    Email
    92 Posts 36 Posters 150.5k Views 39 Watching
    • A
      amanzimdwini @ronny3050
      @ronny3050
      Sorry - pasted only partial copy; I had the trailing }.
      My Config.js was correct…
      Just to be on the safe side, I tested it as if config.js had been what I posted - and that failed with a “please create a config file”. As it should have.
      So - I think the problem is elsewhere. Sorry
      R 3 Replies Last reply
        ronny3050 Module Developer @amanzimdwini
        @amanzimdwini Could you please report the logs?
          @amanzimdwini Also, if you’re using Gmail, you need to ‘set lower security for apps’ https://www.google.com/settings/security/lesssecureapps.
            @amanzimdwini It should be working now?
            A 1 Reply Last reply
            • A
              @ronny3050
              Just did a clean install on a brand new pi in about 5 minutes flat. COOL MODULE.
              (still need to work on 2-auth, please. Plus I’ll want to change your config to make the display single line etc. I’ll look at the js file)
              R 1 Reply Last reply
                @amanzimdwini I am working on it. Also, I am finishing up with another module that works in a very similar fashion, where your requests would be required as well. I’ll add them together :D
                • N
                  Neokamikaze
                  Thanks for this job.
                  It’s possible to add number of email don’t read in the header module ?
                    ronny3050 Module Developer @Neokamikaze
                    @Neokamikaze Thanks for your kind words!
                    It is definitely possible. Unfortunately, I am traveling and don’t have my mirror with me. I will add it in a week and update you.
                    Thanks once more :D
                      pietrodona
                      Thank you very much for this amazing module. Unfortunately, I was not able to make it work properly. Without giving any error (at least that I am aware of) it freezes on the loading screen.
                      I managed the security and everything, it is a Gmail account.
                      Any idea of what’s going on?
                        pietrodona
                        Sorry for double posting. Now it works, but I did nothing but rebooting.
                          ronny3050 Module Developer @pietrodona
                          @pietrodona rebooting helps. The issue could’ve been some IMAP error. This happens because IMAP is super sensitive and errors without reason.
                          Hopefully, all is well now.
                          • KirAsh4K
                            KirAsh4 Moderator
                            When in doubt, pull the plug.
                            • E
                              eugenelai
                              Is it possible to add two email addresses? Kindly please advice @ronny3050
                              • strawberry 3.141S
                                multiple adresses are currently not possible
                                • N
                                  Neokamikaze
                                  Hi @ronny3050,
                                  I have a problem, same problem that @pietrodona. My emails are double on my mirror same after reboot. After a few day, my emails are double on my mirror. And after delete my emails on Gmail these emails aren’t deleted on my mirror.
                                  • cowboysdudeC
                                    cowboysdude Module Developer @ronny3050
                                    @ronny3050 said in Email:
                                    @ronny3050 I did that and still no emails ;( Everything is set up correctly … login/password …
                                    Suggestions?
                                      samydp
                                      you can adjust the size of the email?
                                      at too long email that goes module over the entire screen
                                      H 1 Reply Last reply
                                      • H
                                        Hacksaw @samydp
                                        @samydp
                                        email.js
                                        search line 59:
                                        var subject = mailObj.subject.replace(/[['“]]+/g,”");
                                        among them include:
                                        var subject = subject.substring(0,30); //This limit of 30 characters
                                          robertdempsey
                                          So far it’s working like a charm! Thanks for creating this module.
                                            robertdempsey @pietrodona
                                            @pietrodona be sure to install the dependencies per the README. I skipped that part and MM stopped at a white screen. Once the deps were installed everything worked well.
                                            Reply Quote 2
                                            • 2 / 5
