    Email
    92 Posts 36 Posters 150.5k Views 39 Watching
    • E
      eugenelai
      Is it possible to add two email addresses? Kindly please advice @ronny3050
      R 1 Reply Last reply
      • strawberry 3.141S
        multiple adresses are currently not possible
        • N
          Neokamikaze
          Hi @ronny3050,
          I have a problem, same problem that @pietrodona. My emails are double on my mirror same after reboot. After a few day, my emails are double on my mirror. And after delete my emails on Gmail these emails aren’t deleted on my mirror.
          • cowboysdudeC
            cowboysdude Module Developer @ronny3050
            @ronny3050 said in Email:
            @amanzimdwini Also, if you’re using Gmail, you need to ‘set lower security for apps’ https://www.google.com/settings/security/lesssecureapps.
            @ronny3050 I did that and still no emails ;( Everything is set up correctly … login/password …
            Suggestions?
              samydp
              you can adjust the size of the email?
              at too long email that goes module over the entire screen
              H 1 Reply Last reply
              • H
                Hacksaw @samydp
                @samydp
                email.js
                search line 59:
                var subject = mailObj.subject.replace(/[['“]]+/g,”");
                among them include:
                var subject = subject.substring(0,30); //This limit of 30 characters
                  robertdempsey
                  So far it’s working like a charm! Thanks for creating this module.
                    robertdempsey @pietrodona
                    @pietrodona be sure to install the dependencies per the README. I skipped that part and MM stopped at a white screen. Once the deps were installed everything worked well.
                    Reply Quote 2
                      samydp
                      thx, but dont have the line :/
                      this is in the email.js file :
                      defaults : {
                          user: 'a@b.com',
                          password: 'xxx',
                          host: 'jjj.kkk.com',
                          port: 993,
                          tls: true,
                          authTimeout: 10000,
                          numberOfEmails: 5,
                          fade: true
                      payload: [],
                      start : function(){
                          console.log("Email module started!");
                          this.sendSocketNotification('LISTEN_EMAIL',{config: this.config, payload: this.payload, loaded: this.loaded});
                          this.loaded = false;
                      socketNotificationReceived: function(notification, payload){
                          if (notification === 'EMAIL_RESPONSE'){
                              if(payload){
                                  this.loaded = true;
                                  var that = this;
                                  console.log("NEW PAYLOAD: ", payload);
                                  payload.forEach(function(m){
                                      if(that.payload.indexOf(m.id) == -1)
                                          that.payload.push(m);
                                  this.payload.sort(function(a,b) {return b.id - a.id; });
                                  this.updateDom(2000);
                      // Define required scripts.
                      getStyles: function() {
                          return ["email.css", "font-awesome.css"];
                      getDom: function(){
                          var wrapper = document.createElement("table");
                          wrapper.className = "small";
                          var that =this;
                          if(this.payload.length > 0)
                              var count = 0;
                              this.payload.slice(0,this.config.numberOfEmails).forEach(function (mailObj) {
                                  var name = mailObj.sender[0].name.replace(/['"]+/g,"");
                                  var subject = mailObj.subject.replace(/[\['"\]]+/g,"");
                                  var emailWrapper = document.createElement("tr");
                                  emailWrapper.className = "normal";
                                  var senderWrapper = document.createElement("tr");
                                  senderWrapper.className = "normal";
                                  var nameWrapper = document.createElement("td");
                                  nameWrapper.className = "bright";
                                  nameWrapper.innerHTML = name;
                                  senderWrapper.appendChild(nameWrapper);
                                  var addressWrapper = document.createElement("td");
                                  addressWrapper.className = "address xsmall thin dimmed";
                                  addressWrapper.innerHTML = mailObj.sender[0].address;
                                  senderWrapper.appendChild(addressWrapper);
                                  emailWrapper.appendChild(senderWrapper);
                                  var subjectWrapper = document.createElement("tr");
                                  subjectWrapper.className = "light";
                                  subjectWrapper.innerHTML = subject;
                                  emailWrapper.appendChild(subjectWrapper);
                                  wrapper.appendChild(emailWrapper);
                                  // Create fade effect.
                                  if (that.config.fade) {
                                      var startingPoint = that.payload.slice(0,that.config.numberOfEmails).length * 0.25;
                                      var steps = that.payload.slice(0,that.config.numberOfEmails).length - startingPoint;
                                      if (count >= startingPoint) {
                                          var currentStep = count - startingPoint;
                                          emailWrapper.style.opacity = 1 - (1 / steps * currentStep);
                                  count++;
                          else{
                              wrapper.innerHTML = (this.loaded) ? "No new mails" : this.translate("LOADING");
                              wrapper.className = "small dimmed";
                              return wrapper;
                          return wrapper;
                      • H
                        Hacksaw
                                var subject = mailObj.subject.replace(/[\['"\]]+/g,"");    <----- **Here this line**
                                var subject = subject.substring(0,30);  <----- **New Line**
                          samydp
                          perfekt it works !!
                          but I’d love that is hidden, the email address and the mail before each a symbol appears is that possible?
                            samydp
                            hello, thank you to help me by the email module !!
                            but I have a question
                            you can insert a symbol in front of the email?
                            so i have think tis symbol
                              A Former User
                              said in Email:
                              Link to module
                              Just getting : Loading
                              Any tips on resolving? Thx
                                A Former User
                                Errors
                                Email notifier error: { Error: read ECONNRESET
                                at exports._errnoException (util.js:1026:11)
                                at TCP.onread (net.js:564:26)
                                code: ‘ECONNRESET’,
                                errno: ‘ECONNRESET’,
                                syscall: ‘read’,
                                source: ‘socket’ }
                                code: ‘ECONNRESET’,
                                syscall: ‘read’,
                                source: ‘socket’ }
                                code: ‘ECONNRESET’,
                                syscall: ‘read’,
                                source: ‘socket’ }
                                code: ‘ECONNRESET’,
                                syscall: ‘read’,
                                source: ‘socket’ }
                                code: ‘ECONNRESET’,
                                syscall: ‘read’,
                                source: ‘socket’ }
                                  Peter_van_Evert
                                  Hello ronny3050, the module is great, but after a while the module stands still. On my Mobilphone there are messages about new emails but your email Module does nothing. After a restart from the raspberry pi, everything is ok again, but after a few hours the same… Could you help me ?
                                  Yours Peter van Evert
                                  • strawberry 3.141S
                                    strawberry 3.141 Project Sponsor Module Developer @Peter_van_Evert
                                    @Peter_van_Evert hes offline since two months, you probably have more success with open an issue on github
                                      ronny3050 Module Developer @strawberry 3.141
                                      @strawberry-3.141 @Peter_van_Evert I apologize for not being able to get back to you sooner - been busy with grad school. :( I replied on the issue on github. Thanks! :)
                                      • zman3Z
                                        zman3
                                        can anyone think of a reason the email is not updating to show new emails? i’m very new to this stuff, the temperature module is updating the temperature so its still connected.
                                        thanks
                                        P 1 Reply Last reply
                                          Peter_van_Evert @zman3
                                          @zman3 I got the same problem and only one solution, till now. Press CTRL(STRG) and R to restart the magic mirror client. After that the emails are ok, till 2-3 hours… :)
                                            ronny3050 Module Developer @Peter_van_Evert
                                            @Peter_van_Evert This is really strange. I have not faced this myself.
                                            I think it is because your email client stops responding after 2-3 hours due to security reasons, perhaps :/
                                            • 2 / 5
