    MM docker container problem with mac and linux
    14 Posts 3 Posters 9.1k Views 3 Watching
    • T
      tomasz2101
      @raywo I know that this is strange behaviour of MM and your fix is not according to documentation. I tried that but that fix doesn’t work at all. Additional think is that I’am running container on my mac and i cannot access MM from mac. 192.168.1.176 is my mac local ip. I want to develop new module but i don’t want to do this on rpi.
      var config = {
      	address: "localhost",
      	port: 8080,
      	ipWhitelist: [ "127.0.0.1", "::ffff:127.0.0.1", "::1", "192.168.1.176"],
      	language: "en",
      	timeFormat: 24,
      	units: "metric",
      			module: "alert",
      			module: "updatenotification",
      			position: "top_bar"
      			module: "clock",
      			position: "top_left"
        raywo Module Developer @tomasz2101
        @tomasz2101 Why is that not according to documentation?
        I have a simliar setup like you. I run docker on my mac and access the mirror instance via my mac it works just fine.
        Maybe you should try it without creating your own docker image. Try the solution as described in the MagicMirror documentation.
        • T
          tomasz2101
          @raywo i tried
          docker run  -d \
                                  --publish 8080:8080 \
                                  --restart always \
                                  --volume ~/magic_mirror/config:/opt/magic_mirror/config \
                                  --volume ~/magic_mirror/modules:/opt/magic_mirror/modules \
                                  --name magic_mirror \
                                  bastilimbach/docker-magicmirror
          docker ps
          CONTAINER ID        IMAGE                             COMMAND                  CREATED                  STATUS              PORTS                    NAMES
          69efe710da85        bastilimbach/docker-magicmirror   "/opt/magic_mirror/d…"   Less than a second ago   Up 2 seconds        0.0.0.0:8080->8080/tcp   magic_mirror
          docker logs -f magic_mirror
          Starting MagicMirror: v2.1.3
          Loading config ...
          WARNING! Could not find config file. Please create one. Starting with default configuration.
          Loading module helpers ...
          No helper found for module: helloworld.
          All module helpers loaded.
          Server started ...
          Ready to go! Please point your browser to: http://localhost:8080
          cat config.js
          var config = {
          	port: 8080,
          	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "192.168.1.176"],
          	language: "en",
          	timeFormat: 24,
          	units: "metric",
          			module: "clock",
          When im trying to access url http://localhost:8080/ in incognito i got always “localhost didn’t send any data” and there is no information in container about trying to access pare.
            @tomasz2101 This looks okay to me. Although the log states "WARNING! Could not find config file. Please create one. Starting with default configuration.".
            Where did you put your config.js file? Is it in ~/magic_mirror/config on your mac?
            • T
              tomasz2101 @raywo
              @raywo The config.js.sample was created automatically. After that i copy it to config.js and restarted container but logs show:
              Loading config ...
              Server started ...
                @tomasz2101 And? Does it work?
                • T
                  tomasz2101 @raywo
                  @raywo no
                    @tomasz2101 In my config.js I put "" in the address setting. I also have "::ffff:192.168.2.1/120" included in my ipWhitelist. My home network is 192.168.2.0.
                    my config.js
                    var config = {
                    	address: "", // - "", "0.0.0.0", "::" to listen on any interface
                    	port: 8080,
                    	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.2.1/120", "192.168.2.110", "172.17.0.1"]
                      /* module config */
                    • T
                      tomasz2101 @raywo
                      @raywo thx a lot now it is working.
                      Also i had to do docker binding to localhost
                      my config:
                      var config = {
                      	address: "",
                      	port: 8080,
                      	ipWhitelist: [],
                      	language: "en",
                      	timeFormat: 24,
                      	units: "metric",
                      			module: "clock",
                        bastilimbach
                        I updated the Github repository to include a working config file example. Thanks @raywo!
                          raywo Module Developer @bastilimbach
                          @bastilimbach Good addition to the docs. Thank you!
                          Maybe you should remove "192.168.2.1/120", "192.168.2.110" as it applies only to my configuration. Or you should explain it better.
                            bastilimbach @raywo
                            @raywo Oh yes you’re absolutely right.
