    Email
    92 Posts 36 Posters 150.5k Views 39 Watching
      ronny3050 Module Developer @amanzimdwini
      @amanzimdwini Yes, you should be all set! Thanks for the updates. :D
      A 1 Reply Last reply
      • A
        amanzimdwini @ronny3050
        @ronny3050
        Thx for updating the README.
        Followed instructions (requested app-pwd since I have 2-factor authentication).
        My config.js:
                                module: 'email',
                                position: 'bottom_left',
                                header: 'Email',
                                config:{
                                user: 'XXX@gmail.com',
                                password: '****************',
                                host: 'imap.gmail.com',
                                port: 993,
                                tls: true,
                                authTimeout: 10000,
                                numberOfEmails: 5,
                                fade: true
        Restarted (NOT REBOOTED) Pi.
        Got this:
        0_1469426287738_upload-38a60756-5f8a-4933-b4f3-af564be8f683
        Rebooted (just to be safe) - same result.
        R 1 Reply Last reply
          @amanzimdwini you are missing a ‘}’ which closes the config block. It should look like:
                                  module: 'email',
                                  header: 'Email',
                                  config:{
                                  port: 993,
                                  tls: true,
                                  authTimeout: 10000,
                                  numberOfEmails: 5,
                                  fade: true
          • A
            @ronny3050
            Sorry - pasted only partial copy; I had the trailing }.
            My Config.js was correct…
            Just to be on the safe side, I tested it as if config.js had been what I posted - and that failed with a “please create a config file”. As it should have.
            So - I think the problem is elsewhere. Sorry
            R 3 Replies Last reply
              @amanzimdwini Could you please report the logs?
                @amanzimdwini Also, if you’re using Gmail, you need to ‘set lower security for apps’ https://www.google.com/settings/security/lesssecureapps.
                  @amanzimdwini It should be working now?
                  • A
                    @ronny3050
                    Just did a clean install on a brand new pi in about 5 minutes flat. COOL MODULE.
                    (still need to work on 2-auth, please. Plus I’ll want to change your config to make the display single line etc. I’ll look at the js file)
                      @amanzimdwini I am working on it. Also, I am finishing up with another module that works in a very similar fashion, where your requests would be required as well. I’ll add them together :D
                      • N
                        Neokamikaze
                        Thanks for this job.
                        It’s possible to add number of email don’t read in the header module ?
                          ronny3050 Module Developer @Neokamikaze
                          @Neokamikaze Thanks for your kind words!
                          It is definitely possible. Unfortunately, I am traveling and don’t have my mirror with me. I will add it in a week and update you.
                          Thanks once more :D
                            pietrodona
                            Thank you very much for this amazing module. Unfortunately, I was not able to make it work properly. Without giving any error (at least that I am aware of) it freezes on the loading screen.
                            I managed the security and everything, it is a Gmail account.
                            Any idea of what’s going on?
                              pietrodona
                              Sorry for double posting. Now it works, but I did nothing but rebooting.
                                ronny3050 Module Developer @pietrodona
                                @pietrodona rebooting helps. The issue could’ve been some IMAP error. This happens because IMAP is super sensitive and errors without reason.
                                Hopefully, all is well now.
                                • KirAsh4K
                                  KirAsh4 Moderator
                                  When in doubt, pull the plug.
                                  • E
                                    eugenelai
                                    Is it possible to add two email addresses? Kindly please advice @ronny3050
                                    • strawberry 3.141S
                                      multiple adresses are currently not possible
                                      • N
                                        Neokamikaze
                                        Hi @ronny3050,
                                        I have a problem, same problem that @pietrodona. My emails are double on my mirror same after reboot. After a few day, my emails are double on my mirror. And after delete my emails on Gmail these emails aren’t deleted on my mirror.
                                        • cowboysdudeC
                                          cowboysdude Module Developer @ronny3050
                                          @ronny3050 said in Email:
                                          @ronny3050 I did that and still no emails ;( Everything is set up correctly … login/password …
                                          Suggestions?
                                            samydp
                                            you can adjust the size of the email?
                                            at too long email that goes module over the entire screen
                                            H 1 Reply Last reply
                                            • 2 / 5
