MM docker container problem with mac and linux
@raywo i tried
docker run -d \ --publish 8080:8080 \ --restart always \ --volume ~/magic_mirror/config:/opt/magic_mirror/config \ --volume ~/magic_mirror/modules:/opt/magic_mirror/modules \ --name magic_mirror \ bastilimbach/docker-magicmirrordocker ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES 69efe710da85 bastilimbach/docker-magicmirror "/opt/magic_mirror/d…" Less than a second ago Up 2 seconds 0.0.0.0:8080->8080/tcp magic_mirrordocker logs -f magic_mirror
Starting MagicMirror: v2.1.3 Loading config ... WARNING! Could not find config file. Please create one. Starting with default configuration. Loading module helpers ... Initializing new module helper ... Module helper loaded: updatenotification No helper found for module: helloworld. All module helpers loaded. Starting server on port 8080 ... Server started ... Connecting socket for: updatenotification Sockets connected & modules started ... Ready to go! Please point your browser to: http://localhost:8080cat config.js
var config = { address: "localhost", // Address to listen on, can be: port: 8080, ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "192.168.1.176"], language: "en", timeFormat: 24, units: "metric", modules: [ { module: "clock", position: "top_left" }, ] };When im trying to access url http://localhost:8080/ in incognito i got always “localhost didn’t send any data” and there is no information in container about trying to access pare.
@tomasz2101 This looks okay to me. Although the log states
"WARNING! Could not find config file. Please create one. Starting with default configuration.".
Where did you put yourconfig.jsfile? Is it in~/magic_mirror/configon your mac? -
@raywo The config.js.sample was created automatically. After that i copy it to config.js and restarted container but logs show:
Ready to go! Please point your browser to: http://localhost:8080 Starting MagicMirror: v2.1.3 Loading config ... Loading module helpers ... No helper found for module: clock. All module helpers loaded. Starting server on port 8080 ... Server started ... Sockets connected & modules started ... Ready to go! Please point your browser to: http://localhost:8080
@tomasz2101 And? Does it work?
@raywo no
@tomasz2101 In my
config.jsI put""in theaddresssetting. I also have"::ffff:192.168.2.1/120"included in myipWhitelist. My home network is192.168.2.0.my
config.jsvar config = { address: "", // - "", "0.0.0.0", "::" to listen on any interface // Default, when address config is left out, is "localhost" port: 8080, ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.2.1/120", "192.168.2.110", "172.17.0.1"] /* module config */ } -
@raywo thx a lot now it is working.
Also i had to do docker binding to localhost
my config:var config = { address: "", port: 8080, ipWhitelist: [], language: "en", timeFormat: 24, units: "metric", modules: [ { module: "clock", position: "top_left" } ] }; -
I updated the Github repository to include a working config file example. Thanks @raywo!
@bastilimbach Good addition to the docs. Thank you!
Maybe you should remove"192.168.2.1/120", "192.168.2.110"as it applies only to my configuration. Or you should explain it better. -
@raywo Oh yes you’re absolutely right.
