac?
        • T Offline
          tomasz2101 @raywo
          @raywo The config.js.sample was created automatically. After that i copy it to config.js and restarted container but logs show:
          Loading config ...
          Server started ...
            @tomasz2101 And? Does it work?
            • T Offline
              tomasz2101 @raywo
              @raywo no
                @tomasz2101 In my config.js I put "" in the address setting. I also have "::ffff:192.168.2.1/120" included in my ipWhitelist. My home network is 192.168.2.0.
                my config.js
                var config = {
                	address: "", // - "", "0.0.0.0", "::" to listen on any interface
                	port: 8080,
                	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.2.1/120", "192.168.2.110", "172.17.0.1"]
                  /* module config */
                • T Offline
                  tomasz2101 @raywo
                  @raywo thx a lot now it is working.
                  Also i had to do docker binding to localhost
                  my config:
                  var config = {
                  	address: "",
                  	port: 8080,
                  	ipWhitelist: [],
                  	language: "en",
                  	timeFormat: 24,
                  	units: "metric",
                  			module: "clock",
                    bastilimbach
                    I updated the Github repository to include a working config file example. Thanks @raywo!
                      raywo Module Developer @bastilimbach
                      @bastilimbach Good addition to the docs. Thank you!
                      Maybe you should remove "192.168.2.1/120", "192.168.2.110" as it applies only to my configuration. Or you should explain it better.
                        bastilimbach @raywo
                        @raywo Oh yes you’re absolutely right.
