    MMM-Carousel positional behaviour
    5 Posts 5 Posters 2.6k Views 4 Watching
      sonic
      Hi all
      What’s the expected behaviour when using positional mode?
      I have two modules with the same position, but Carousel isn’t rotating them. The two modules both appear on screen (stacked or located as you’d expect with two modules sharing the same position).
      Should I expect them to appear like that at first, then end up rotating when the first rotation time period has taken place? Or should they rotate right from the start when MM is restarted?
      Obviously they should EVENTUALLY rotate but it would help to know what the expected behaviour is.
      config.js follows; any tips very welcome!
      cheers
              module: 'MMM-Carousel',
                  transitionInterval: 5000,
      	    ignoreModules: [],
                  mode: 'positional',
                  bottom_left: {enabled: true}
      		module: 'alert',
      		module: 'clock',
      		position: 'top_left'
      		module: 'calendar',
      		position: 'top_left',
      					symbol: 'calendar-check-o ',
      					color: '#A7C5E3',
      					url: '...'
      					color: '#AAAAAA',
      					url: '...'
      		maximumNumberOfDays: 7,
      		maxTitleLength: 50,
      		fetchInterval: 60000,
      		fade:false,
      		colored: true
      		module: 'compliments',
      		position: 'lower_third',
      		// position: 'middle_center',
      			remoteFile: 'compliments.json'
      		module: 'currentweather',
      		position: 'top_right',
      			locationID: '...',
      			appid: '...',
      			useBeaufort: false
      		module: 'weatherforecast',
      			locationID: '...',
      			appid: '...',
      			showRainAmount: true,
      			appendLocationNameToHeader: false,
      			colored: true
      		module: 'MMM-daysToGo',
      		position: 'top_center',
          		targetDate: "2017-01-21 24:00:00",
          		toWhat: "...",
      		present: "...",
      		timesUp: "...",
      		singular: "day to go!",
      		plural: "days to go"
      		module: 'MMM-ImagesPhotos',
      		position: 'bottom_left',
      			opacity: 0.9,
      			animationSpeed: 500,
      			updateInterval: 5000,
      			getInterval: 10000,
      			maxWidth: "35%"
      		module: 'MMM-TextFile',
      			remoteFile: 'jsonfile.json',
      			updateInterval: 2000,
      			header: ''
        alang
        Did you find a solution to the problem? If so, please share!
          Sun
          You have to specific the postion where you what to rotate
                      transitionInterval: 10000,
                      ignoreModules: [],
                      mode: 'positional',
                      bottom_left: {enabled: true, ignoreModules: [], overrideTransitionInterval: 15000},
          • G Offline
            Gav @Sun
            @Sonic @alang @Sun I have the same problem. I am just testing this so I am using the following but no matter what I do the modules stack. I have tried this as well as other modules (eg currentweather) and everything does the same. Is Carousel no longer working?
                                    module: "weatherforecast",
                                    position: "bottom_left",
                                    header: "Weather Forecast",
                                            locationID: "2174003",
                                            appid: "secret!"
                                    module: "MMM-Bob-Ross",
                                            imgHeight: "30vh",
                                            videoHeight: "30vh",
                                            updateInterval: 1*60*60*1000,
                                            autoPlay: false
                                            mode: 'positional',
            • K Offline
              khrusher @Gav
              @Gav
              I know this is an old issue, but I solved it…adding here for future readers
