    Email
    92 Posts 36 Posters 150.5k Views 39 Watching
      ronny3050 Module Developer @amanzimdwini
      @amanzimdwini Could you please report the logs?
        @amanzimdwini Also, if you’re using Gmail, you need to ‘set lower security for apps’ https://www.google.com/settings/security/lesssecureapps.
          @amanzimdwini It should be working now?
          A 1 Reply Last reply
          • A
            amanzimdwini @ronny3050
            @ronny3050
            Just did a clean install on a brand new pi in about 5 minutes flat. COOL MODULE.
            (still need to work on 2-auth, please. Plus I’ll want to change your config to make the display single line etc. I’ll look at the js file)
            R 1 Reply Last reply
              @amanzimdwini I am working on it. Also, I am finishing up with another module that works in a very similar fashion, where your requests would be required as well. I’ll add them together :D
              • N
                Neokamikaze
                Thanks for this job.
                It’s possible to add number of email don’t read in the header module ?
                  ronny3050 Module Developer @Neokamikaze
                  @Neokamikaze Thanks for your kind words!
                  It is definitely possible. Unfortunately, I am traveling and don’t have my mirror with me. I will add it in a week and update you.
                  Thanks once more :D
                    pietrodona
                    Thank you very much for this amazing module. Unfortunately, I was not able to make it work properly. Without giving any error (at least that I am aware of) it freezes on the loading screen.
                    I managed the security and everything, it is a Gmail account.
                    Any idea of what’s going on?
                      pietrodona
                      Sorry for double posting. Now it works, but I did nothing but rebooting.
                        ronny3050 Module Developer @pietrodona
                        @pietrodona rebooting helps. The issue could’ve been some IMAP error. This happens because IMAP is super sensitive and errors without reason.
                        Hopefully, all is well now.
                        • KirAsh4K
                          KirAsh4 Moderator
                          When in doubt, pull the plug.
                          • E
                            eugenelai
                            Is it possible to add two email addresses? Kindly please advice @ronny3050
                            • strawberry 3.141S
                              multiple adresses are currently not possible
                              • N
                                Neokamikaze
                                Hi @ronny3050,
                                I have a problem, same problem that @pietrodona. My emails are double on my mirror same after reboot. After a few day, my emails are double on my mirror. And after delete my emails on Gmail these emails aren’t deleted on my mirror.
                                • cowboysdudeC
                                  cowboysdude Module Developer @ronny3050
                                  @ronny3050 said in Email:
                                  @ronny3050 I did that and still no emails ;( Everything is set up correctly … login/password …
                                  Suggestions?
                                    samydp
                                    you can adjust the size of the email?
                                    at too long email that goes module over the entire screen
                                    H 1 Reply Last reply
                                    • H
                                      Hacksaw @samydp
                                      @samydp
                                      email.js
                                      search line 59:
                                      var subject = mailObj.subject.replace(/[['“]]+/g,”");
                                      among them include:
                                      var subject = subject.substring(0,30); //This limit of 30 characters
                                        robertdempsey
                                        So far it’s working like a charm! Thanks for creating this module.
                                          robertdempsey @pietrodona
                                          @pietrodona be sure to install the dependencies per the README. I skipped that part and MM stopped at a white screen. Once the deps were installed everything worked well.
                                          Reply Quote 2
                                            samydp
                                            thx, but dont have the line :/
                                            this is in the email.js file :
                                            defaults : {
                                                user: 'a@b.com',
                                                password: 'xxx',
                                                host: 'jjj.kkk.com',
                                                port: 993,
                                                tls: true,
                                                authTimeout: 10000,
                                                numberOfEmails: 5,
                                                fade: true
                                            payload: [],
                                            start : function(){
                                                console.log("Email module started!");
                                                this.sendSocketNotification('LISTEN_EMAIL',{config: this.config, payload: this.payload, loaded: this.loaded});
                                                this.loaded = false;
                                            socketNotificationReceived: function(notification, payload){
                                                if (notification === 'EMAIL_RESPONSE'){
                                                    if(payload){
                                                        this.loaded = true;
                                                        var that = this;
                                                        console.log("NEW PAYLOAD: ", payload);
                                                        payload.forEach(function(m){
                                                            if(that.payload.indexOf(m.id) == -1)
        that.payload.push(m);
                                                        this.payload.sort(function(a,b) {return b.id - a.id; });
                                                        this.updateDom(2000);
                                            // Define required scripts.
                                            getStyles: function() {
                                                return ["email.css", "font-awesome.css"];
                                            getDom: function(){
                                                var wrapper = document.createElement("table");
                                                wrapper.className = "small";
                                                var that =this;
                                                if(this.payload.length > 0)
                                                    var count = 0;
                                                    this.payload.slice(0,this.config.numberOfEmails).forEach(function (mailObj) {
                                                        var name = mailObj.sender[0].name.replace(/['"]+/g,"");
                                                        var subject = mailObj.subject.replace(/[\['"\]]+/g,"");
                                                        var emailWrapper = document.createElement("tr");
                                                        emailWrapper.className = "normal";
                                                        var senderWrapper = document.createElement("tr");
                                                        senderWrapper.className = "normal";
                                                        var nameWrapper = document.createElement("td");
                                                        nameWrapper.className = "bright";
                                                        nameWrapper.innerHTML = name;
                                                        senderWrapper.appendChild(nameWrapper);
                                                        var addressWrapper = document.createElement("td");
                                                        addressWrapper.className = "address xsmall thin dimmed";
                                                        addressWrapper.innerHTML = mailObj.sender[0].address;
                                                        senderWrapper.appendChild(addressWrapper);
                                                        emailWrapper.appendChild(senderWrapper);
                                                        var subjectWrapper = document.createElement("tr");
                                                        subjectWrapper.className = "light";
                                                        subjectWrapper.innerHTML = subject;
                                                        emailWrapper.appendChild(subjectWrapper);
                                                        wrapper.appendChild(emailWrapper);
                                                        // Create fade effect.
                                                        if (that.config.fade) {
                                                            var startingPoint = that.payload.slice(0,that.config.numberOfEmails).length * 0.25;
                                                            var steps = that.payload.slice(0,that.config.numberOfEmails).length - startingPoint;
                                                            if (count >= startingPoint) {
        var currentStep = count - startingPoint;
        emailWrapper.style.opacity = 1 - (1 / steps * currentStep);
                                                        count++;
                                                else{
                                                    wrapper.innerHTML = (this.loaded) ? "No new mails" : this.translate("LOADING");
                                                    wrapper.className = "small dimmed";
                                                    return wrapper;
                                                return wrapper;
                                            • 2 / 5
