    Further development of the MMM-Swipe module
    25 Posts 7 Posters 19.0k Views 7 Watching
    • N
      nowis
      Hi @richland007,
      could you figure out a solution with the help of @AxLed by now? If not, let me know and I will try to help you. I should definitely put the math-statistics module in the package.json, sorry for that.
      Edit: I just saw I removed it from the dependencies at some point, that was a mistake.
      About the error with electron: Here and there I get the error after adding submodules, but I’m still not sure when and how… When I have time I should check this, but it’s probably a problem with more than just my module.
      I hope this helps,
      Simon
      richland007R 1 Reply Last reply
      • richland007R
        richland007 @nowis
        @nowis Sorry for the late reply i did figure out the math statistic on my own “…the power of research on the internet” :)
        and also a simple npm install fixes “… the got 53 and expected 48 issue”
        Everything on my end is working nicely i got no errors on my Magic Mirror and i have a lot of modules… however i can’t test the MMM-Swipe …granted it is not installed in the exact position where it is going to ultimately be. Mirror’s Raspi is still on my desk hooked to the monitor, wired though with the sonic sensors… cause i just got done with the programming part and have not started with the physical built of the mirror yet but i had a couple of question regarding the wiring of the two sonic sensors!!
        Are both of the trigger pins for both sensors connected to the same Rpi GPIO?? How can i test if my hand movement can move the pages?? I have tried but nothing happens the module on the software side has no errors but i don’t know if it works!!
        How far apart should the centers of the 2 sensor pairs be from each other ultimately on the mirror frame??
        Any help will be greatly appreciated
        thank you
        Denis
        • N
          nowis
          @richland007: I’m glad you could figure a solution for your problems.
          Ragarding your questions: Yes, both trigger pins are connected to one RPi GPIO pin. It works fine for me.
          There are two ways for testing your movements:
          1. In the module-config, set a position: this will display “waiting for movement …” and will change to “Swipe Left” or “Swipe Right” for 2 seconds, if a movement is recognized.
          2. More precise method: In the module config, set “verbose” to true. This will print to the console (see attached image). The first line means where a potential swipe started. The next two rows give you the measured distanced used to detect a swipe. So far this does not mean we detected a swipe! Only if there is a line “----> Swipe Left” or “----> Swipe Right” a swipe is detected. This output helps you to figure out how fast do move your hand. Sometimes the sensors get noise and try to therefore try to detect a swipe. In this case you won’t see the last line, which means we do not recognize the false positive.
          The centers of sensors are 20cm apart from each other. In general you can mount them just as you like, since you can configure the swipe-speed
          I hope this helps! Just let me know if you need any further help.
          richland007R 2 Replies Last reply
          • richland007R
            richland007 @nowis
            @nowis Thank you very much for the quick reply i will try it as soon as i get some free time …can’t do much on the weekends. I will report back any changes or difficulties i might have
            have a great remeinder of the weekend
            Denis
            • richland007R
              richland007 @nowis
              @nowis Ok so i got the chance to try it with your suggestions and i guess my connections are right and it sort of works!!!
              I got to read a swipe only once … a Swipe Left and judging from the readings on the console it detects movement but i am unable to replicate any additional swipes granted they are very close to each other and not aligned.
              However do these numbers seem right to you?? judging from this pic that i am attaching …what are these reading in the 3 thousand range?
              Any pointer in the alignment or calibration of the sensors and when i get it to read the swipes left and right correctly does that mean the pages are going to be go left and right also meaning if i swipe from left to right the pages are going to ump one forward and if i swipe from light to left the MM pages are going to go backwards?? that’s our ultimate goal isn’t it
              thanks again
              Denis
              ps. I cant upload a image so here is a text copy of it
              Start: Right
              [MMM-Swipe] Left : [{“dist”:“158”},{“dist”:“3076”},{“dist”:“5593”},{“dist”:“13”},{“dist”:“280”}]
              [MMM-Swipe] Right: [{“dist”:“7”},{“dist”:“3054”},{“dist”:“8”},{“dist”:“165”},{“dist”:“237”}]
              [MMM-Swipe] ----> Swipe Left
              [MMM-Swipe] -------------------------
              [MMM-Swipe] Start: Left
              [MMM-Swipe] Left : [{“dist”:“4”},{“dist”:“2805”},{“dist”:“143”},{“dist”:“7”},{“dist”:“151”}]
              [MMM-Swipe] Right: [{“dist”:“12”},{“dist”:“9”},{“dist”:“12”},{“dist”:“154”},{“dist”:“3”}]
              N 1 Reply Last reply
              • N
                nowis @richland007
                @richland007 Hey, I am on vacation right now, so I cannot access my mirror but I will try to help you anyways.
                The output “Start: Right” means the application detected a distance smaller than rightDistance (from the config) and therefore checks if you made a swipe. In your example with the detected left swipe it found a value (7) for the right sensor and so checks if there is a valid swipe.
                For your second example it does not detect a valid swipe, since the first measurement for both sensors is lower than the threshold (I assume so?!). We assume your hand never covers both sensors, so we declare this event as invalid and therefore no swipe.
                To get a feeling for the sensors set calibrate to true and a position for the module in your config. This will print the measured distances for both sensors on your mirror. I experienced I have to make my hand very flat in order to trigger the sensors.
                Regarding the page increment/decrement: Just to be sure, a “Swipe Left” means you start at the right and move to the left. The right sensor is the one on your right side when you look at your mirror and vice versa. Currently a “Swipe Right” sends a PAGE_INCREMENT. If you want to change this, check the function socketNotificationReceived in the MMM-Swipe.js file.
                Hope this helps,
                Simon
                • N
                  nawak86 @nowis
                  @nowis Hello can you take a photo and video of your installation ? it’s difficult to properly setup motion detection.
                  how did you integrate the sensors on the mirror ?
                  Sor for my bad english
                  • T
                    thobach
                    You may also be interested in my gesture sensor module: https://github.com/thobach/MMM-Gestures, which is based on infra red, which I found more reliable and silent :) I developed it after a couple of iterations with ultra sonic sensors like the HC SR04, which didn’t satisfy my needs.
                    N 2 Replies Last reply
                    • N
                      nawak86 @thobach
                      @thobach hello, the plugin looks more accurate is it easy to set up?
                      can you show me a picture of the wiring?
                      I do not know if I will be able to install it,
                      it most difficult like MMM-Swipe no ?
                      T 1 Reply Last reply
                      • N
                        nawak86 @thobach
                        @thobach lets go i buy this : https://www.amazon.fr/WINGONEER-APDS-9960-ambiante-détection-mouvement/dp/B071VS21M4/ and https://www.ebay.fr/itm/GP2Y0A21YK0F-Capteur-distance-infrarouge-analogique-ARDUINO-robot-IR-SHARP-GP2/292499905194?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2649 i wait my product and i try ;)
                        • T
                          thobach @nawak86
                          @nawak86 Unfortunately, it is probably one of the most difficult modules as it consists of two sensors and an Arduino connected to the Pi. The wiring is described at https://github.com/thobach/MMM-Gestures/blob/master/Arduino/MagicMirror2/MagicMirror2.ino#L31 (Arduino) and https://github.com/thobach/MMM-Gestures/blob/master/README.MD. I don’t have a wiring picture.
                          You can see it in action though on https://www.youtube.com/watch?v=V8a6UgeoYOU.
                          • N
                            nawak86 @thobach
                            @thobach f*ck i dont see hardware who is required before !! so i must buy an arduino one can you tell me if it is that : https://www.amazon.fr/Elegoo-Carte-ATmega328P-ATMEGA16U2-Arduino/dp/B01N91PVIS/ ??? infact just plug sensor on arduino send library by software and connect to the raspberry with usb and git clone module et npm install ? for the movement it works with MMM-Pages ? sorry i’m a noob with that ;)
                            • N
                              nowis
                              Hi @nawak86, after setting up the two HC-SR04 sensors, I am not very happy with its performance. It basically works, also with the Pages module.
                              It sounds like @thobach is pretty happy with his gestures module (even you need an Arduino besides the Pi, right?).
                              Here is a picture of how I integrated the sensors into my mirror, I could maybe upload a video in the next days.
                              For connecting everything you need the two sensors, jumper wires, 2 times a 1k Ohm resistance, a breadboard.
                              • N
                                nawak86
                                hello thank you for your answer @nowis I can try both solutions and make a choice. I’m not against a small video, I’m waiting for @thobach confirms me that the arduino product on amazon is the good. MMM-Swipe works with MMM-Pages but I do not know how MMM-Gesture changes page
                                • N
                                  nawak86
                                  Allo ? ? :p no answer ? :(
