    Email
    92 Posts 36 Posters 149.3k Views 39 Watching
    • strawberry 3.141S
      strawberry 3.141 Project Sponsor Module Developer @Peter_van_Evert
      @Peter_van_Evert hes offline since two months, you probably have more success with open an issue on github
      R 1 Reply Last reply
        ronny3050 Module Developer @strawberry 3.141
        @strawberry-3.141 @Peter_van_Evert I apologize for not being able to get back to you sooner - been busy with grad school. :( I replied on the issue on github. Thanks! :)
        • Z
          zman3
          can anyone think of a reason the email is not updating to show new emails? i’m very new to this stuff, the temperature module is updating the temperature so its still connected.
          thanks
          P 1 Reply Last reply
            Peter_van_Evert @zman3
            @zman3 I got the same problem and only one solution, till now. Press CTRL(STRG) and R to restart the magic mirror client. After that the emails are ok, till 2-3 hours… :)
              ronny3050 Module Developer @Peter_van_Evert
              @Peter_van_Evert This is really strange. I have not faced this myself.
              I think it is because your email client stops responding after 2-3 hours due to security reasons, perhaps :/
                ronny3050 Module Developer @Guest
                @wjdw87 This usually happens due to two reasons:
                1. Connection to your mail client is not possible - try the two-factor authentication mentioned before for using Gmail, or your credentials are wrong.
                2. Try restarting mirror.
                • E
                  edsulst
                  Is it possible to sroll the subject instead of putting a limit to the number of characters ?
                    pepemujica
                    Hi! is it possible to use it in emails requesting 2nd factor?
                      davidrq7
                      Hi guys can any 1 help me? Email module shows all the time no new emails, and the console looks like this: 0_1491837734246_17857461_1549238255109393_1377519403_n.jpg
                      Edit: Solved. Just added “subjectlength: 50” at the end of script and works fine :)
                      M 1 Reply Last reply
                      • G
                        Gungnir83
                        I refer to the possibility of a multiaccount module.
                        I tried to make 2 directories email_a and email_b, uninstalled the module, customized the mail.js und installed it again.
                        In the “global” config I added both modules into the array with their new names (email_a email_b) with all the other neccessary information like the auth…
                        But when I start the mirror app, nothing happens. I see, that the helpers start, but no tries to fetch mails.
                        And no errors.
                        Any suggestions?
                        • A
                          apm1007 @ronny3050
                          @ronny3050 i would like to display only unread emails. thank you.
                          G 1 Reply Last reply
                          • G
                            gismo2006
                            I use this modul for a long time. but now I have a little question,
                            is it possible to set a intervall to check new emails?? Like every 10 Minutes for example.
                            And if it isn´t possible can I easy put this option in any way?
                            I have to say my coding experencie isn´t very good, so because there is a easy way. :-)
                            greets gismo
                              Updated email module.
                              Now supports:
                              • Multiple email accounts
                              • Will not crash on too many unread emails
                              • Better fetching of recent and unread emails
                                ronny3050 Module Developer @eugenelai
                                @eugenelai @apm1007 @Gungnir83 Please update. :)
                                  Preve
                                  Done the update and now email is “Loading”. Nothing more than this.
                                  Anyone knows why?
                                  The bottom error I got after the “npm install”.
                                    ronny3050 Module Developer @Preve
                                    @Preve Thanks for the heads up. The bottom parts are warnings and have nothing to do with the module not working. Loading for a long time indicates problem with communicating with your email service.
                                      rodofrn @ronny3050
                                      @ronny3050 I have the same problem as Preve, I have tried multiple email accts, and nothing. Happened after I updated MM. Any ideas?
                                        stephenmelody
                                        Hey @ronny3050, is there a way to only show the sender’s name and not their email address?
                                          MSimonart @davidrq7
                                          @davidrq7 Do you remember what you did to solve this? cause I have the same problem
                                            MSimonart
                                            Hi, when starting up the Mirror, email shows loading…
                                            in my terminal i see the following:
                                            NEW MAIL
                                            NEW MAIL
                                            NEW MAIL
                                            Email notifier error: { Error: Timed out while autenticating with server at Timeout._onTimeout (/home/pi/MagicMirror/modules/email/node_modules/imap/lib/Connection
                                            my config looks good,
                                            Accounts: [
                                            user: ‘XX@hotmail.com’,
                                            password: ‘’,
                                            host: ‘imap-mail.outlook.com’,
                                            port: 993,
                                            tls: true,
                                            authTimeout: 10000,
                                            numberOfEmails: 5
                                            fade: true,
                                            maxCharacters: 30
                                            • 3 / 5
