    Email
    92 Posts 36 Posters 141.5k Views 39 Watching
      Peter_van_Evert
      Hello ronny3050, the module is great, but after a while the module stands still. On my Mobilphone there are messages about new emails but your email Module does nothing. After a restart from the raspberry pi, everything is ok again, but after a few hours the same… Could you help me ?
      Yours Peter van Evert
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @Peter_van_Evert
        @Peter_van_Evert hes offline since two months, you probably have more success with open an issue on github
          ronny3050 Module Developer @strawberry 3.141
          @strawberry-3.141 @Peter_van_Evert I apologize for not being able to get back to you sooner - been busy with grad school. :( I replied on the issue on github. Thanks! :)
          • Z Offline
            zman3
            can anyone think of a reason the email is not updating to show new emails? i’m very new to this stuff, the temperature module is updating the temperature so its still connected.
            thanks
              Peter_van_Evert @zman3
              @zman3 I got the same problem and only one solution, till now. Press CTRL(STRG) and R to restart the magic mirror client. After that the emails are ok, till 2-3 hours… :)
                ronny3050 Module Developer @Peter_van_Evert
                @Peter_van_Evert This is really strange. I have not faced this myself.
                I think it is because your email client stops responding after 2-3 hours due to security reasons, perhaps :/
                  ronny3050 Module Developer @Guest
                  @wjdw87 This usually happens due to two reasons:
                  1. Connection to your mail client is not possible - try the two-factor authentication mentioned before for using Gmail, or your credentials are wrong.
                  2. Try restarting mirror.
                  • E Offline
                    edsulst
                    Is it possible to sroll the subject instead of putting a limit to the number of characters ?
                      pepemujica
                      Hi! is it possible to use it in emails requesting 2nd factor?
                        davidrq7
                        Hi guys can any 1 help me? Email module shows all the time no new emails, and the console looks like this: 0_1491837734246_17857461_1549238255109393_1377519403_n.jpg
                        Edit: Solved. Just added “subjectlength: 50” at the end of script and works fine :)
                        • G Offline
                          Gungnir83
                          I refer to the possibility of a multiaccount module.
                          I tried to make 2 directories email_a and email_b, uninstalled the module, customized the mail.js und installed it again.
                          In the “global” config I added both modules into the array with their new names (email_a email_b) with all the other neccessary information like the auth…
                          But when I start the mirror app, nothing happens. I see, that the helpers start, but no tries to fetch mails.
                          And no errors.
                          Any suggestions?
                            apm1007 @ronny3050
                            @ronny3050 i would like to display only unread emails. thank you.
                            • G Offline
                              gismo2006
                              I use this modul for a long time. but now I have a little question,
                              is it possible to set a intervall to check new emails?? Like every 10 Minutes for example.
                              And if it isn´t possible can I easy put this option in any way?
                              I have to say my coding experencie isn´t very good, so because there is a easy way. :-)
                              greets gismo
                                Updated email module.
                                Now supports:
                                • Multiple email accounts
                                • Will not crash on too many unread emails
                                • Better fetching of recent and unread emails
                                  ronny3050 Module Developer @eugenelai
                                  @eugenelai @apm1007 @Gungnir83 Please update. :)
                                    Preve
                                    Done the update and now email is “Loading”. Nothing more than this.
                                    Anyone knows why?
                                    The bottom error I got after the “npm install”.
                                      ronny3050 Module Developer @Preve
                                      @Preve Thanks for the heads up. The bottom parts are warnings and have nothing to do with the module not working. Loading for a long time indicates problem with communicating with your email service.
                                        rodofrn @ronny3050
                                        @ronny3050 I have the same problem as Preve, I have tried multiple email accts, and nothing. Happened after I updated MM. Any ideas?
                                          stephenmelody
                                          Hey @ronny3050, is there a way to only show the sender’s name and not their email address?
                                            MSimonart @davidrq7
                                            @davidrq7 Do you remember what you did to solve this? cause I have the same problem
                                            • 3 / 5
