    Email
    92 Posts 36 Posters 149.3k Views 39 Watching
    • H
      Hacksaw
              var name = mailObj.sender[0].name.replace(/['"]+/g,"");
              var subject = mailObj.subject.replace(/[\['"\]]+/g,"");    <----- **Here this line**
              var subject = subject.substring(0,30);  <----- **New Line**
        samydp
        perfekt it works !!
        but I’d love that is hidden, the email address and the mail before each a symbol appears is that possible?
          samydp
          hello, thank you to help me by the email module !!
          but I have a question
          you can insert a symbol in front of the email?
          so i have think tis symbol
            A Former User
            said in Email:
            Link to module
            Just getting : Loading
            Any tips on resolving? Thx
              A Former User
              Errors
              Email notifier error: { Error: read ECONNRESET
              at exports._errnoException (util.js:1026:11)
              at TCP.onread (net.js:564:26)
              code: ‘ECONNRESET’,
              errno: ‘ECONNRESET’,
              syscall: ‘read’,
              source: ‘socket’ }
              code: ‘ECONNRESET’,
              syscall: ‘read’,
              source: ‘socket’ }
              code: ‘ECONNRESET’,
              syscall: ‘read’,
              source: ‘socket’ }
              code: ‘ECONNRESET’,
              syscall: ‘read’,
              source: ‘socket’ }
              code: ‘ECONNRESET’,
              syscall: ‘read’,
              source: ‘socket’ }
                Peter_van_Evert
                Hello ronny3050, the module is great, but after a while the module stands still. On my Mobilphone there are messages about new emails but your email Module does nothing. After a restart from the raspberry pi, everything is ok again, but after a few hours the same… Could you help me ?
                Yours Peter van Evert
                • strawberry 3.141S
                  strawberry 3.141 Project Sponsor Module Developer @Peter_van_Evert
                  @Peter_van_Evert hes offline since two months, you probably have more success with open an issue on github
                    ronny3050 Module Developer @strawberry 3.141
                    @strawberry-3.141 @Peter_van_Evert I apologize for not being able to get back to you sooner - been busy with grad school. :( I replied on the issue on github. Thanks! :)
                    • Z
                      zman3
                      can anyone think of a reason the email is not updating to show new emails? i’m very new to this stuff, the temperature module is updating the temperature so its still connected.
                      thanks
                        Peter_van_Evert @zman3
                        @zman3 I got the same problem and only one solution, till now. Press CTRL(STRG) and R to restart the magic mirror client. After that the emails are ok, till 2-3 hours… :)
                          ronny3050 Module Developer @Peter_van_Evert
                          @Peter_van_Evert This is really strange. I have not faced this myself.
                          I think it is because your email client stops responding after 2-3 hours due to security reasons, perhaps :/
                            ronny3050 Module Developer @Guest
                            @wjdw87 This usually happens due to two reasons:
                            1. Connection to your mail client is not possible - try the two-factor authentication mentioned before for using Gmail, or your credentials are wrong.
                            2. Try restarting mirror.
                            • E
                              edsulst
                              Is it possible to sroll the subject instead of putting a limit to the number of characters ?
                                pepemujica
                                Hi! is it possible to use it in emails requesting 2nd factor?
                                  davidrq7
                                  Hi guys can any 1 help me? Email module shows all the time no new emails, and the console looks like this: 0_1491837734246_17857461_1549238255109393_1377519403_n.jpg
                                  Edit: Solved. Just added “subjectlength: 50” at the end of script and works fine :)
                                  • G
                                    Gungnir83
                                    I refer to the possibility of a multiaccount module.
                                    I tried to make 2 directories email_a and email_b, uninstalled the module, customized the mail.js und installed it again.
                                    In the “global” config I added both modules into the array with their new names (email_a email_b) with all the other neccessary information like the auth…
                                    But when I start the mirror app, nothing happens. I see, that the helpers start, but no tries to fetch mails.
                                    And no errors.
                                    Any suggestions?
                                    • A
                                      apm1007 @ronny3050
                                      @ronny3050 i would like to display only unread emails. thank you.
                                      • G
                                        gismo2006
                                        I use this modul for a long time. but now I have a little question,
                                        is it possible to set a intervall to check new emails?? Like every 10 Minutes for example.
                                        And if it isn´t possible can I easy put this option in any way?
                                        I have to say my coding experencie isn´t very good, so because there is a easy way. :-)
                                        greets gismo
                                          Updated email module.
                                          Now supports:
                                          • Multiple email accounts
                                          • Will not crash on too many unread emails
                                          • Better fetching of recent and unread emails
                                            ronny3050 Module Developer @eugenelai
                                            @eugenelai @apm1007 @Gungnir83 Please update. :)
                                            • 3 / 5
