MMM-Carousel positional behaviour
5 Posts 5 Posters 2.2k Views 4 Watching
    sonic
    Hi all
    What’s the expected behaviour when using positional mode?
    I have two modules with the same position, but Carousel isn’t rotating them. The two modules both appear on screen (stacked or located as you’d expect with two modules sharing the same position).
    Should I expect them to appear like that at first, then end up rotating when the first rotation time period has taken place? Or should they rotate right from the start when MM is restarted?
    Obviously they should EVENTUALLY rotate but it would help to know what the expected behaviour is.
    config.js follows; any tips very welcome!
    cheers
            module: 'MMM-Carousel',
                transitionInterval: 5000,
    	    ignoreModules: [],
                mode: 'positional',
                bottom_left: {enabled: true}
    		module: 'alert',
    		module: 'clock',
    		position: 'top_left'
    		module: 'calendar',
    		position: 'top_left',
    					symbol: 'calendar-check-o ',
    					color: '#A7C5E3',
    					url: '...'
    					color: '#AAAAAA',
    					url: '...'
    		maximumNumberOfDays: 7,
    		maxTitleLength: 50,
    		fetchInterval: 60000,
    		fade:false,
    		colored: true
    		module: 'compliments',
    		position: 'lower_third',
    		// position: 'middle_center',
    			remoteFile: 'compliments.json'
    		module: 'currentweather',
    		position: 'top_right',
    			locationID: '...',
    			appid: '...',
    			useBeaufort: false
    		module: 'weatherforecast',
    			locationID: '...',
    			appid: '...',
    			showRainAmount: true,
    			appendLocationNameToHeader: false,
    			colored: true
    		module: 'MMM-daysToGo',
    		position: 'top_center',
        		targetDate: "2017-01-21 24:00:00",
        		toWhat: "...",
    		present: "...",
    		timesUp: "...",
    		singular: "day to go!",
    		plural: "days to go"
    		module: 'MMM-ImagesPhotos',
    		position: 'bottom_left',
    			opacity: 0.9,
    			animationSpeed: 500,
    			updateInterval: 5000,
    			getInterval: 10000,
    			maxWidth: "35%"
    		module: 'MMM-TextFile',
    			remoteFile: 'jsonfile.json',
    			updateInterval: 2000,
    			header: ''
      alang
      Did you find a solution to the problem? If so, please share!
        Sun
        You have to specific the postion where you what to rotate
                    transitionInterval: 10000,
                    ignoreModules: [],
                    mode: 'positional',
                    bottom_left: {enabled: true, ignoreModules: [], overrideTransitionInterval: 15000},
        G 1 Reply Last reply Apr 6, 2019, 1:15 PM Reply Quote 0
        • G Offline
          Gav @Sun
          @Sonic @alang @Sun I have the same problem. I am just testing this so I am using the following but no matter what I do the modules stack. I have tried this as well as other modules (eg currentweather) and everything does the same. Is Carousel no longer working?
                                  module: "weatherforecast",
                                  position: "bottom_left",
                                  header: "Weather Forecast",
                                          locationID: "2174003",
                                          appid: "secret!"
                                  module: "MMM-Bob-Ross",
                                          imgHeight: "30vh",
                                          videoHeight: "30vh",
                                          updateInterval: 1*60*60*1000,
                                          autoPlay: false
                                          mode: 'positional',
          K 1 Reply Last reply May 8, 2025, 4:49 PM Reply Quote 0
          • K Offline
            khrusher @Gav
            @Gav
            I know this is an old issue, but I solved it…adding here for future readers
