    Email
    92 Posts 36 Posters 150.5k Views 39 Watching
    • A
      amanzimdwini @ronny3050
      @ronny3050
      pi@MagicMirror2:~/MagicMirror/modules $ npm install
      npm WARN enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/package.json'
      npm WARN enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/node_modules/node_helper/packa        ge.json'
      npm WARN modules No description
      npm WARN modules No repository field.
      npm WARN modules No README data
      npm WARN modules No license field.
      pi@MagicMirror2:~/MagicMirror/modules $ ^C
      pi@MagicMirror2:~/MagicMirror/modules $ cd ..
      pi@MagicMirror2:~/MagicMirror $ cd config/
      pi@MagicMirror2:~/MagicMirror/config $ ls
      config.1  config.2  config.5.keep  config.good  config.good.js  config.good.swap  config.js  config.js.sample  config.js.save  config.js.save.1
      pi@MagicMirror2:~/MagicMirror/config $ sudo nano config.js
      pi@MagicMirror2:~/MagicMirror/config $ cd ..
      pi@MagicMirror2:~/MagicMirror $ cd modules/
      pi@MagicMirror2:~/MagicMirror/modules $ ls
      default  email  MMM-HTTPRequestDisplay  MMM-wordnik  MMM-WunderGround  MMM-Wunderlist  node_modules  README.md  TR_swap
      pi@MagicMirror2:~/MagicMirror/modules $ cd email/
      pi@MagicMirror2:~/MagicMirror/modules/email $ npm install
      email@0.0.1 /home/pi/MagicMirror/modules/email
      ├─┬ debug@2.2.0
      │ └── ms@0.7.1
      ├─┬ imap@0.8.17
      │ ├─┬ readable-stream@1.1.14
      │ │ ├── core-util-is@1.0.2
      │ │ ├── inherits@2.0.1
      │ │ ├── isarray@0.0.1
      │ │ └── string_decoder@0.10.31
      │ └── utf7@1.0.0
      ├─┬ mailparser@0.4.9
      │ ├─┬ encoding@0.1.12
      │ │ └── iconv-lite@0.4.13
      │ ├── mime@1.3.4
      │ ├─┬ mimelib@0.2.19
      │ │ └── addressparser@0.3.2
      │ └── uue@1.0.0
      └── underscore@1.8.3
      npm WARN email@0.0.1 No repository field.
      npm WARN email@0.0.1 No license field.
      Note from admin: Please use Markdown on code and shell snippets!
      R 1 Reply Last reply
        ronny3050 Module Developer @amanzimdwini
        @amanzimdwini Yes, you should be all set! Thanks for the updates. :D
        A 1 Reply Last reply
        • A
          @ronny3050
          Thx for updating the README.
          Followed instructions (requested app-pwd since I have 2-factor authentication).
          My config.js:
                                  module: 'email',
                                  position: 'bottom_left',
                                  header: 'Email',
                                  config:{
                                  user: 'XXX@gmail.com',
                                  password: '****************',
                                  host: 'imap.gmail.com',
                                  port: 993,
                                  tls: true,
                                  authTimeout: 10000,
                                  numberOfEmails: 5,
                                  fade: true
          Restarted (NOT REBOOTED) Pi.
          Got this:
          0_1469426287738_upload-38a60756-5f8a-4933-b4f3-af564be8f683
          Rebooted (just to be safe) - same result.
            @amanzimdwini you are missing a ‘}’ which closes the config block. It should look like:
                                    module: 'email',
                                    header: 'Email',
                                    config:{
                                    port: 993,
                                    tls: true,
                                    authTimeout: 10000,
                                    numberOfEmails: 5,
                                    fade: true
            • A
              @ronny3050
              Sorry - pasted only partial copy; I had the trailing }.
              My Config.js was correct…
              Just to be on the safe side, I tested it as if config.js had been what I posted - and that failed with a “please create a config file”. As it should have.
              So - I think the problem is elsewhere. Sorry
              R 3 Replies Last reply
                @amanzimdwini Could you please report the logs?
                  @amanzimdwini Also, if you’re using Gmail, you need to ‘set lower security for apps’ https://www.google.com/settings/security/lesssecureapps.
                    @amanzimdwini It should be working now?
                    • A
                      @ronny3050
                      Just did a clean install on a brand new pi in about 5 minutes flat. COOL MODULE.
                      (still need to work on 2-auth, please. Plus I’ll want to change your config to make the display single line etc. I’ll look at the js file)
                        @amanzimdwini I am working on it. Also, I am finishing up with another module that works in a very similar fashion, where your requests would be required as well. I’ll add them together :D
                        • N
                          Neokamikaze
                          Thanks for this job.
                          It’s possible to add number of email don’t read in the header module ?
                            ronny3050 Module Developer @Neokamikaze
                            @Neokamikaze Thanks for your kind words!
                            It is definitely possible. Unfortunately, I am traveling and don’t have my mirror with me. I will add it in a week and update you.
                            Thanks once more :D
                              pietrodona
                              Thank you very much for this amazing module. Unfortunately, I was not able to make it work properly. Without giving any error (at least that I am aware of) it freezes on the loading screen.
                              I managed the security and everything, it is a Gmail account.
                              Any idea of what’s going on?
                                pietrodona
                                Sorry for double posting. Now it works, but I did nothing but rebooting.
                                  ronny3050 Module Developer @pietrodona
                                  @pietrodona rebooting helps. The issue could’ve been some IMAP error. This happens because IMAP is super sensitive and errors without reason.
                                  Hopefully, all is well now.
                                  • KirAsh4K
                                    KirAsh4 Moderator
                                    When in doubt, pull the plug.
                                    • E
                                      eugenelai
                                      Is it possible to add two email addresses? Kindly please advice @ronny3050
                                      • strawberry 3.141S
                                        multiple adresses are currently not possible
                                        • N
                                          Neokamikaze
                                          Hi @ronny3050,
                                          I have a problem, same problem that @pietrodona. My emails are double on my mirror same after reboot. After a few day, my emails are double on my mirror. And after delete my emails on Gmail these emails aren’t deleted on my mirror.
                                          • cowboysdudeC
                                            cowboysdude Module Developer @ronny3050
                                            @ronny3050 said in Email:
                                            @ronny3050 I did that and still no emails ;( Everything is set up correctly … login/password …
                                            Suggestions?
                                            • 2 / 5
