    MMM-RMV "Loading data"
    15 Posts 2 Posters 7.2k Views 2 Watching
    • Y Offline
      yawns Moderator @CvG
      @CvG
      Would you mind sharing your api key via chat with me? I still did not receive any feedback from the vendor
      Update: just received my api key
        CvG
        Thanks for you support. There ist an solved issue at the github page that might help you. The open one is mine.
        https://github.com/Com-Lum/MMM-RMV/issues/6
        • Y Offline
          yawns Moderator
          Interesting. Using this does show connections for me:
                          {       module: 'MMM-RMV',
                                  position: 'top_left',
                                          apikey: 'xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx',
                                          stationId: '3000001',
          Using your config fails for me, debug console shows an error.
                                          stationId: '3025547',
          I hope I find some time tomorrow to dig into this.
            CvG
            Hmmmmmmmmm?
            That is strange. I’ll check this when I’m back in my office at monday.
            "… shows an error. ", means “loading data” in gui and error 400 or do you get something new?
            When I use my browser to querry the information it works fine. So the data is available for this station.
            Do you know a way to show the url the magicmirror backend uses? This is where my Linux knowlege ends.
            • Y Offline
              @CvG
              In node_helper.js you find //console.log(some thing with url)
              Remove the // and restart your mirror. You will see the url in terminal, not browser
                CvG
                now its working.
                My fault was that I misspelled the entry apiKey (I wrote it apikey. With a small k). I found out about this when I displayed the url because the accessId was empty. Now, with a capital letter K it works.
                Thanks for this and you help
                • Y Offline
                  yawns Moderator
                  bummer. I didn’t notice that o.O
                    CvG
                    The “mean” thing is that your relay has the error too, but you wrote that it workes for you.
                    • Y Offline
                      @CvG That’s because I tested on one machine and responded on another. I copied your config (and therefore your error) and just modified with my stationID.
                        CvG
                        yes, I assumed that but finaly you led me to the right solution.
