    MMM-RMV "Loading data"
    15 Posts 2 Posters 6.7k Views 2 Watching
    • yawnsY Offline
      yawns Moderator
      Does it work with default stationid and destination?
        CvG
        No, it is not working with any value.
        • yawnsY Offline
          yawns Moderator
          Interesting. I requested an API key to test it
            CvG
            it still doesn’t work but I have tried something. I disabled every module but MMM-RMV and when I start npm directly I get an Error.
            Error: No connection data recieved. Error code 400
            • yawnsY Offline
              yawns Moderator @CvG
              @CvG
              Would you mind sharing your api key via chat with me? I still did not receive any feedback from the vendor
              Update: just received my api key
                CvG
                Thanks for you support. There ist an solved issue at the github page that might help you. The open one is mine.
                https://github.com/Com-Lum/MMM-RMV/issues/6
                • yawnsY Offline
                  yawns Moderator
                  Interesting. Using this does show connections for me:
                                  {       module: 'MMM-RMV',
                                          position: 'top_left',
                                                  apikey: 'xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx',
                                                  stationId: '3000001',
                  Using your config fails for me, debug console shows an error.
                                                  stationId: '3025547',
                  I hope I find some time tomorrow to dig into this.
                    CvG
                    Hmmmmmmmmm?
                    That is strange. I’ll check this when I’m back in my office at monday.
                    "… shows an error. ", means “loading data” in gui and error 400 or do you get something new?
                    When I use my browser to querry the information it works fine. So the data is available for this station.
                    Do you know a way to show the url the magicmirror backend uses? This is where my Linux knowlege ends.
                    • yawnsY Offline
                      @CvG
                      In node_helper.js you find //console.log(some thing with url)
                      Remove the // and restart your mirror. You will see the url in terminal, not browser
                        CvG
                        now its working.
                        My fault was that I misspelled the entry apiKey (I wrote it apikey. With a small k). I found out about this when I displayed the url because the accessId was empty. Now, with a capital letter K it works.
                        Thanks for this and you help
                        • yawnsY Offline
                          yawns Moderator
                          bummer. I didn’t notice that o.O
                            CvG
                            The “mean” thing is that your relay has the error too, but you wrote that it workes for you.
                            • yawnsY Offline
                              @CvG That’s because I tested on one machine and responded on another. I copied your config (and therefore your error) and just modified with my stationID.
                                CvG
                                yes, I assumed that but finaly you led me to the right solution.
