    Email
    92 Posts 36 Posters 132.9k Views 39 Watching
      ronny3050 Module Developer @pietrodona
      @pietrodona rebooting helps. The issue could’ve been some IMAP error. This happens because IMAP is super sensitive and errors without reason.
      Hopefully, all is well now.
      • KirAsh4K Offline
        KirAsh4 Moderator
        When in doubt, pull the plug.
        • E Offline
          eugenelai
          Is it possible to add two email addresses? Kindly please advice @ronny3050
          • strawberry 3.141S Offline
            multiple adresses are currently not possible
            • N Offline
              Neokamikaze
              Hi @ronny3050,
              I have a problem, same problem that @pietrodona. My emails are double on my mirror same after reboot. After a few day, my emails are double on my mirror. And after delete my emails on Gmail these emails aren’t deleted on my mirror.
              • cowboysdudeC Offline
                cowboysdude Module Developer @ronny3050
                @ronny3050 said in Email:
                @amanzimdwini Also, if you’re using Gmail, you need to ‘set lower security for apps’ https://www.google.com/settings/security/lesssecureapps.
                @ronny3050 I did that and still no emails ;( Everything is set up correctly … login/password …
                Suggestions?
                  samydp
                  you can adjust the size of the email?
                  at too long email that goes module over the entire screen
                  • H Offline
                    Hacksaw @samydp
                    @samydp
                    email.js
                    search line 59:
                    var subject = mailObj.subject.replace(/[['“]]+/g,”");
                    among them include:
                    var subject = subject.substring(0,30); //This limit of 30 characters
                      robertdempsey
                      So far it’s working like a charm! Thanks for creating this module.
                        robertdempsey @pietrodona
                        @pietrodona be sure to install the dependencies per the README. I skipped that part and MM stopped at a white screen. Once the deps were installed everything worked well.
                        • 10
                        • 3 / 10
