    Email
    92 Posts 36 Posters 146.4k Views 39 Watching
    • justjim1220J Offline
      justjim1220 Module Developer @umairshah
      @umairshah
      @ime90
      Can you show your config.js file here?
      Make sure you hide personal info…
      Jim Hallock - 1995
      • I Offline
        ime90 @justjim1220
        @justjim1220
        var config = {
        address: “localhost”,
        port: 8080,
        ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”],
        language: "en",
        timeFormat: 24,
        units: "metric",
        		module: "alert",
        		module: 'email',
                        position: 'bottom_left',
                        header: 'Email',
                            accounts: [
                                    user: '**@gmail.com',
                                    password: '**',
                                    host: 'imap.gmail.com',
                                    port: 993,
                                    tls: true,
                                    authTimeout: 10000,
                                    numberOfEmails: 2,
                            fade: true,
                            maxCharacters: 30,
        		    subjectLength: 50
        		module: "updatenotification",
        		position: "top_bar"
        		module: "clock",
        		position: "top_left"
        		header: "US Holidays",
        					symbol: "calendar-check-o ",
        		module: "compliments",
        		position: "lower_third"
        		module: "currentweather",
        			locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
        		module: "weatherforecast",
        		header: "Weather Forecast",
        			locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
        		module: "newsfeed",
        		position: "bottom_bar",
        			feeds: [
        					title: "New York Times",
        			showSourceTitle: true,
        			showPublishDate: true
        if (typeof module !== “undefined”) {module.exports = config;}
        justjim1220J 2 Replies Last reply Reply Quote 0
          justjim1220 Module Developer @ime90
          @ime90
          Try changing the fade to false.
          Make sure your email address and password are case correct (uppercase and lowercase).
          Other than that, I don’t see an issue with the syntax.
          You did change the config.js.sample to config.js, correct?
          Jim Hallock - 1995
            @ime90
            Also…
            I have found that some modules don’t work as well with the single quotes (’ ').
            Try changing them all to the double quotes (" ")
            Jim Hallock - 1995
            • I Offline
              ime90 @justjim1220
              @justjim1220
              Yeah, I changed it of course. I’ll try out the double quotation marks and all you recommended.
              Can you just tell me, does this module work for you at this time for Gmail or any other mail?
                @ime90
                Yes, it works for me with my Gmail, my Hotmail, and my Yahoo mail. But I have since decided to link all three to my Gmail so I use just the one to receive all of them. But, I have tested it with all three and it does work.
                Jim Hallock - 1995
                I 1 Reply Last reply Reply Quote 1
                • I Offline
                  ime90 @justjim1220
                  @justjim1220
                  Tried it all but still getting “No new Mail” text. I dunno where I’m going wrong. Could you please copy your module text (or send me on private) so I can compare them. Also, did you do anything on your own gmail account that could help? I changed the imap settings.
                  I get this error:
                  Email notifier error:  { Error: Web login required: https://support.google.com/mail/answer/78754 (Failure)
                      at Connection._resTagged (/home/pi/MagicMirror/modules/email/node_modules/imap/lib/Connection.js:1502:11)
                  at emitOne (events.js:96:13)
                      at Parser.emit (events.js:191:7)
                      at Parser._resTagged (/home/pi/MagicMirror/modules/email/node_modules/imap/lib/Parser.js:175:10)
                      at Parser._parse (/home/pi/MagicMirror/modules/email/node_modules/imap/lib/Parser.js:139:16)
                      at Parser._tryread (/home/pi/MagicMirror/modules/email/node_modules/imap/lib/Parser.js:82:15)
                      at TLSSocket.Parser._cbReadable (/home/pi/MagicMirror/modules/email/node_modules/imap/lib/Parser.js:53:12)
                      at emitNone (events.js:86:13)
                      at TLSSocket.emit (events.js:188:7) type: 'no', textCode: 'ALERT', source: 'authentication' }
                    @ime90
                    Follow the link given in your error…
                    Then follow the instructions to set your account to use less secure apps with your account…
                    I’m pretty sure that I had to do that to get mine to work.
                    There are other things to try as well.
                    Jim Hallock - 1995
                    I 1 Reply Last reply Reply Quote 2
                    • I Offline
                      ime90 @justjim1220
                      @justjim1220
                      Yeah, I did.
                      Sorry for bugging you and thanks for the help. I dunno what the error is but it does seem to be connected to the mirrors inability to connect to the gmail servers. I’ll keep on trucking. If anybody has a clue what to do, I’m open for suggestions :D
                        @ime90
                        Do you have your Gmail account set up with any 2-step verification?
                        If so, that would be a problem as well.
                        Jim Hallock - 1995
                          @ime90
                          Another thing to try is to rebuild the mirror…
                          npm rebuild
                          Another option is to make sure you have all the latest updates for everything… Computer OS, RasPi, The mirror, node, electron, etc.
                          After a full updating, reboot, rebuild. Try again.
                          I have found that most of the problems relating to ‘no new emails’ is because you have your email open on another device, so it appears to the mirror module that they have been read and nothing new is coming up for it to retrieve.
                          Jim Hallock - 1995
                          • L Offline
                            letshin
                            Hi, would it be possible to modify the frequency at which the module checks for new emails please, so as to minimise processor load?
                            G 1 Reply Last reply Reply Quote 1
                              Seratio
                              Hi Guys,
                              while creating the configuration for my magicmirror, i experienced that showing emails isn’t working, if fade is set to true… So i debugged this nearly two hours without any knowledge of javascript :D
                              The problem is, that the variable “count” isnt working as desired. Its not increasing. So i created a patch for your:
                              58d57
                              <         var e = 0;
                              125,127c124,126
                              <                       var steps = that.payload.slice(0, that.config.numberOfEmails).length - startingPoint;
                              <                       if (e >= startingPoint) {
                              <                             var currentStep = e - startingPoint;
                              >                         if (count >= startingPoint) {
                              >                             var currentStep = count - startingPoint;
                              130d128
                              <                       e++;
                              Hopefuly this will fix your problems with the fade option.
                              Regards
                              Alex
                              • G Offline
                                gismo2006 @letshin
                                @letshin said in Email:
                                Good Morning, are they any news?
                                greets gismo2006a
                                • I Offline
                                  icke
                                  Hello Guys , anyone knows a possibilty to get the subject not dimmed?
                                  (customs.css)
                                  Regards icke
                                  • U Offline
                                    UniqueUsername
                                    It’s just keeping me on “Loading”. WHY?
                                    • 5 / 5
