    Modules assistance for MM newbie! Help!
    21 Posts 4 Posters 13.2k Views 4 Watching
    • F
      Fookes
      Please be gentle as I’m new to the game and I’ve tried to work things out for myself before seeking help. Sadly that point has now come!
      1. Trying to install module: PushBulletNotes. Cloned repository in Modules folder and added configuration block as shown in image below. When starting Mirror I just get a black screen. MagicMirror works fine before adding this config:
      [0_1520248551793_pushbullet.pdf](Uploading 100%)
      1. I’m going for a more ‘grown up’ mirror so the thought of it saying ‘Hi sexy’ isn’t appealing. In the config.js file all it shows is as attachment below. Where do I amend what it’s saying?:
      [0_1520248724921_Compliments.pdf](Uploading 100%)
      1. I have altered the stock weather module to show my location. It shows the temp in fahrenheit rather than celsius which I want. I’ve also noted that it doesn’t show the 5 day forecast on the MagicMirror when running - only today’s weather. Can someone kindly advise on both of these issues? Image to show below:
      [0_1520249023926_Weather.pdf](Uploading 100%)
      Thanks in advance for any assistance!
      N 1 Reply Last reply
      • N
        ninjabreadman @Fookes
        Hey @Fookes,
        Usually the screen going black with config changes means there’s a syntax error crashing the parser. Try pasting it into JSHint.
        For Compliments, see here for the config options. You can either make an object with four arrays in the config, or create a file from which to load them.
        Weather, I’ll have to look. I think the API/feed complains that I cannot use certain forecasts with the free WUndergound account. The same may be happening to you too.
        I can’t see you screenshots. You might instead copy/paste the text into a block quote, like so:
        // Code goes here
        F 1 Reply Last reply
        • F
          Fookes @ninjabreadman
          @ninjabreadman
          Hi, @ninjabreadman - apologies for the delay in responding. I really appreciate your contribution to my queries. Sadly, when I said I was a ‘newbie’ I really meant that I was a newbie! I simply don’t understand some of your answer. ‘Syntax error crashing the parser, try pasting into JSHint’ might as well be written in hieroglyphics. Could you explain in very basic language what I should be doing? I have made slight progress (although I’m unsure how!) on the Pushbullet notifications in so much as the screen is no longer blank and the module displays on my monitor. What it doesn’t do is show any notifications when they come through. It simply says ‘no new notifications’. Here’s (hopefully) how the module is set up. Can you spot anything which is stopping notifications working?
          module: “PushBulletNotes”,
          header: “iPhone Messages”,
          disabled: false,
          position: “bottom_left”, // Or any valid MagicMirror position.
          accessToken: “o.(middle bit left out)i”,
          numberOfNotifications: 5,
          showNotificationIcon: true,
          showMessage: true,
          showCount: true,
          fade: true,
          maxMsgCharacters: 50,
          maxHeaderCharacters: 32
          Thanks in advance!
          • Y
            yawns Moderator
            The problem with your code is, as with several other people (mostly on macs) wrong quotation marks.
            module: "PushBulletNotes",
            header: "iPhone Messages",
            disabled: false,
            position: "bottom_left", // Or any valid MagicMirror position.
            	accessToken: "o.(middle bit left out)i",
            	showMessage: true,
            	showCount: true,
            	fade: true,
            Look at the quotation marks. Left is correct, right is using wrong ones. I think this is a problem with Mac keyboard or mac software.
            • F
              Fookes
              Thanks for the response.
              Not that I’m doubting you for a second but wouldn’t that stop other modules working? I have other modules using quotation marks (denoting screen position, header etc) which seem to run without issue.
              Secondly, how would I go about changing these to the correct format as I only have a Mac to use.
              Thank you.
              • Y
                yawns Moderator
                That’s a bad question, as I cannot answer that. I don’t have any mac available, so I cannot test it.
                I don’t know if this is an unwanted feature - in this case - of the editor or of the entire operating system. On Windows I use “notepad++”, I’m sure there is something similar for Mac.
                • N
                  ninjabreadman @yawns
                  @yawns It’s usually Macs because they do “smart quote” replacement, including in TextEdit, the default text editor. Straight double quotes (") are different characters from open and close quotes (“ or ”). Such smart replacement done at a program level on certain word processors, like Microsoft Word, but not in things like Notepad, the default text editor for Windows. This is why it’s more of a problem for Mac users.
                  @Fookes The solution is to not use TextEdit (much more like WordPad) for any code. Use a true text editor like Atom, BBEdit, TextMate, etc. Download one, install it, and use that to open/edit/save your config and other code files.
                  • F
                    Fookes
                    @ninjabreadman - thanks for the info. As explained throughout the thread I’m the exact definition of a ‘newbie’. When detailing text editors such as TextEdit, Atom etc, what role do they play in what I am trying to achieve?
                    As an example:
                    I want to install a TP module I’ve found (as this Pushbullet one is). There is a ‘using this module’ section which tells us to add the following configuration block to the ‘modules’. I have simply been copy and pasting this configuration in to the config.js section and tweaking the parts I can/want to. How and why would I use Atom to do this? Genuine question - I simply have no idea. I’m eager to learn but clearly need basic guidance on this.
                    Appreciate it.
                    • N
                      @Fookes No problem. You need to use a program (app) to open any file. Right now, you’re using what came with your Mac (called TextEdit). But it’s much more of a note taking or word processing program than a text editor for code. It doesn’t understand code, and does things that break it. Once you’ve downloaded and installed Atom (by moving it to your ~/Applications folder on your Mac) you can run it then open the file, or right-click a file and select “Open with…” and choose Atom. Not only will it not break your code, it will colour-code (called “syntax-highlighting”) your code, show you where brackets/braces match, and can help to make your code legible (called “Beautify” in Atom).
                      For adding modules, check out this walkthrough for tips: https://forum.magicmirror.builders/topic/4231/how-to-add-modules-for-absolute-beginners
                      • F
                        Fookes
                        Have I actually been using TextEdit though? I simply ‘right click’ over what I want to copy from the modules section of the 3rd party modules page on MagicMirror2, before copying and then pasting in the config.js section. Where does TextEdit come in to my procedure?
                        I have downloaded and installed Atom as suggested. You suggest I 'open the file or right-click and select “open with…” ’ - What file am I opening or selecting to open with?
                        • N
                          @Fookes Yes, but how are you opening your config.js to paste in your options/configuration? There is an app/program that opens and interprets the file, then saves it again. Whatever you’re using, it is permitting MacOS to change your quotes, thereby breaking the file.
                          • F
                            Fookes
                            I’m simply (from the MagicMirror folder in terminal on Raspberry Pi - ‘pi@raspberrypi:~/MagicMirror $’ keying in ‘nano config/config.js’. I then paste and amend module stuff in there. I presume I’m doing this all wrong?
                            • N
                              Sorry @Fookes, when @yawns mentioned MacOS and you didn’t say you weren’t using a Mac, I assumed that to be the case (given the quotes problem). Did you install Atom on your own computer or the RPi? Are you editing your files on the RPi itself (via a keyboard, in Terminal) or are you connecting remotely from other computer (typically ssh)?
                              As a command-line text editor, nano respects quotes and should not cause a problem, although I typically avoid pasting code blocks – I find over ssh that the paste buffers and encodings can get weird.
                              • F
                                Fookes
                                @ninjabreadman - Hi.
                                I AM using a Mac! I’m simply VNC-ing into the Raspberry Pi. How can I easily attach images to my communications on this forum? Images of my procedure may help in explaining my situation clearly and concisely.
                                Regards
                                • N
                                  @Fookes Oh, understood. You can use the little art/photo icon to upload a photo in the forum.
                                  Are you pasting via VNC? I suggest using an SFTP client like FileZilla or CyberDuck.
                                  You can then connect to the RPi and edit files remotely (not download, edit, upload; both programs have an “edit” option that will let you edit and save remotely in an editor … change it to Atom for js/css/html files in the preferences).
                                  You can also use Terminal (in Applications > Utilities) to connect to your RPi via ssh (ex. ssh 192.168.0.100) to run commands remotely.
                                  • F
                                    Fookes
                                    Hi @ninjabreadman - Yes, I paste in to the config.js via VNC. I really appreciate your input and guidance on this. Would it be a request too far to ask you to breakdown the steps you take from start to finish to add a module? You suggest using an SFTP client but I have no knowledge of what this is, how it works, how I incorporate this in to what I’m doing and at what point. I’m happy to install whatever is recommended - I just need guidance on the process. I think you linked to a ‘newbie’s guide to installing a module’ which seemed to suggest the ‘cut and paste’ approach I have been doing - albeit probably on a PC rather than a Mac.
                                    I’d be very grateful but I appreciate it if my request is a request too far…
                                    • N
                                      Hi @Fookes,
                                      I’ll try. This is what I use for adding modules:
                                      Ingredients
                                      • Text Editor (e.g. Atom) ‑ that supports syntax highlighting, code formatting, and won’t break your code (i.e. not MacOS’ TextEdit)
                                      • SFTP Client (e.g. FileZilla)
                                      • Terminal
                                      • VNC Client (optional)
                                      Directions
                                      1. Connect to your MM via ssh in Terminal (e.g. ssh 192.168.0.101), and in your ssh session do the following:
                                        a. Change directories to ~/MagicMirror/modules
                                        b. Download your module with git clone (e.g. git clone https://github.com/matteodanelli/MMM-cryptocurrency.git)
                                        c. This will create the folder for your module
                                      2. Connect with your SFTP Client to your MM
                                        a. Navigate to your ~/MagicMirror/config directory
                                        b. Tell the SFTP Client to open/edit your config.js with your Text Editor (this can sometimes be configured in File > Preferences) or by right-clicking the file (to select “Open with…”)
                                        c. Copy the config options from the module’s Git Readme.md, website, etc. that you want to use
                                        d. Paste the config options into config.js that is open in your Text Editor
                                        e. Save the file, and the SFTP Client will upload the file back to your MM
                                      3. In Terminal (still in ssh) run pm2 restart mm or npm start dev in ~/MagicMirror/.
                                        a. Have a look at your mirror to see that the changes took, or use a VNC Client to connect to and view your mirror
                                      Hope that helps. Let me know if you have any questions.
                                      • F
                                        Fookes
                                        @ninjabreadman - Thanks, appreciate you doing this for me. In step one, I’m presuming you’re doing all of this on the Pi - not from a Mac or PC?
                                        • N
                                          @Fookes No problem. No, all of the above will be done from your separate Mac/PC. The directions explain how to use Terminal and SFTP Client to make changes as through you were in front of the machine. All of the apps (Text Editor, SFTP Client, and VNC Viewer) should be installed on your Mac/PC (read: not MM) remote machine.
                                          Otherwise, you can just follow the excellent How to add modules for absolute beginners thread which covers everything as done on the RPi.
                                          • F
                                            Fookes
                                            @ninjabreadman - Thank you. I shall give it a go shortly and let you know how I get on! Thanks again!
