    Email
    92 Posts 36 Posters 149.3k Views 39 Watching
    • U
      umairshah
      I have added the module in Default folder named it email
      and added the module in config.js from the Github link followed here
      https://github.com/ronny3050/email-mirror
      but nothing is shown on screen.
      Mykle1M justjim1220J 2 Replies Last reply
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @umairshah
        @umairshah
        The email module folder goes in the modules folder but not inside the default folder
        U 1 Reply Last reply
        • U
          umairshah @Mykle1
          @Mykle1 I have moved it to module but it is not working
          • E
            E3V3A @amanzimdwini
            • U
              umairshah
              When I wrote the command npm install
              it showed error no License and no repository field found
              then I added repository and license
              but it shows that email@0.0.1 is not valid license spdx expression
              “license” : {
              “type” : “MIT”
              • I
                ime90
                I’m still having trouble.
                I believe I setup everything correctly. Added the subjectlength at the end, allowed IMAP in my gmail account, but still, after loading the module won’t connect to my mail and doesn’t show anything. Is anyone else having trouble with this?
                • justjim1220J
                  justjim1220 Module Developer @umairshah
                  @umairshah
                  If you add a module to the default folder, you have to make the necessary changes to the default.js file to include it.
                  It’s just better to put it in the modules folder.
                  Jim Hallock - 1995
                  • U
                    umairshah @justjim1220
                    @justjim1220 said in Email:
                    @justjim
                    It is not in default folder, it is in the module folder.
                    when I download and tried to install it gave error of no repository and license field in package.json, but when I add those fields in package.json then it showed spdx expression error.
                    justjim1220J 1 Reply Last reply
                    • justjim1220J
                      @umairshah
                      @ime90
                      Can you show your config.js file here?
                      Make sure you hide personal info…
                      Jim Hallock - 1995
                      I 1 Reply Last reply
                      • I
                        ime90 @justjim1220
                        @justjim1220
                        var config = {
                        address: “localhost”,
                        port: 8080,
                        ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”],
                        language: "en",
                        timeFormat: 24,
                        units: "metric",
                        		module: "alert",
                        		module: 'email',
                                        position: 'bottom_left',
                                        header: 'Email',
                                            accounts: [
                                                    user: '**@gmail.com',
                                                    password: '**',
                                                    host: 'imap.gmail.com',
                                                    port: 993,
                                                    tls: true,
                                                    authTimeout: 10000,
                                                    numberOfEmails: 2,
                                            fade: true,
                                            maxCharacters: 30,
                        		    subjectLength: 50
                        		module: "updatenotification",
                        		position: "top_bar"
                        		module: "clock",
                        		position: "top_left"
                        		header: "US Holidays",
                        					symbol: "calendar-check-o ",
                        		module: "compliments",
                        		position: "lower_third"
                        		module: "currentweather",
                        			locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
                        		module: "weatherforecast",
                        		header: "Weather Forecast",
                        			locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
                        		module: "newsfeed",
                        		position: "bottom_bar",
                        			feeds: [
                        					title: "New York Times",
                        			showSourceTitle: true,
                        			showPublishDate: true
                        if (typeof module !== “undefined”) {module.exports = config;}
                        • justjim1220J
                          justjim1220 Module Developer @ime90
                          @ime90
                          Try changing the fade to false.
                          Make sure your email address and password are case correct (uppercase and lowercase).
                          Other than that, I don’t see an issue with the syntax.
                          You did change the config.js.sample to config.js, correct?
                          Jim Hallock - 1995
                          • justjim1220J
                            @ime90
                            Also…
                            I have found that some modules don’t work as well with the single quotes (’ ').
                            Try changing them all to the double quotes (" ")
                            Jim Hallock - 1995
                            • I
                              ime90 @justjim1220
                              @justjim1220
                              Yeah, I changed it of course. I’ll try out the double quotation marks and all you recommended.
                              Can you just tell me, does this module work for you at this time for Gmail or any other mail?
                              • justjim1220J
                                @ime90
                                Yes, it works for me with my Gmail, my Hotmail, and my Yahoo mail. But I have since decided to link all three to my Gmail so I use just the one to receive all of them. But, I have tested it with all three and it does work.
                                Jim Hallock - 1995
                                • I
                                  ime90 @justjim1220
                                  @justjim1220
                                  Tried it all but still getting “No new Mail” text. I dunno where I’m going wrong. Could you please copy your module text (or send me on private) so I can compare them. Also, did you do anything on your own gmail account that could help? I changed the imap settings.
                                  I get this error:
                                  Email notifier error:  { Error: Web login required: https://support.google.com/mail/answer/78754 (Failure)
                                      at Connection._resTagged (/home/pi/MagicMirror/modules/email/node_modules/imap/lib/Connection.js:1502:11)
                                  at emitOne (events.js:96:13)
                                      at Parser.emit (events.js:191:7)
                                      at Parser._resTagged (/home/pi/MagicMirror/modules/email/node_modules/imap/lib/Parser.js:175:10)
                                      at Parser._parse (/home/pi/MagicMirror/modules/email/node_modules/imap/lib/Parser.js:139:16)
                                      at Parser._tryread (/home/pi/MagicMirror/modules/email/node_modules/imap/lib/Parser.js:82:15)
                                      at TLSSocket.Parser._cbReadable (/home/pi/MagicMirror/modules/email/node_modules/imap/lib/Parser.js:53:12)
                                      at emitNone (events.js:86:13)
                                      at TLSSocket.emit (events.js:188:7) type: 'no', textCode: 'ALERT', source: 'authentication' }
                                  • justjim1220J
                                    @ime90
                                    Follow the link given in your error…
                                    Then follow the instructions to set your account to use less secure apps with your account…
                                    I’m pretty sure that I had to do that to get mine to work.
                                    There are other things to try as well.
                                    Jim Hallock - 1995
                                    Reply Quote 2
                                    • I
                                      ime90 @justjim1220
                                      @justjim1220
                                      Yeah, I did.
                                      Sorry for bugging you and thanks for the help. I dunno what the error is but it does seem to be connected to the mirrors inability to connect to the gmail servers. I’ll keep on trucking. If anybody has a clue what to do, I’m open for suggestions :D
                                      • justjim1220J
                                        @ime90
                                        Do you have your Gmail account set up with any 2-step verification?
                                        If so, that would be a problem as well.
                                        Jim Hallock - 1995
                                        • justjim1220J
                                          @ime90
                                          Another thing to try is to rebuild the mirror…
                                          npm rebuild
                                          Another option is to make sure you have all the latest updates for everything… Computer OS, RasPi, The mirror, node, electron, etc.
                                          After a full updating, reboot, rebuild. Try again.
                                          I have found that most of the problems relating to ‘no new emails’ is because you have your email open on another device, so it appears to the mirror module that they have been read and nothing new is coming up for it to retrieve.
                                          Jim Hallock - 1995
                                          • L
                                            letshin
                                            Hi, would it be possible to modify the frequency at which the module checks for new emails please, so as to minimise processor load?
                                            G 1 Reply Last reply
                                            • 4 / 5
