    Email
    92 Posts 36 Posters 143.7k Views 39 Watching
      stephenmelody
      Hey @ronny3050, is there a way to only show the sender’s name and not their email address?
        MSimonart @davidrq7
        @davidrq7 Do you remember what you did to solve this? cause I have the same problem
          MSimonart
          Hi, when starting up the Mirror, email shows loading…
          in my terminal i see the following:
          NEW MAIL
          NEW MAIL
          NEW MAIL
          Email notifier error: { Error: Timed out while autenticating with server at Timeout._onTimeout (/home/pi/MagicMirror/modules/email/node_modules/imap/lib/Connection
          my config looks good,
          Accounts: [
          user: ‘XX@hotmail.com’,
          password: ‘’,
          host: ‘imap-mail.outlook.com’,
          port: 993,
          tls: true,
          authTimeout: 10000,
          numberOfEmails: 5
          fade: true,
          maxCharacters: 30
            MSimonart
            ok, it works, now for the css of the .address text, the text is not well readable on the mirror, there is like some sort of gradient or something effect on the font/text. How do I disable this?
            • strawberry 3.141S Offline
              strawberry 3.141 Project Sponsor Module Developer @MSimonart
              @MSimonart here is no gradient effect, probably you mean the default magicmirror class dimmed, you can overwrite it for that module in the custom css
              .email .dimmed {
                color: #aaa;
              • G Offline
                Gxnfr Ali @apm1007
                @apm1007 hello
                  MSimonart @strawberry 3.141
                  @strawberry-3.141 Ok i’ll try, thanks
                  • G Offline
                    Gxnfr Ali @MSimonart
                    @MSimonart
                    no new email show
                      secblizz
                      Same problem here. The module recieves the Mails but they weren’t shown in the mirror
                      //edit: fixed my problem. Fade has to be false…
                      • U Offline
                        umairshah
                        I have added the module in Default folder named it email
                        and added the module in config.js from the Github link followed here
                        https://github.com/ronny3050/email-mirror
                        but nothing is shown on screen.
                        Mykle1M justjim1220J 2 Replies Last reply Reply Quote 0
                          Mykle1 Project Sponsor Module Developer @umairshah
                          @umairshah
                          The email module folder goes in the modules folder but not inside the default folder
                          U 1 Reply Last reply Reply Quote 0
                          • U Offline
                            umairshah @Mykle1
                            @Mykle1 I have moved it to module but it is not working
                            • E Offline
                              E3V3A @amanzimdwini
                              • U Offline
                                umairshah
                                When I wrote the command npm install
                                it showed error no License and no repository field found
                                then I added repository and license
                                but it shows that email@0.0.1 is not valid license spdx expression
                                “license” : {
                                “type” : “MIT”
                                • I Offline
                                  ime90
                                  I’m still having trouble.
                                  I believe I setup everything correctly. Added the subjectlength at the end, allowed IMAP in my gmail account, but still, after loading the module won’t connect to my mail and doesn’t show anything. Is anyone else having trouble with this?
                                  • justjim1220J Offline
                                    justjim1220 Module Developer @umairshah
                                    @umairshah
                                    If you add a module to the default folder, you have to make the necessary changes to the default.js file to include it.
                                    It’s just better to put it in the modules folder.
                                    Jim Hallock - 1995
                                    • U Offline
                                      umairshah @justjim1220
                                      @justjim1220 said in Email:
                                      @justjim
                                      It is not in default folder, it is in the module folder.
                                      when I download and tried to install it gave error of no repository and license field in package.json, but when I add those fields in package.json then it showed spdx expression error.
                                        @umairshah
                                        @ime90
                                        Can you show your config.js file here?
                                        Make sure you hide personal info…
                                        Jim Hallock - 1995
                                        • I Offline
                                          ime90 @justjim1220
                                          @justjim1220
                                          var config = {
                                          address: “localhost”,
                                          port: 8080,
                                          ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”],
                                          language: "en",
                                          timeFormat: 24,
                                          units: "metric",
                                          		module: "alert",
                                          		module: 'email',
                                                          position: 'bottom_left',
                                                          header: 'Email',
                                                              accounts: [
        user: '**@gmail.com',
        password: '**',
        host: 'imap.gmail.com',
        port: 993,
        tls: true,
        authTimeout: 10000,
        numberOfEmails: 2,
                                                              fade: true,
                                                              maxCharacters: 30,
                                          		    subjectLength: 50
                                          		module: "updatenotification",
                                          		position: "top_bar"
                                          		module: "clock",
                                          		position: "top_left"
                                          		header: "US Holidays",
                                          					symbol: "calendar-check-o ",
                                          		module: "compliments",
                                          		position: "lower_third"
                                          		module: "currentweather",
                                          			locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
                                          		module: "weatherforecast",
                                          		header: "Weather Forecast",
                                          			locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
                                          		module: "newsfeed",
                                          		position: "bottom_bar",
                                          			feeds: [
                                          					title: "New York Times",
                                          			showSourceTitle: true,
                                          			showPublishDate: true
                                          if (typeof module !== “undefined”) {module.exports = config;}
                                            justjim1220 Module Developer @ime90
                                            @ime90
                                            Try changing the fade to false.
                                            Make sure your email address and password are case correct (uppercase and lowercase).
                                            Other than that, I don’t see an issue with the syntax.
                                            You did change the config.js.sample to config.js, correct?
                                            Jim Hallock - 1995
                                            • 4 / 5
