    Email
    92 Posts 36 Posters 149.3k Views 39 Watching
      A Former User
      Errors
      Email notifier error: { Error: read ECONNRESET
      at exports._errnoException (util.js:1026:11)
      at TCP.onread (net.js:564:26)
      code: ‘ECONNRESET’,
      errno: ‘ECONNRESET’,
      syscall: ‘read’,
      source: ‘socket’ }
      code: ‘ECONNRESET’,
      syscall: ‘read’,
      source: ‘socket’ }
      code: ‘ECONNRESET’,
      syscall: ‘read’,
      source: ‘socket’ }
      code: ‘ECONNRESET’,
      syscall: ‘read’,
      source: ‘socket’ }
      code: ‘ECONNRESET’,
      syscall: ‘read’,
      source: ‘socket’ }
        Peter_van_Evert
        Hello ronny3050, the module is great, but after a while the module stands still. On my Mobilphone there are messages about new emails but your email Module does nothing. After a restart from the raspberry pi, everything is ok again, but after a few hours the same… Could you help me ?
        Yours Peter van Evert
        • strawberry 3.141S
          strawberry 3.141 Project Sponsor Module Developer @Peter_van_Evert
          @Peter_van_Evert hes offline since two months, you probably have more success with open an issue on github
            ronny3050 Module Developer @strawberry 3.141
            @strawberry-3.141 @Peter_van_Evert I apologize for not being able to get back to you sooner - been busy with grad school. :( I replied on the issue on github. Thanks! :)
            • Z
              zman3
              can anyone think of a reason the email is not updating to show new emails? i’m very new to this stuff, the temperature module is updating the temperature so its still connected.
              thanks
                Peter_van_Evert @zman3
                @zman3 I got the same problem and only one solution, till now. Press CTRL(STRG) and R to restart the magic mirror client. After that the emails are ok, till 2-3 hours… :)
                  ronny3050 Module Developer @Peter_van_Evert
                  @Peter_van_Evert This is really strange. I have not faced this myself.
                  I think it is because your email client stops responding after 2-3 hours due to security reasons, perhaps :/
                    ronny3050 Module Developer @Guest
                    @wjdw87 This usually happens due to two reasons:
                    1. Connection to your mail client is not possible - try the two-factor authentication mentioned before for using Gmail, or your credentials are wrong.
                    2. Try restarting mirror.
                    • E
                      edsulst
                      Is it possible to sroll the subject instead of putting a limit to the number of characters ?
                        pepemujica
                        Hi! is it possible to use it in emails requesting 2nd factor?
                          davidrq7
                          Hi guys can any 1 help me? Email module shows all the time no new emails, and the console looks like this: 0_1491837734246_17857461_1549238255109393_1377519403_n.jpg
                          Edit: Solved. Just added “subjectlength: 50” at the end of script and works fine :)
                          • G
                            Gungnir83
                            I refer to the possibility of a multiaccount module.
                            I tried to make 2 directories email_a and email_b, uninstalled the module, customized the mail.js und installed it again.
                            In the “global” config I added both modules into the array with their new names (email_a email_b) with all the other neccessary information like the auth…
                            But when I start the mirror app, nothing happens. I see, that the helpers start, but no tries to fetch mails.
                            And no errors.
                            Any suggestions?
                            • A
                              apm1007 @ronny3050
                              @ronny3050 i would like to display only unread emails. thank you.
                              • G
                                gismo2006
                                I use this modul for a long time. but now I have a little question,
                                is it possible to set a intervall to check new emails?? Like every 10 Minutes for example.
                                And if it isn´t possible can I easy put this option in any way?
                                I have to say my coding experencie isn´t very good, so because there is a easy way. :-)
                                greets gismo
                                  Updated email module.
                                  Now supports:
                                  • Multiple email accounts
                                  • Will not crash on too many unread emails
                                  • Better fetching of recent and unread emails
                                    ronny3050 Module Developer @eugenelai
                                    @eugenelai @apm1007 @Gungnir83 Please update. :)
                                      Preve
                                      Done the update and now email is “Loading”. Nothing more than this.
                                      Anyone knows why?
                                      The bottom error I got after the “npm install”.
                                        ronny3050 Module Developer @Preve
                                        @Preve Thanks for the heads up. The bottom parts are warnings and have nothing to do with the module not working. Loading for a long time indicates problem with communicating with your email service.
                                          rodofrn @ronny3050
                                          @ronny3050 I have the same problem as Preve, I have tried multiple email accts, and nothing. Happened after I updated MM. Any ideas?
                                            stephenmelody
                                            Hey @ronny3050, is there a way to only show the sender’s name and not their email address?
                                            • 3 / 5
