    Email
    92 Posts 36 Posters 149.3k Views 39 Watching
    • G
      Gxnfr Ali @apm1007
      @apm1007 hello
        MSimonart @strawberry 3.141
        @strawberry-3.141 Ok i’ll try, thanks
        • G
          Gxnfr Ali @MSimonart
          @MSimonart
          no new email show
            secblizz
            Same problem here. The module recieves the Mails but they weren’t shown in the mirror
            //edit: fixed my problem. Fade has to be false…
            • U
              umairshah
              I have added the module in Default folder named it email
              and added the module in config.js from the Github link followed here
              https://github.com/ronny3050/email-mirror
              but nothing is shown on screen.
              Mykle1M justjim1220J 2 Replies Last reply Reply Quote 0
              • Mykle1M
                Mykle1 Project Sponsor Module Developer @umairshah
                @umairshah
                The email module folder goes in the modules folder but not inside the default folder
                U 1 Reply Last reply Reply Quote 0
                • U
                  umairshah @Mykle1
                  @Mykle1 I have moved it to module but it is not working
                  • E
                    E3V3A @amanzimdwini
                    • U
                      umairshah
                      When I wrote the command npm install
                      it showed error no License and no repository field found
                      then I added repository and license
                      but it shows that email@0.0.1 is not valid license spdx expression
                      “license” : {
                      “type” : “MIT”
                      • I
                        ime90
                        I’m still having trouble.
                        I believe I setup everything correctly. Added the subjectlength at the end, allowed IMAP in my gmail account, but still, after loading the module won’t connect to my mail and doesn’t show anything. Is anyone else having trouble with this?
                        • justjim1220J
                          justjim1220 Module Developer @umairshah
                          @umairshah
                          If you add a module to the default folder, you have to make the necessary changes to the default.js file to include it.
                          It’s just better to put it in the modules folder.
                          Jim Hallock - 1995
                          • U
                            umairshah @justjim1220
                            @justjim1220 said in Email:
                            @justjim
                            It is not in default folder, it is in the module folder.
                            when I download and tried to install it gave error of no repository and license field in package.json, but when I add those fields in package.json then it showed spdx expression error.
                            • justjim1220J
                              @umairshah
                              @ime90
                              Can you show your config.js file here?
                              Make sure you hide personal info…
                              Jim Hallock - 1995
                              • I
                                ime90 @justjim1220
                                @justjim1220
                                var config = {
                                address: “localhost”,
                                port: 8080,
                                ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”],
                                language: "en",
                                timeFormat: 24,
                                units: "metric",
                                		module: "alert",
                                		module: 'email',
                                                position: 'bottom_left',
                                                header: 'Email',
                                                    accounts: [
                                                            user: '**@gmail.com',
                                                            password: '**',
                                                            host: 'imap.gmail.com',
                                                            port: 993,
                                                            tls: true,
                                                            authTimeout: 10000,
                                                            numberOfEmails: 2,
                                                    fade: true,
                                                    maxCharacters: 30,
                                		    subjectLength: 50
                                		module: "updatenotification",
                                		position: "top_bar"
                                		module: "clock",
                                		position: "top_left"
                                		header: "US Holidays",
                                					symbol: "calendar-check-o ",
                                		module: "compliments",
                                		position: "lower_third"
                                		module: "currentweather",
                                			locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
                                		module: "weatherforecast",
                                		header: "Weather Forecast",
                                			locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
                                		module: "newsfeed",
                                		position: "bottom_bar",
                                			feeds: [
                                					title: "New York Times",
                                			showSourceTitle: true,
                                			showPublishDate: true
                                if (typeof module !== “undefined”) {module.exports = config;}
                                • justjim1220J
                                  justjim1220 Module Developer @ime90
                                  @ime90
                                  Try changing the fade to false.
                                  Make sure your email address and password are case correct (uppercase and lowercase).
                                  Other than that, I don’t see an issue with the syntax.
                                  You did change the config.js.sample to config.js, correct?
                                  Jim Hallock - 1995
                                  • justjim1220J
                                    @ime90
                                    Also…
                                    I have found that some modules don’t work as well with the single quotes (’ ').
                                    Try changing them all to the double quotes (" ")
                                    Jim Hallock - 1995
                                    • I
                                      ime90 @justjim1220
                                      @justjim1220
                                      Yeah, I changed it of course. I’ll try out the double quotation marks and all you recommended.
                                      Can you just tell me, does this module work for you at this time for Gmail or any other mail?
                                      • justjim1220J
                                        @ime90
                                        Yes, it works for me with my Gmail, my Hotmail, and my Yahoo mail. But I have since decided to link all three to my Gmail so I use just the one to receive all of them. But, I have tested it with all three and it does work.
                                        Jim Hallock - 1995
                                        I 1 Reply Last reply Reply Quote 1
                                        • I
                                          ime90 @justjim1220
                                          @justjim1220
                                          Tried it all but still getting “No new Mail” text. I dunno where I’m going wrong. Could you please copy your module text (or send me on private) so I can compare them. Also, did you do anything on your own gmail account that could help? I changed the imap settings.
                                          I get this error:
                                          Email notifier error:  { Error: Web login required: https://support.google.com/mail/answer/78754 (Failure)
                                              at Connection._resTagged (/home/pi/MagicMirror/modules/email/node_modules/imap/lib/Connection.js:1502:11)
                                          at emitOne (events.js:96:13)
                                              at Parser.emit (events.js:191:7)
                                              at Parser._resTagged (/home/pi/MagicMirror/modules/email/node_modules/imap/lib/Parser.js:175:10)
                                              at Parser._parse (/home/pi/MagicMirror/modules/email/node_modules/imap/lib/Parser.js:139:16)
                                              at Parser._tryread (/home/pi/MagicMirror/modules/email/node_modules/imap/lib/Parser.js:82:15)
                                              at TLSSocket.Parser._cbReadable (/home/pi/MagicMirror/modules/email/node_modules/imap/lib/Parser.js:53:12)
                                              at emitNone (events.js:86:13)
                                              at TLSSocket.emit (events.js:188:7) type: 'no', textCode: 'ALERT', source: 'authentication' }
                                          • justjim1220J
                                            @ime90
                                            Follow the link given in your error…
                                            Then follow the instructions to set your account to use less secure apps with your account…
                                            I’m pretty sure that I had to do that to get mine to work.
                                            There are other things to try as well.
                                            Jim Hallock - 1995
                                            I 1 Reply Last reply Reply Quote 2
                                            • 4 / 5
